Archives de la liste
- From: Muhammad Usama Asad <muhammad-usama.asad@s2012.tu-chemnitz.de>
- To: Samuel Thibault <samuel.thibault@inria.fr>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Scheduling accelerators
- Date: Wed, 13 Jan 2016 11:56:38 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=muhammad-usama.asad@s2012.tu-chemnitz.de; spf=None smtp.mailfrom=muhammad-usama.asad@s2012.tu-chemnitz.de; spf=None smtp.helo=postmaster@nick.hrz.tu-chemnitz.de
- Ironport-phdr: 9a23:muDbahQ4cQkdSGoGwhyyDAGImtpsv+yvbD5Q0YIujvd0So/mwa65ZRSN2/xhgRfzUJnB7Loc0qyN4/6mCTNLuMnJmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbvipduDPE4R23KUWvBbElaflU3prM4YgI9veO4a6yDihT92QdlQ3n5iPlmJnhzxtY+a9Z9n9DlM6bp6r5YTGY2zRakzTKRZATI6KCh1oZSz7ViQBTeIs0AVV3gbllJ0AwnP5Qz+Qt+lqSL/q+d5njWaPMf/ULQocTWk9aZiDhHy3nQpLTk8pUTKisV1iatX6C+6rhl2i6fPaY3dYP9jfqrYeNoWAHdaV8NYESVaC4+UdNFXVrBHIfsdpInwol0PsQn4CQT6V7Cn8SNBmnKjhf5y6O8mCwyTmVV4R98=
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Ok. If external memory is used with much more space, is it possible to implement? Keeping in view as you mentioned that it will be much slower.
Can I get in contact with somebody through your reference who already implemented starPU for SoC ?
Thanks
Zitat von Samuel Thibault <samuel.thibault@inria.fr>:
Muhammad Usama Asad, on Wed 13 Jan 2016 11:42:18 +0100, wrote:
Samuel I can use global working memory as well which is 4 kilobytes.
Global memory will probably be very slow (I do hope it's 4MiB, not
4KiB), the resulting runtime will not be able to cope with the task rate
required by the multimedia stream.
Samuel
- [Starpu-devel] Scheduling accelerators, Muhammad Usama Asad, 12/01/2016
- Re: [Starpu-devel] Scheduling accelerators, Samuel Thibault, 12/01/2016
- Re: [Starpu-devel] Scheduling accelerators, Muhammad Usama Asad, 12/01/2016
- Re: [Starpu-devel] Scheduling accelerators, Muhammad Usama Asad, 13/01/2016
- Re: [Starpu-devel] Scheduling accelerators, Samuel Thibault, 13/01/2016
