Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] StarPU Configuration error
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@inria.fr>
  • Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
  • Subject: Re: [Starpu-devel] StarPU Configuration error
  • Date: Wed, 6 Apr 2016 07:46:09 +0000 (UTC)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=wafa_nafti@yahoo.fr; spf=Pass smtp.mailfrom=wafa_nafti@yahoo.fr; spf=None smtp.helo=postmaster@nm37-vm5.bullet.mail.ne1.yahoo.com
  • Ironport-phdr: 9a23:jtHYIhG5h/t523/1xSCgzZ1GYnF86YWxBRYc798ds5kLTJ74pc+wAkXT6L1XgUPTWs2DsrQf27qQ7/irADdYqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh7D0p8WYOl4QzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IeezAcq85Vb1VCig9eyBwvZWz9EqLcQza3XIZT2gS2iZIAgLM8RXmFsPquy7nu+47xCmbN8TrSawcWDK47q4tRgW+2x0KLzoozGaCtcV+hep9qRy9plQr3IfaabaTPfRif4vMdNMdQixPRJACeTZGB9aDZoUGR8wIM/pZ593irlUHmh23CxWtLPLmyjhPwHHsi/5pm989GB3LiVRzV+kFt27Z+ZCsbP8f
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Ok, it's in attachment.
Wafa NAFTI
ENSIT, Tunisie
Le Mercredi 6 avril 2016 9h43, Samuel Thibault <samuel.thibault@inria.fr> a écrit :
Hello,
Wafa Nafti, on Wed 06 Apr 2016 07:37:21 +0000, wrote:
> libhwloc-dev is already the newest version.
Ok.
> Thus, it is already installed. However it always gives me the same error
> message during the configuration.
Please post the content of config.log, that's where the actuel error
message lies.
Samuel
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by StarPU configure 1.3.0, which was
generated by GNU Autoconf 2.69.  Invocation command line was
  $ ./configure --with-hwloc
## Platform. ##
hostname = wafa-Inspiron-5521
uname -m = x86_64
uname -r = 3.8.0-35-generic
uname -s = Linux
uname -v = #50-Ubuntu SMP Tue Dec 3 01:24:59 UTC 2013
/usr/bin/uname -p = unknown
/bin/uname -X     = unknown
/bin/arch              = unknown
/usr/bin/arch -k       = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo      = unknown
/bin/machine           = unknown
/usr/bin/oslevel       = unknown
/bin/universe          = unknown
PATH: /usr/local/sbin
PATH: /usr/local/bin
PATH: /usr/sbin
PATH: /usr/bin
PATH: /sbin
PATH: /bin
PATH: /usr/games
PATH: /usr/local/games
## Core tests. ##
configure:3580: checking build system type
configure:3594: result: x86_64-unknown-linux-gnu
configure:3614: checking host system type
configure:3627: result: x86_64-unknown-linux-gnu
configure:3647: checking target system type
configure:3660: result: x86_64-unknown-linux-gnu
configure:3704: checking for a BSD-compatible install
configure:3772: result: /usr/bin/install -c
configure:3783: checking whether build environment is sane
configure:3838: result: yes
configure:3989: checking for a thread-safe mkdir -p
configure:4028: result: /bin/mkdir -p
configure:4035: checking for gawk
configure:4051: found /usr/bin/gawk
configure:4062: result: gawk
configure:4073: checking whether make sets $(MAKE)
configure:4095: result: yes
configure:4124: checking whether make supports nested variables
configure:4141: result: yes
configure:4278: checking whether make supports nested variables
configure:4295: result: yes
configure:4321: checking for style of include used by make
configure:4349: result: GNU
configure:4420: checking for gcc
configure:4436: found /usr/bin/gcc
configure:4447: result: gcc
configure:4676: checking for C compiler version
configure:4685: gcc --version >&5
gcc (Ubuntu/Linaro 4.6.4-6ubuntu2) 4.6.4
Copyright (C) 2011 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:4696: $? = 0
configure:4685: gcc -v >&5
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/4.6/lto-wrapper
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Ubuntu/Linaro 4.6.4-6ubuntu2' --with-bugurl=file:///usr/share/doc/gcc-4.6/README.Bugs --enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.6 --enable-shared --enable-linker-build-id --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.6 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-gnu-unique-object --disable-libmudflap --enable-plugin --enable-objc-gc --disable-werror --with-arch-32=i686 --with-tune=generic --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu
Thread model: posix
gcc version 4.6.4 (Ubuntu/Linaro 4.6.4-6ubuntu2)
configure:4685: gcc -V >&5
gcc: error: unrecognized option '-V'
gcc: fatal error: no input files
compilation terminated.
configure:4696: $? = 4
configure:4685: gcc -qversion >&5
gcc: error: unrecognized option '-qversion'
configure:4716: checking whether the C compiler works
configure:4738: gcc    conftest.c  >&5
configure:4742: $? = 0
configure:4790: result: yes
configure:4793: checking for C compiler default output file name
configure:4795: result: a.out
configure:4801: checking for suffix of executables
configure:4808: gcc -o conftest    conftest.c  >&5
configure:4812: $? = 0
configure:4834: result:
configure:4856: checking whether we are cross compiling
configure:4864: gcc -o conftest    conftest.c  >&5
configure:4868: $? = 0
configure:4875: ./conftest
configure:4879: $? = 0
configure:4894: result: no
configure:4899: checking for suffix of object files
configure:4921: gcc -c   conftest.c >&5
configure:4925: $? = 0
configure:4946: result: o
configure:4950: checking whether we are using the GNU C compiler
configure:4969: gcc -c   conftest.c >&5
configure:4969: $? = 0
configure:4978: result: yes
configure:4987: checking whether gcc accepts -g
configure:5007: gcc -c -g  conftest.c >&5
configure:5007: $? = 0
configure:5048: result: yes
configure:5065: checking for gcc option to accept ISO C89
configure:5128: gcc  -c -g -O2  conftest.c >&5
configure:5128: $? = 0
configure:5141: result: none needed
configure:5166: checking whether gcc understands -c and -o together
configure:5188: gcc -c conftest.c -o conftest2.o
configure:5191: $? = 0
configure:5203: result: yes
configure:5222: checking dependency style of gcc
configure:5333: result: gcc3
configure:5398: checking for ar
configure:5414: found /usr/bin/ar
configure:5425: result: ar
configure:5451: checking the archiver (ar) interface
configure:5467: gcc -c -g -O2  conftest.c >&5
configure:5467: $? = 0
configure:5469: ar cru libconftest.a conftest.o >&5
configure:5472: $? = 0
configure:5500: result: ar
configure:5568: checking for gcc
configure:5595: result: gcc
configure:5824: checking for C compiler version
configure:5833: gcc --version >&5
configure:5844: $? = 0
configure:5833: gcc -v >&5
COLLECT_GCC=gcc
Thread model: posix
configure:5833: gcc -V >&5
configure:5844: $? = 4
configure:5833: gcc -qversion >&5
configure:5848: checking whether we are using the GNU C compiler
configure:5876: result: yes
configure:5885: checking whether gcc accepts -g
configure:5946: result: yes
configure:5963: checking for gcc option to accept ISO C89
configure:6039: result: none needed
configure:6064: checking whether gcc understands -c and -o together
configure:6101: result: yes
configure:6120: checking dependency style of gcc
configure:6231: result: gcc3
configure:6305: checking for g++
configure:6321: found /usr/bin/g++
configure:6332: result: g++
configure:6359: checking for C++ compiler version
configure:6368: g++ --version >&5
g++ (Ubuntu 4.8.4-2ubuntu1~14.04.1) 4.8.4
Copyright (C) 2013 Free Software Foundation, Inc.
