Archives de la liste
- From: Muhammad Usama Asad <muhammad-usama.asad@s2012.tu-chemnitz.de>
- To: Samuel Thibault <samuel.thibault@inria.fr>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Scheduling accelerators
- Date: Wed, 13 Jan 2016 11:42:18 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=muhammad-usama.asad@s2012.tu-chemnitz.de; spf=None smtp.mailfrom=muhammad-usama.asad@s2012.tu-chemnitz.de; spf=None smtp.helo=postmaster@cora.hrz.tu-chemnitz.de
- Ironport-phdr: 9a23:EFgBjRGmCKfszClwY+cax51GYnF86YWxBRYc798ds5kLTJ74psywAkXT6L1XgUPTWs2DsrQf27SQ4/+rADVIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/niabipNaKOk1hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv+YJa6jxfrw5QLpEF3xmdjltvIy4/SXEGDCG42YRVi0qkhtCChXB8FmuRZ70ryb+8PZ92SOTIMnqZbEyQzWrqalxHkzGkiACYhsk8GjSj8V8xJ9AqReo7zVkyoKcNISINPN7e6rROM4BTG9IGM9KXiBpGdnkNtFJE/dENuZVqo/8u0lIoRboVlrkP//m1jId3iy+5qY9yel0VFiehAE=
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Samuel I can use global working memory as well which is 4 kilobytes. And openMP facilitates with shared memory. Will it be fine then ?
Zitat von Samuel Thibault <samuel.thibault@inria.fr>:
Muhammad Usama Asad, on Wed 13 Jan 2016 11:30:06 +0100, wrote:
Thanks for your reply. The SoC has 2kbyes local memory.
So you mean 2 kilobytes? That's far too little for a generic runtime,
you need to have a look at runtimes specifically dedicated to embedded
systems.
I am therefore assigned this task as part of my masters Thesis. I will
appreciate your teams precious input. Can you recommend some researchers
group or experts for partitioning ?
I don't know about computer vision.
Probably for mapping and scheduling I will be using StarPU and will be
getting your guidance in this regard.
StarPU will definitely not fit in 2 kilobytes.
Samuel
- [Starpu-devel] Scheduling accelerators, Muhammad Usama Asad, 12/01/2016
- Re: [Starpu-devel] Scheduling accelerators, Samuel Thibault, 12/01/2016
- Re: [Starpu-devel] Scheduling accelerators, Muhammad Usama Asad, 12/01/2016
- Re: [Starpu-devel] Scheduling accelerators, Muhammad Usama Asad, 13/01/2016
- Re: [Starpu-devel] Scheduling accelerators, Samuel Thibault, 13/01/2016
