Archives de la liste
- To: Muhammad Usama Asad <muhammad-usama.asad@s2012.tu-chemnitz.de>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Scheduling accelerators
- Date: Tue, 12 Jan 2016 18:57:02 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=None smtp.mailfrom=SRS0=qZh2=NM=ens-lyon.org=samuel.thibault@bounce.ens-lyon.org; spf=Pass smtp.helo=postmaster@sonata.ens-lyon.org
- Ironport-phdr: 9a23:ebpf8xfnQ6n8n3CfzjdXgXlVlGMj4u6mDksu8pMizoh2WeGdxc+7ZB7h7PlgxGXEQZ/co6odzbGG7eawBCdbud6oizMrTt9lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLDsvc2OKF4QzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IeezAcq85Vb1VCig9eyBwvZWz9EqLcQzaw2YcW2ATmxYAPhPM6Riyd4z4vmOus/d90SyfNMGzUKs9XD3k5rxiRDfz0n9ebXgl7STcisF1iqNHslStqkos7ZTTZdSuPf9jc6eVQdMbT2NcWtoZAzdIB56xa80TD+sLNPtcs6H8oUEPpF2wH1//V6vU1jZUiyqujuUB2OM7HFSDhVR4Eg==
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Muhammad Usama Asad, on Tue 12 Jan 2016 18:43:36 +0100, wrote:
> So its not well enough to use for Embedded SoCs. Actually this SoC consists
> of vision accelerators, can you recommend any other scheduler or software
> framework for scheduling accelerators ?
The problem is quite general actually. A PhD student in our team
studied what a dynamic scheduler can afford in an embedded environment,
and it may not be much. Again, how much local memory does it have? Is
it 256KiB, 2MiB, 32MiB? General-purpose dynamic scheduling would
usually needs rather 32MiB than even 2MiB.
Samuel
- [Starpu-devel] Scheduling accelerators, Muhammad Usama Asad, 12/01/2016
- Re: [Starpu-devel] Scheduling accelerators, Samuel Thibault, 12/01/2016
- Re: [Starpu-devel] Scheduling accelerators, Muhammad Usama Asad, 12/01/2016
- Re: [Starpu-devel] Scheduling accelerators, Muhammad Usama Asad, 13/01/2016
- Re: [Starpu-devel] Scheduling accelerators, Samuel Thibault, 13/01/2016