configure:6379: $? = 0
configure:6368: g++ -v >&5
COLLECT_GCC=g++
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/4.8/lto-wrapper
Configured with: ../src/configure -v --with-pkgversion='Ubuntu 4.8.4-2ubuntu1~14.04.1' --with-bugurl=file:///usr/share/doc/gcc-4.8/README.Bugs --enable-languages=c,c++,java,go,d,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.8 --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.8 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-gnu-unique-object --disable-libmudflap --enable-plugin --with-system-zlib --disable-browser-plugin --enable-java-awt=gtk --enable-gtk-cairo --with-java-home=/usr/lib/jvm/java-1.5.0-gcj-4.8-amd64/jre --enable-java-home --with-jvm-root-dir=/usr/lib/jvm/java-1.5.0-gcj-4.8-amd64 --with-jvm-jar-dir=/usr/lib/jvm-exports/java-1.5.0-gcj-4.8-amd64 --with-arch-directory=amd64 --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --enable-objc-gc --enable-multiarch --disable-werror --with-arch-32=i686 --with-abi=m64 --with-multilib-list=m32,m64,mx32 --with-tune=generic --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu
Thread model: posix
gcc version 4.8.4 (Ubuntu 4.8.4-2ubuntu1~14.04.1)
configure:6368: g++ -V >&5
g++: error: unrecognized command line option '-V'
g++: fatal error: no input files
configure:6379: $? = 4
configure:6368: g++ -qversion >&5
g++: error: unrecognized command line option '-qversion'
configure:6383: checking whether we are using the GNU C++ compiler
configure:6402: g++ -c   conftest.cpp >&5
configure:6402: $? = 0
configure:6411: result: yes
configure:6420: checking whether g++ accepts -g
configure:6440: g++ -c -g  conftest.cpp >&5
configure:6440: $? = 0
configure:6481: result: yes
configure:6506: checking dependency style of g++
configure:6617: result: gcc3
configure:6637: checking how to run the C preprocessor
configure:6668: gcc -E  conftest.c
configure:6668: $? = 0
configure:6682: gcc -E  conftest.c
conftest.c:14:28: fatal error: ac_nonexistent.h: No such file or directory
configure:6682: $? = 1
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME "StarPU"
| #define PACKAGE_TARNAME "starpu"
| #define PACKAGE_VERSION "1.3.0"
| #define PACKAGE_STRING "StarPU 1.3.0"
| #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr"
| #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/";
| #define STARPU_MAJOR_VERSION 1
| #define STARPU_MINOR_VERSION 3
| #define STARPU_RELEASE_VERSION 0
| #define PACKAGE "starpu"
| #define VERSION "1.3.0"
| /* end confdefs.h.  */
| #include <ac_nonexistent.h>
configure:6707: result: gcc -E
configure:6727: gcc -E  conftest.c
configure:6727: $? = 0
configure:6741: gcc -E  conftest.c
configure:6741: $? = 1
| /* confdefs.h */
configure:6769: checking for a sed that does not truncate output
configure:6833: result: /bin/sed
configure:6838: checking whether ln -s works
configure:6842: result: yes
configure:6902: checking for g77
configure:6932: result: no
configure:6902: checking for xlf
configure:6902: checking for f77
configure:6902: checking for frt
configure:6902: checking for pgf77
configure:6902: checking for cf77
configure:6902: checking for fort77
configure:6902: checking for fl32
configure:6902: checking for af77
configure:6902: checking for xlf90
configure:6902: checking for f90
configure:6902: checking for pgf90
configure:6902: checking for pghpf
configure:6902: checking for epcf90
configure:6902: checking for gfortran
configure:6902: checking for g95
configure:6902: checking for xlf95
configure:6902: checking for f95
configure:6902: checking for ifort
configure:6902: checking for ifc
configure:6902: checking for efc
configure:6902: checking for pgfortran
configure:6902: checking for pgf95
configure:6902: checking for lf95
configure:6902: checking for ftn
configure:6902: checking for nagfor
configure:6955: checking for Fortran 77 compiler version
configure:6964:  --version >&5
./configure: line 6966: --version: command not found
configure:6975: $? = 127
configure:6964:  -v >&5
./configure: line 6966: -v: command not found
configure:6964:  -V >&5
./configure: line 6966: -V: command not found
configure:6964:  -qversion >&5
./configure: line 6966: -qversion: command not found
configure:6984: checking whether we are using the GNU Fortran 77 compiler
configure:6997:  -c  conftest.F >&5
./configure: line 2204: -c: command not found
configure:6997: $? = 127
|       program main
| #ifndef __GNUC__
|        choke me
| #endif
|       end
configure:7006: result: no
configure:7012: checking whether  accepts -g
configure:7023:  -c -g conftest.f >&5
configure:7023: $? = 127
|       program main
|       end
configure:7031: result: no
configure:7113: checking for gfortran
configure:7143: result: no
configure:7113: checking for g95
configure:7113: checking for xlf95
configure:7113: checking for f95
configure:7113: checking for fort
configure:7113: checking for ifort
configure:7113: checking for ifc
configure:7113: checking for efc
configure:7113: checking for pgfortran
configure:7113: checking for pgf95
configure:7113: checking for lf95
configure:7113: checking for ftn
configure:7113: checking for nagfor
configure:7113: checking for xlf90
configure:7113: checking for f90
configure:7113: checking for pgf90
configure:7113: checking for pghpf
configure:7113: checking for epcf90
configure:7113: checking for g77
configure:7113: checking for f77
configure:7113: checking for frt
configure:7113: checking for pgf77
configure:7113: checking for cf77
configure:7113: checking for fort77
configure:7113: checking for fl32
configure:7113: checking for af77
configure:7166: checking for Fortran compiler version
configure:7175:  --version >&5
./configure: line 7177: --version: command not found
configure:7186: $? = 127
configure:7175:  -v >&5
./configure: line 7177: -v: command not found
configure:7175:  -V >&5
./configure: line 7177: -V: command not found
configure:7175:  -qversion >&5
./configure: line 7177: -qversion: command not found
configure:7195: checking whether we are using the GNU Fortran compiler
configure:7208:  -c   conftest.F >&5
./configure: line 2242: -c: command not found
configure:7208: $? = 127
|       program main
| #ifndef __GNUC__
|        choke me
| #endif
|       end
configure:7217: result: no
configure:7223: checking whether  accepts -g
configure:7234:  -c -g  conftest.f >&5
configure:7234: $? = 127
|       program main
|       end
configure:7242: result: no
configure:7275: checking for gstat
configure:7305: result: no
configure:7275: checking for stat
configure:7291: found /usr/bin/stat
configure:7302: result: stat
configure:7317: checking for gdate
configure:7347: result: no
configure:7317: checking for date
configure:7333: found /bin/date
configure:7344: result: date
configure:7363: checking for gcc option to support OpenMP
configure:7378: gcc -o conftest -g -O2   conftest.c  >&5
conftest.c:16:2: error: unknown type name 'choke'
In file included from conftest.c:18:0:
/usr/lib/gcc/x86_64-linux-gnu/4.6/include/omp.h:34:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'typedef'
configure:7378: $? = 1
| /* confdefs.h */
| #ifndef _OPENMP
|  choke me
| #endif
| #include <omp.h>
| int main () { return omp_get_num_threads (); }
configure:7396: gcc -o conftest -g -O2 -fopenmp   conftest.c  >&5
configure:7396: $? = 0
configure:7410: result: -fopenmp
configure:7473: checking how to print strings
configure:7500: result: printf
configure:7521: checking for a sed that does not truncate output
configure:7585: result: /bin/sed
configure:7603: checking for grep that handles long lines and -e
configure:7661: result: /bin/grep
configure:7666: checking for egrep
configure:7728: result: /bin/grep -E
configure:7733: checking for fgrep
configure:7795: result: /bin/grep -F
configure:7830: checking for ld used by gcc
configure:7897: result: /usr/bin/ld
configure:7904: checking if the linker (/usr/bin/ld) is GNU ld
configure:7919: result: yes
configure:7931: checking for BSD- or MS-compatible name lister (nm)
configure:7980: result: /usr/bin/nm -B
configure:8110: checking the name lister (/usr/bin/nm -B) interface
configure:8117: gcc -c -g -O2  conftest.c >&5
configure:8120: /usr/bin/nm -B "conftest.o"
configure:8123: output
0000000000000000 B some_variable
configure:8130: result: BSD nm
configure:8134: checking the maximum length of command line arguments
configure:8259: result: 1572864
configure:8276: checking whether the shell understands some XSI constructs
configure:8286: result: yes
configure:8290: checking whether the shell understands "+="
configure:8296: result: yes
configure:8331: checking how to convert x86_64-unknown-linux-gnu file names to x86_64-unknown-linux-gnu format
configure:8371: result: func_convert_file_noop
configure:8378: checking how to convert x86_64-unknown-linux-gnu file names to toolchain format
configure:8398: result: func_convert_file_noop
configure:8405: checking for /usr/bin/ld option to reload object files
configure:8412: result: -r
configure:8486: checking for objdump
configure:8502: found /usr/bin/objdump
configure:8513: result: objdump
configure:8542: checking how to recognize dependent libraries
configure:8744: result: pass_all
configure:8829: checking for dlltool
configure:8859: result: no
configure:8886: checking how to associate runtime and link libraries
configure:8913: result: printf %s\n
configure:9037: checking for archiver @FILE support
configure:9054: gcc -c -g -O2  conftest.c >&5
configure:9054: $? = 0
configure:9057: ar cru libconftest.a @conftest.lst >&5
configure:9060: $? = 0
configure:9065: ar cru libconftest.a @conftest.lst >&5
ar: conftest.o: No such file or directory
configure:9068: $? = 1
configure:9080: result: @
configure:9138: checking for strip
configure:9154: found /usr/bin/strip
configure:9165: result: strip
configure:9237: checking for ranlib
configure:9253: found /usr/bin/ranlib
configure:9264: result: ranlib
configure:9366: checking command to parse /usr/bin/nm -B output from gcc object
configure:9485: gcc -c -g -O2  conftest.c >&5
configure:9488: $? = 0
configure:9492: /usr/bin/nm -B conftest.o \| sed -n -e 's/^.*[ ]\([ABCDGIRSTW][ABCDGIRSTW]*\)[ ][ ]*\([_A-Za-z][_A-Za-z0-9]*\)$/\1 \2 \2/p' | sed '/ __gnu_lto/d' \> conftest.nm
configure:9495: $? = 0
configure:9561: gcc -o conftest -g -O2   conftest.c conftstm.o >&5
configure:9564: $? = 0
configure:9602: result: ok
configure:9639: checking for sysroot
configure:9669: result: no
configure:9746: gcc -c -g -O2  conftest.c >&5
configure:9749: $? = 0
configure:9912: checking for mt
configure:9928: found /bin/mt
configure:9939: result: mt
configure:9962: checking if mt is a manifest tool
configure:9968: mt '-?'
configure:9976: result: no
configure:10604: checking for ANSI C header files
configure:10624: gcc -c -g -O2  conftest.c >&5
configure:10624: $? = 0
configure:10697: gcc -o conftest -g -O2   conftest.c  >&5
configure:10697: $? = 0
configure:10697: ./conftest
configure:10708: result: yes
configure:10721: checking for sys/types.h
configure:10721: gcc -c -g -O2  conftest.c >&5
configure:10721: $? = 0
configure:10721: result: yes
configure:10721: checking for sys/stat.h
configure:10721: checking for stdlib.h
configure:10721: checking for string.h
configure:10721: checking for memory.h
configure:10721: checking for strings.h
configure:10721: checking for inttypes.h
configure:10721: checking for stdint.h
configure:10721: checking for unistd.h
configure:10735: checking for dlfcn.h
configure:10735: gcc -c -g -O2  conftest.c >&5
configure:10735: $? = 0
configure:10735: result: yes
configure:11233: checking for objdir
configure:11248: result: .libs
configure:11519: checking if gcc supports -fno-rtti -fno-exceptions
configure:11537: gcc -c -g -O2  -fno-rtti -fno-exceptions conftest.c >&5
cc1: warning: command line option '-fno-rtti' is valid for C++/ObjC++ but not for C [enabled by default]
configure:11541: $? = 0
configure:11554: result: no
configure:11864: checking for gcc option to produce PIC
configure:11871: result: -fPIC -DPIC
configure:11879: checking if gcc PIC flag -fPIC -DPIC works
configure:11897: gcc -c -g -O2  -fPIC -DPIC -DPIC conftest.c >&5
configure:11901: $? = 0
configure:11914: result: yes
configure:11943: checking if gcc static flag -static works
configure:11971: result: yes
configure:11986: checking if gcc supports -c -o file.o
configure:12007: gcc -c -g -O2  -o out/conftest2.o conftest.c >&5
configure:12011: $? = 0
configure:12033: result: yes
configure:12041: checking if gcc supports -c -o file.o
configure:12088: result: yes
configure:12121: checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries
configure:13279: result: yes
configure:13316: checking whether -lc should be explicitly linked in
configure:13324: gcc -c -g -O2  conftest.c >&5
configure:13327: $? = 0
configure:13342: gcc -shared  -fPIC -DPIC conftest.o  -v -Wl,-soname -Wl,conftest -o conftest 2\>\&1 \| /bin/grep  -lc  \>/dev/null 2\>\&1
configure:13345: $? = 0
configure:13359: result: no
configure:13524: checking dynamic linker characteristics
configure:14038: gcc -o conftest -g -O2   -Wl,-rpath -Wl,/foo conftest.c  >&5
configure:14038: $? = 0
configure:14260: result: GNU/Linux ld.so
configure:14367: checking how to hardcode library paths into programs
configure:14392: result: immediate
configure:14932: checking whether stripping libraries is possible
configure:14937: result: yes
configure:14972: checking if libtool supports shared libraries
configure:14974: result: yes
configure:14977: checking whether to build shared libraries
configure:14998: result: yes
configure:15001: checking whether to build static libraries
configure:15005: result: yes
configure:15028: checking how to run the C++ preprocessor
configure:15055: g++ -E  conftest.cpp
configure:15055: $? = 0
configure:15069: g++ -E  conftest.cpp
conftest.cpp:26:28: fatal error: ac_nonexistent.h: No such file or directory
configure:15069: $? = 1
| /* confdefs.h */
| #define STDC_HEADERS 1
| #define HAVE_SYS_TYPES_H 1
| #define HAVE_SYS_STAT_H 1
| #define HAVE_STDLIB_H 1
| #define HAVE_STRING_H 1
| #define HAVE_MEMORY_H 1
| #define HAVE_STRINGS_H 1
| #define HAVE_INTTYPES_H 1
| #define HAVE_STDINT_H 1
| #define HAVE_UNISTD_H 1
| #define HAVE_DLFCN_H 1
| #define LT_OBJDIR ".libs/"
configure:15094: result: g++ -E
configure:15114: g++ -E  conftest.cpp
configure:15114: $? = 0
configure:15128: g++ -E  conftest.cpp
configure:15128: $? = 1
| /* confdefs.h */
configure:15298: checking for ld used by g++
configure:15365: result: /usr/bin/ld -m elf_x86_64
configure:15372: checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld
configure:15387: result: yes
configure:15442: checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries
configure:16446: result: yes
configure:16481: g++ -c -g -O2  conftest.cpp >&5
configure:16484: $? = 0
configure:17004: checking for g++ option to produce PIC
configure:17011: result: -fPIC -DPIC
configure:17019: checking if g++ PIC flag -fPIC -DPIC works
configure:17037: g++ -c -g -O2  -fPIC -DPIC -DPIC conftest.cpp >&5
configure:17041: $? = 0
configure:17054: result: yes
configure:17077: checking if g++ static flag -static works
configure:17105: result: yes
configure:17117: checking if g++ supports -c -o file.o
configure:17138: g++ -c -g -O2  -o out/conftest2.o conftest.cpp >&5
configure:17142: $? = 0
configure:17164: result: yes
configure:17169: checking if g++ supports -c -o file.o
configure:17216: result: yes
configure:17246: checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries
configure:17280: result: yes
configure:17423: checking dynamic linker characteristics
configure:18093: result: GNU/Linux ld.so
configure:18146: checking how to hardcode library paths into programs
configure:18171: result: immediate
configure:23802: checking whether ln -s works
configure:23806: result: yes
configure:23814: checking for ANSI C header files
configure:23918: result: yes
configure:23927: checking for C/C++ restrict keyword
configure:23952: gcc -c -g -O2  conftest.c >&5
configure:23952: $? = 0
configure:23960: result: __restrict
configure:23979: checking for bash
configure:24006: result: /bin/bash
configure:24021: checking for svn
configure:24039: found /usr/bin/svn
configure:24051: result: /usr/bin/svn
configure:24061: checking for svnversion
configure:24079: found /usr/bin/svnversion
configure:24091: result: /usr/bin/svnversion
configure:24178: checking for lib
configure:24211: result: no
configure:24279: checking size of void *
configure:24284: gcc -o conftest -g -O2   conftest.c  >&5
configure:24284: $? = 0
configure:24284: ./conftest
configure:24298: result: 8
configure:24364: checking for struct timespec
configure:24364: gcc -c -g -O2  conftest.c >&5
configure:24364: $? = 0
conftest.c: In function 'main':
conftest.c:46:30: error: expected expression before ')' token
configure:24364: $? = 1
| /* confdefs.h */
| #define restrict __restrict
| #define STARPU_MIC_USE_RMA 1
| #define STARPU_LINUX_SYS 1
| #define SIZEOF_VOID_P 8
| #define STARPU_BUILD_DIR "/home/wafa/StarPU"
| #define STARPU_SRC_DIR "/home/wafa/StarPU/."
| #include <sys/types.h>
| #include <sys/stat.h>
| #ifdef HAVE_UNISTD_H
| #include <unistd.h>
| #endif
| #include <time.h>
| #include <pthread.h>
| int
| main ()
| if (sizeof ((struct timespec)))
| 	    return 0;
|   return 0;
configure:24364: result: yes
configure:24383: checking for unistd.h
configure:24383: result: yes
configure:24422: checking for pthread_create in -lpthread
configure:24447: gcc -o conftest -g -O2   conftest.c -lpthread   >&5
configure:24447: $? = 0
configure:24456: result: yes
configure:24469: checking for library containing sqrt
configure:24500: gcc -o conftest -g -O2   conftest.c -lpthread  >&5
conftest.c:44:6: warning: conflicting types for built-in function 'sqrt' [enabled by default]
/tmp/cctIVv3z.o: In function `main':
/home/wafa/StarPU/conftest.c:48: undefined reference to `sqrt'
collect2: ld returned 1 exit status
configure:24500: $? = 1
| /* confdefs.h */
| #define STARPU_HAVE_STRUCT_TIMESPEC /**/
| #define STARPU_HAVE_UNISTD_H 1
| #define HAVE_LIBPTHREAD 1
| /* Override any GCC internal prototype to avoid an error.
|    Use char because int might match the return type of a GCC
|    builtin and then its argument prototype would still apply.  */
| #ifdef __cplusplus
| extern "C"
| #endif
| char sqrt ();
| int
| main ()
| return sqrt ();
|   return 0;
configure:24500: gcc -o conftest -g -O2   conftest.c -lm  -lpthread  >&5
configure:24500: $? = 0
configure:24517: result: -lm
configure:24527: checking for main in -lws2_32
configure:24546: gcc -o conftest -g -O2   conftest.c -lws2_32  -lm -lpthread  >&5
/usr/bin/ld: cannot find -lws2_32
configure:24546: $? = 1
| /* confdefs.h */
| int
| main ()
| return main ();
|   return 0;
configure:24555: result: no
configure:24569: checking for sysconf
configure:24569: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:24569: $? = 0
configure:24569: result: yes
configure:24579: checking for pthread_spin_lock
configure:24579: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:24579: $? = 0
configure:24579: result: yes
configure:24595: checking for pthread_barrier_init
configure:24595: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:24595: $? = 0
configure:24595: result: yes
configure:24611: checking for pthread_setaffinity_np
configure:24611: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:24611: $? = 0
configure:24611: result: yes
configure:24624: checking for posix_memalign
configure:24624: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:24624: $? = 0
configure:24624: result: yes
configure:24637: checking for memalign
configure:24637: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:24637: $? = 0
configure:24637: result: yes
configure:24650: checking for drand48
configure:24650: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:24650: $? = 0
configure:24650: result: yes
configure:24657: checking for erand48_r
configure:24657: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:24657: $? = 0
configure:24657: result: yes
configure:24684: checking for strerror_r
configure:24684: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:24684: $? = 0
configure:24684: result: yes
configure:24693: checking for setenv
configure:24693: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:24693: $? = 0
configure:24693: result: yes
configure:24702: checking for unsetenv
configure:24702: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:24702: $? = 0
configure:24702: result: yes
configure:24711: checking for nearbyintf
configure:24711: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
conftest.c:74:6: warning: conflicting types for built-in function 'nearbyintf' [enabled by default]
configure:24711: $? = 0
configure:24711: result: yes
configure:24720: checking for rintf
configure:24720: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
conftest.c:75:6: warning: conflicting types for built-in function 'rintf' [enabled by default]
configure:24720: $? = 0
configure:24720: result: yes
configure:24796: checking malloc.h usability
configure:24796: gcc -c -g -O2  conftest.c >&5
configure:24796: $? = 0
configure:24796: result: yes
configure:24796: checking malloc.h presence
configure:24796: gcc -E  conftest.c
configure:24796: checking for malloc.h
configure:24819: checking valgrind/valgrind.h usability
configure:24819: gcc -c -g -O2  conftest.c >&5
conftest.c:88:31: fatal error: valgrind/valgrind.h: No such file or directory
configure:24819: $? = 1
| /* confdefs.h */
| #define HAVE_SYSCONF 1
| #define HAVE_PTHREAD_SPIN_LOCK /**/
| #define STARPU_HAVE_PTHREAD_SPIN_LOCK /**/
| #define STARPU_HAVE_PTHREAD_BARRIER /**/
| #define HAVE_PTHREAD_SETAFFINITY_NP 1
| #define HAVE_POSIX_MEMALIGN 1
| #define STARPU_HAVE_POSIX_MEMALIGN 1
| #define HAVE_MEMALIGN 1
| #define STARPU_HAVE_MEMALIGN 1
| #define STARPU_USE_DRAND48 1
| #define STARPU_USE_ERAND48_R 1
| #define STARPU_HAVE_STRERROR_R 1
| #define STARPU_HAVE_SETENV 1
| #define STARPU_HAVE_UNSETENV 1
| #define STARPU_HAVE_NEARBYINTF 1
| #define STARPU_HAVE_RINTF 1
| #define HAVE_MALLOC_H 1
| #define STARPU_HAVE_MALLOC_H 1
| #include <stdio.h>
| #ifdef HAVE_SYS_TYPES_H
| # include <sys/types.h>
| #endif
| #ifdef HAVE_SYS_STAT_H
| # include <sys/stat.h>
| #endif
| #ifdef STDC_HEADERS
| # include <stdlib.h>
| # include <stddef.h>
| #else
| # ifdef HAVE_STDLIB_H
| # endif
| #endif
| #ifdef HAVE_STRING_H
| # if !defined STDC_HEADERS && defined HAVE_MEMORY_H
| #  include <memory.h>
| # endif
| # include <string.h>
| #endif
| #ifdef HAVE_STRINGS_H
| # include <strings.h>
| #endif
| #ifdef HAVE_INTTYPES_H
| # include <inttypes.h>
| #endif
| #ifdef HAVE_STDINT_H
| # include <stdint.h>
| #endif
| # include <unistd.h>
| #endif
| #include <valgrind/valgrind.h>
configure:24819: result: no
configure:24819: checking valgrind/valgrind.h presence
configure:24819: gcc -E  conftest.c
conftest.c:55:31: fatal error: valgrind/valgrind.h: No such file or directory
| /* confdefs.h */
configure:24819: checking for valgrind/valgrind.h
configure:24833: checking valgrind/memcheck.h usability
configure:24833: gcc -c -g -O2  conftest.c >&5
conftest.c:88:31: fatal error: valgrind/memcheck.h: No such file or directory
configure:24833: $? = 1
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <valgrind/memcheck.h>
configure:24833: result: no
configure:24833: checking valgrind/memcheck.h presence
configure:24833: gcc -E  conftest.c
conftest.c:55:31: fatal error: valgrind/memcheck.h: No such file or directory
| /* confdefs.h */
configure:24833: checking for valgrind/memcheck.h
configure:24847: checking valgrind/helgrind.h usability
configure:24847: gcc -c -g -O2  conftest.c >&5
conftest.c:88:31: fatal error: valgrind/helgrind.h: No such file or directory
configure:24847: $? = 1
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <valgrind/helgrind.h>
configure:24847: result: no
configure:24847: checking valgrind/helgrind.h presence
configure:24847: gcc -E  conftest.c
conftest.c:55:31: fatal error: valgrind/helgrind.h: No such file or directory
| /* confdefs.h */
configure:24847: checking for valgrind/helgrind.h
configure:24866: checking for sched_yield
configure:24866: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:24866: $? = 0
configure:24866: result: yes
configure:24876: checking aio.h usability
configure:24876: gcc -c -g -O2  conftest.c >&5
configure:24876: $? = 0
configure:24876: result: yes
configure:24876: checking aio.h presence
configure:24876: gcc -E  conftest.c
configure:24876: checking for aio.h
configure:24889: checking for mkostemp
configure:24889: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:24889: $? = 0
configure:24889: result: yes
configure:24902: checking for pread
configure:24902: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:24902: $? = 0
configure:24902: result: yes
configure:24902: checking for pwrite
configure:24914: checking whether the target supports __sync_val_compare_and_swap
configure:24931: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:24931: $? = 0
configure:24939: result: yes
configure:24949: checking whether the target supports __sync_bool_compare_and_swap
configure:24966: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:24966: $? = 0
configure:24974: result: yes
configure:24984: checking whether the target supports __sync_fetch_and_add
configure:25001: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:25001: $? = 0
configure:25009: result: yes
configure:25019: checking whether the target supports __sync_fetch_and_or
configure:25036: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:25036: $? = 0
configure:25044: result: yes
configure:25054: checking whether the target supports __sync_lock_test_and_set
configure:25071: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:25071: $? = 0
configure:25079: result: yes
configure:25089: checking whether the target supports __sync_synchronize
configure:25106: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:25106: $? = 0
configure:25114: result: yes
configure:25126: checking for library containing set_mempolicy
configure:25157: gcc -o conftest -g -O2  -D_GNU_SOURCE   conftest.c  >&5
/tmp/cc6gMIxE.o: In function `main':
/home/wafa/StarPU/conftest.c:77: undefined reference to `set_mempolicy'
configure:25157: $? = 1
| /* confdefs.h */
| #define STARPU_HAVE_SCHED_YIELD 1
| #define HAVE_AIO_H 1
| #define HAVE_MKOSTEMP 1
| #define HAVE_PREAD 1
| #define HAVE_PWRITE 1
| #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1
| #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1
| #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1
| #define STARPU_HAVE_SYNC_FETCH_AND_OR 1
| #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1
| #define STARPU_HAVE_SYNC_SYNCHRONIZE 1
| #ifdef __cplusplus
| extern "C"
| #endif
| char set_mempolicy ();
| int
| main ()
| return set_mempolicy ();
|   return 0;
configure:25157: gcc -o conftest -g -O2  -D_GNU_SOURCE   conftest.c -lnuma   >&5
/usr/bin/ld: cannot find -lnuma
| /* confdefs.h */
| #ifdef __cplusplus
| extern "C"
| #endif
| int
| main ()
|   return 0;
configure:25174: result: no
configure:25188: checking whether libnuma is available
configure:25190: result: no
configure:25203: checking maximum number of sched_ctxs
configure:25212: result: 10
configure:25290: checking maximum number of CPUs
configure:25299: result: 64
configure:25307: checking whether CPUs should be used
configure:25316: result: yes
configure:25341: checking maximum number of CUDA devices
configure:25350: result: 4
configure:25429: checking whether CUDA is available
configure:25432: result:
configure:25446: checking cuda.h usability
configure:25446: gcc -c -g -O2  -D_GNU_SOURCE  conftest.c >&5
conftest.c:103:18: fatal error: cuda.h: No such file or directory
configure:25446: $? = 1
| /* confdefs.h */
| #define STARPU_NMAX_SCHED_CTXS 10
| #define STARPU_MAXCPUS 64
| #define STARPU_USE_CPU 1
| #define STARPU_MAXCUDADEVS 4
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <cuda.h>
configure:25446: result: no
configure:25446: checking cuda.h presence
configure:25446: gcc -E  -D_GNU_SOURCE  conftest.c
conftest.c:70:18: fatal error: cuda.h: No such file or directory
| /* confdefs.h */
| #include <cuda.h>
configure:25446: checking for cuda.h
configure:25980: checking whether CUDA is available
configure:25983: result:
configure:25997: checking cuda.h usability
configure:25997: gcc -c -g -O2  -D_GNU_SOURCE  conftest.c >&5
configure:25997: $? = 1
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <cuda.h>
configure:25997: result: no
configure:25997: checking cuda.h presence
configure:25997: gcc -E  -D_GNU_SOURCE  conftest.c
| /* confdefs.h */
| #include <cuda.h>
configure:25997: checking for cuda.h
configure:26531: checking whether CUDA is available in /usr/local/cuda
configure:26537: result:
configure:26551: checking cuda.h usability
configure:26551: gcc -c -g -O2  -D_GNU_SOURCE  -I/usr/local/cuda/include conftest.c >&5
configure:26551: $? = 1
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <cuda.h>
configure:26551: result: no
configure:26551: checking cuda.h presence
configure:26551: gcc -E  -D_GNU_SOURCE  -I/usr/local/cuda/include conftest.c
| /* confdefs.h */
| #include <cuda.h>
configure:26551: checking for cuda.h
configure:26531: checking whether CUDA is available in /c/cuda
configure:26551: gcc -c -g -O2  -D_GNU_SOURCE  -I/c/cuda/include conftest.c >&5
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <cuda.h>
configure:26551: gcc -E  -D_GNU_SOURCE  -I/c/cuda/include conftest.c
| /* confdefs.h */
| #include <cuda.h>
configure:26531: checking whether CUDA is available in /cygdrive/c/cuda
configure:26551: gcc -c -g -O2  -D_GNU_SOURCE  -I/cygdrive/c/cuda/include conftest.c >&5
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <cuda.h>
configure:26551: gcc -E  -D_GNU_SOURCE  -I/cygdrive/c/cuda/include conftest.c
| /* confdefs.h */
| #include <cuda.h>
configure:26531: checking whether CUDA is available in /opt/cuda
configure:26551: gcc -c -g -O2  -D_GNU_SOURCE  -I/opt/cuda/include conftest.c >&5
configure:26551: $? = 0
configure:26551: result: yes
configure:26551: gcc -E  -D_GNU_SOURCE  -I/opt/cuda/include conftest.c
configure:26705: checking whether CUDA is available with: -L/opt/cuda/lib64
configure:26707: result:
configure:26710: checking for main in -lcuda
configure:26729: gcc -o conftest -g -O2  -D_GNU_SOURCE  -I/opt/cuda/include  -L/opt/cuda/lib64 conftest.c -lcuda  -lm -lpthread  >&5
configure:26729: $? = 0
configure:26738: result: yes
configure:26749: checking for main in -lcudart
configure:26768: gcc -o conftest -g -O2  -D_GNU_SOURCE  -I/opt/cuda/include  -L/opt/cuda/lib64 conftest.c -lcudart  -lm -lpthread  >&5
configure:26768: $? = 0
configure:26777: result: yes
configure:26791: checking for main in -lcublas
configure:26810: gcc -o conftest -g -O2  -D_GNU_SOURCE  -I/opt/cuda/include  -L/opt/cuda/lib64 -lcudart conftest.c -lcublas  -lm -lpthread  >&5
configure:26810: $? = 0
configure:26819: result: yes
configure:26987: checking for nvcc
configure:27019: result: not-found
configure:27029: WARNING: 'nvcc' not found, disabling CUDA
configure:26531: checking whether CUDA is available in /..
configure:26551: gcc -c -g -O2  -D_GNU_SOURCE  -I/opt/cuda/include -I/../include conftest.c >&5
configure:26551: gcc -E  -D_GNU_SOURCE  -I/opt/cuda/include -I/../include conftest.c
configure:26705: checking whether CUDA is available with: -L/../lib64
configure:26729: gcc -o conftest -g -O2  -D_GNU_SOURCE  -I/opt/cuda/include -I/../include  -L/../lib64 conftest.c -lcuda  -lm -lpthread  >&5
configure:26768: gcc -o conftest -g -O2  -D_GNU_SOURCE  -I/opt/cuda/include -I/../include  -L/../lib64 conftest.c -lcudart  -lm -lpthread  >&5
/usr/bin/ld: cannot find -lcudart
configure:26768: $? = 1
| /* confdefs.h */
| int
| main ()
| return main ();
|   return 0;
configure:26777: result: no
configure:26729: gcc -o conftest -g -O2  -D_GNU_SOURCE  -I/opt/cuda/include -I/../include  -L/../lib conftest.c -lcuda  -lm -lpthread  >&5
configure:26768: gcc -o conftest -g -O2  -D_GNU_SOURCE  -I/opt/cuda/include -I/../include  -L/../lib conftest.c -lcudart  -lm -lpthread  >&5
| /* confdefs.h */
| int
| main ()
| return main ();
|   return 0;
configure:26705: checking whether CUDA is available with: -L/../lib/x64
configure:26729: gcc -o conftest -g -O2  -D_GNU_SOURCE  -I/opt/cuda/include -I/../include  -L/../lib/x64 conftest.c -lcuda  -lm -lpthread  >&5
configure:26768: gcc -o conftest -g -O2  -D_GNU_SOURCE  -I/opt/cuda/include -I/../include  -L/../lib/x64 conftest.c -lcudart  -lm -lpthread  >&5
| /* confdefs.h */
| int
| main ()
| return main ();
|   return 0;
configure:26705: checking whether CUDA is available with: -L/../lib/Win32
configure:26729: gcc -o conftest -g -O2  -D_GNU_SOURCE  -I/opt/cuda/include -I/../include  -L/../lib/Win32 conftest.c -lcuda  -lm -lpthread  >&5
configure:26768: gcc -o conftest -g -O2  -D_GNU_SOURCE  -I/opt/cuda/include -I/../include  -L/../lib/Win32 conftest.c -lcudart  -lm -lpthread  >&5
| /* confdefs.h */
| int
| main ()
| return main ();
|   return 0;
| /* confdefs.h */
| int
| main ()
| return main ();
|   return 0;
| /* confdefs.h */
| int
| main ()
| return main ();
|   return 0;
| /* confdefs.h */
| int
| main ()
| return main ();
|   return 0;
| /* confdefs.h */
| int
| main ()
| return main ();
|   return 0;
| /* confdefs.h */
| int
| main ()
| return main ();
|   return 0;
| /* confdefs.h */
| int
| main ()
| return main ();
|   return 0;
| /* confdefs.h */
| int
| main ()
| return main ();
|   return 0;
| /* confdefs.h */
| int
| main ()
| return main ();
|   return 0;
| /* confdefs.h */
| int
| main ()
| return main ();
|   return 0;
| /* confdefs.h */
| int
| main ()
| return main ();
|   return 0;
| /* confdefs.h */
| int
| main ()
| return main ();
|   return 0;
| /* confdefs.h */
| int
| main ()
| return main ();
|   return 0;
configure:27073: checking whether CUDA is working
configure:27137: result: no
configure:27148: checking whether CUDA should be used
configure:27150: result: no
configure:27249: checking for pkg-config
configure:27267: found /usr/bin/pkg-config
configure:27279: result: /usr/bin/pkg-config
configure:27304: checking pkg-config is at least version 0.9.0
configure:27307: result: yes
configure:27406: checking whether MAGMA should be used
configure:27408: result: no
configure:27412: checking for cufftDoubleComplex
configure:27412: gcc -c -g -O2  -D_GNU_SOURCE  -I/opt/cuda/include conftest.c >&5
configure:27412: $? = 0
conftest.c:75:33: error: expected expression before ')' token
configure:27412: $? = 1
| /* confdefs.h */
| #include <cufft.h>
| int
| main ()
| if (sizeof ((cufftDoubleComplex)))
| 	    return 0;
|   return 0;
configure:27412: result: yes
configure:27478: checking whether CURAND is available
configure:27480: result: no
configure:27536: checking maximum number of OpenCL devices
configure:27545: result: 8
configure:27658: checking whether OpenCL is available
configure:27661: result:
configure:27674: checking CL/cl.h usability
configure:27674: gcc -c -g -O2  -D_GNU_SOURCE  -I/opt/cuda/include conftest.c >&5
configure:27674: $? = 0
configure:27674: result: yes
configure:27674: checking CL/cl.h presence
configure:27674: gcc -E  -D_GNU_SOURCE  -I/opt/cuda/include conftest.c
configure:27674: checking for CL/cl.h
configure:27726: checking whether OpenCL is available in no
configure:27728: result:
configure:27730: checking for main in -lOpenCL
configure:27749: gcc -o conftest -g -O2  -D_GNU_SOURCE  -I/opt/cuda/include  conftest.c -lOpenCL  -lm -lpthread  >&5
configure:27749: $? = 0
configure:27758: result: yes
configure:27820: checking for main in -lOpenCL
configure:27839: gcc -o conftest -g -O2  -D_GNU_SOURCE  -I/opt/cuda/include  conftest.c -lOpenCL  -lm -lpthread  >&5
configure:27839: $? = 0
configure:27848: result: yes
configure:28153: checking for clEnqueueMarkerWithWaitList
configure:28153: gcc -o conftest -g -O2  -D_GNU_SOURCE  -I/opt/cuda/include  conftest.c -lm -lpthread   -lOpenCL >&5
configure:28153: $? = 0
configure:28153: result: yes
configure:28165: checking whether OpenCL should be used
configure:28167: result: yes
configure:28195: checking whether asynchronous copy should be disabled
configure:28208: result: no
configure:28216: checking whether asynchronous CUDA copy should be disabled
configure:28229: result: no
configure:28237: checking whether asynchronous OpenCL copy should be disabled
configure:28250: result: no
configure:28258: checking whether asynchronous MIC copy should be disabled
configure:28271: result: no
configure:28519: checking whether SimGrid is enabled
configure:28521: result: no
configure:28524: checking whether blocking drivers should be enabled
configure:28533: result: no
configure:28548: checking maximum number of MIC devices
configure:28557: result: 4
configure:28566: checking maximum number of MIC threads
configure:28575: result:
configure:29148: checking RCCE.h usability
configure:29148: gcc -c -g -O2  -D_GNU_SOURCE  -I/opt/cuda/include  conftest.c >&5
conftest.c:111:18: fatal error: RCCE.h: No such file or directory
configure:29148: $? = 1
| /* confdefs.h */
| #define STARPU_HAVE_CUFFTDOUBLECOMPLEX 1
| #define STARPU_MAXOPENCLDEVS 8
| #define HAVE_CLENQUEUEMARKERWITHWAITLIST 1
| #define STARPU_USE_OPENCL 1
| #define STARPU_NON_BLOCKING_DRIVERS 1
| #define STARPU_MAXMICDEVS 4
| #define STARPU_MAXMICCORES 120
| #define STARPU_MAXSCCDEVS 47
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <RCCE.h>
configure:29148: result: no
configure:29148: checking RCCE.h presence
configure:29148: gcc -E  -D_GNU_SOURCE  -I/opt/cuda/include  conftest.c
conftest.c:78:18: fatal error: RCCE.h: No such file or directory
| /* confdefs.h */
| #include <RCCE.h>
configure:29148: checking for RCCE.h
configure:29164: checking for RCCE_init in -lRCCE_bigflags_nongory_nopwrmgmt
configure:29189: gcc -o conftest -g -O2  -D_GNU_SOURCE  -I/opt/cuda/include    conftest.c -lRCCE_bigflags_nongory_nopwrmgmt  -lm -lpthread  >&5
/usr/bin/ld: cannot find -lRCCE_bigflags_nongory_nopwrmgmt
configure:29189: $? = 1
| /* confdefs.h */
| #ifdef __cplusplus
| extern "C"
| #endif
| char RCCE_init ();
| int
| main ()
| return RCCE_init ();
|   return 0;
configure:29198: result: no
configure:29246: checking whether RCCE should be used
configure:29248: result: no
configure:29287: checking Maximum number of message-passing kernels
configure:29296: result: 10
configure:29312: checking whether debug mode should be enabled
configure:29321: result: no
configure:29353: checking whether extra checks should be performed
configure:29362: result: no
configure:29370: checking whether debug messages should be displayed
configure:29379: result: no
configure:29395: checking whether coverage testing should be enabled
configure:29404: result: no
configure:29423: checking whether FxT traces should be generated
configure:29454: result: no
configure:29813: checking whether additional locking systems FxT traces should be enabled
configure:29822: result: no
configure:29830: checking whether performance debugging should be enabled
configure:29839: result: no
configure:29851: checking whether performance model debugging should be enabled
configure:29860: result: no
configure:29868: checking whether memory stats should be displayed
configure:29877: result: no
configure:29887: checking glpk.h usability
configure:29887: gcc -c -O3 -g -O2 -gdwarf-2 -g3   -D_GNU_SOURCE  -I/opt/cuda/include conftest.c >&5
conftest.c:112:18: fatal error: glpk.h: No such file or directory
configure:29887: $? = 1
| /* confdefs.h */
| #define STARPU_MAXMPKERNELS 10
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <glpk.h>
configure:29887: result: no
configure:29887: checking glpk.h presence
configure:29887: gcc -E  -D_GNU_SOURCE  -I/opt/cuda/include conftest.c
conftest.c:79:18: fatal error: glpk.h: No such file or directory
| /* confdefs.h */
| #include <glpk.h>
configure:29887: checking for glpk.h
configure:29901: checking for main in -lglpk
configure:29920: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3   -D_GNU_SOURCE  -I/opt/cuda/include  -gdwarf-2 -g3  conftest.c -lglpk   >&5
/usr/bin/ld: cannot find -lglpk
configure:29920: $? = 1
| /* confdefs.h */
| int
| main ()
| return main ();
|   return 0;
configure:29929: result: no
configure:29947: checking Ayudame.h usability
configure:29947: gcc -c -O3 -g -O2 -gdwarf-2 -g3   -D_GNU_SOURCE  -I/opt/cuda/include conftest.c >&5
conftest.c:112:21: fatal error: Ayudame.h: No such file or directory
configure:29947: $? = 1
| /* confdefs.h */
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <Ayudame.h>
configure:29947: result: no
configure:29947: checking Ayudame.h presence
configure:29947: gcc -E  -D_GNU_SOURCE  -I/opt/cuda/include conftest.c
conftest.c:79:21: fatal error: Ayudame.h: No such file or directory
| /* confdefs.h */
configure:29947: checking for Ayudame.h
configure:29964: checking how many buffers can be manipulated per task
configure:29973: result: 8
configure:29981: checking maximum number of nodes to use
configure:30030: checking maximum number of memory nodes
configure:30032: result: 16
configure:30041: checking whether allocation cache should be used
configure:30050: result: yes
configure:30084: checking using explicit performance model location
configure:30086: result: no
configure:30089: checking performance models location
configure:30091: result: $HOME/.starpu/sampling/
configure:30095: checking for clock_gettime in -lrt
configure:30120: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3   -D_GNU_SOURCE  -I/opt/cuda/include  -gdwarf-2 -g3  conftest.c -lrt  -lm -lpthread  >&5
configure:30120: $? = 0
configure:30129: result: yes
configure:30142: checking for clock_gettime
configure:30142: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3   -D_GNU_SOURCE  -I/opt/cuda/include  -gdwarf-2 -g3  conftest.c -lrt -lm -lpthread  >&5
configure:30142: $? = 0
configure:30142: result: yes
configure:30172: checking Maximum number of workers
configure:30174: result: 80
configure:30184: checking Maximum number of workers combinations
configure:30186: result: 64
configure:30197: checking maximum number of implementations
configure:30206: result: 4
configure:30223: checking leveldb/db.h usability
configure:30223: g++ -c -O3 -g -O2 -gdwarf-2 -g3   -D_GNU_SOURCE  -I/opt/cuda/include conftest.cpp >&5
conftest.cpp:120:24: fatal error: leveldb/db.h: No such file or directory
 #include <leveldb/db.h>
configure:30223: $? = 1
| /* confdefs.h */
| #define STARPU_NMAXBUFS 8
| #define STARPU_MAXNODES 16
| #define STARPU_USE_ALLOCATION_CACHE 1
| #define HAVE_LIBRT 1
| #define HAVE_CLOCK_GETTIME 1
| #define STARPU_NMAXWORKERS 80
| #define STARPU_NMAX_COMBINEDWORKERS 64
| #define STARPU_MAXIMPLEMENTATIONS 4
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
configure:30223: result: no
configure:30223: checking leveldb/db.h presence
configure:30223: g++ -E  -D_GNU_SOURCE  -I/opt/cuda/include conftest.cpp
conftest.cpp:87:24: fatal error: leveldb/db.h: No such file or directory
| /* confdefs.h */
configure:30223: checking for leveldb/db.h
configure:30237: checking for main in -lleveldb
configure:30256: g++ -o conftest -O3 -g -O2 -gdwarf-2 -g3   -D_GNU_SOURCE  -I/opt/cuda/include  -gdwarf-2 -g3  conftest.cpp -lleveldb   >&5
/usr/bin/ld: cannot find -lleveldb
collect2: error: ld returned 1 exit status
configure:30256: $? = 1
| /* confdefs.h */
| int
| main ()
| return main ();
|   return 0;
configure:30265: result: no
configure:30297: checking calibration heuristic of history-based StarPU calibrator
configure:30306: result: 50
configure:30341: checking for mpicc
configure:30373: result: no
configure:30388: result: The mpicc compiler 'no' does not have the execute permission
configure:30456: checking mpicc path
configure:30458: result: no
configure:30510: checking for mpiexec
configure:30542: result: no
configure:30554: checking whether mpiexec is available
configure:30556: result: no
configure:30562: result: The mpiexec script is not valid
configure:30585: checking whether the StarPU MPI library should be generated
configure:30587: result: no
configure:30635: checking for StarPU-Top
configure:30644: checking for qmake-qt4
configure:30677: result: no
configure:30662: found /usr/bin/qmake
configure:30674: result: /usr/bin/qmake
configure:30774: checking whether compiler support -Wall
configure:30796: gcc -o conftest -Wall  -D_GNU_SOURCE  -I/opt/cuda/include  -gdwarf-2 -g3  conftest.c -lrt -lm -lpthread  >&5
conftest.c:94:18: warning: unused variable 'hello' [-Wunused-variable]
configure:30796: $? = 0
configure:30799: result: yes
configure:30818: checking whether compiler support -Werror=implicit
configure:30840: gcc -o conftest -Werror=implicit  -D_GNU_SOURCE  -I/opt/cuda/include  -gdwarf-2 -g3  conftest.c -lrt -lm -lpthread  >&5
configure:30840: $? = 0
configure:30843: result: yes
configure:30862: checking whether compiler support -Werror=implicit-function-declaration
configure:30884: gcc -o conftest -Werror=implicit-function-declaration  -D_GNU_SOURCE  -I/opt/cuda/include  -gdwarf-2 -g3  conftest.c -lrt -lm -lpthread  >&5
configure:30884: $? = 0
configure:30887: result: yes
configure:31188: checking whether GCC supports plug-ins
configure:31243: gcc -c -O3 -g -O2 -gdwarf-2 -g3  -Iplugin/include conftest.c >&5
conftest.c:88:24: fatal error: gcc-plugin.h: No such file or directory
configure:31243: $? = 1
| /* confdefs.h */
| #define STARPU_HISTORYMAXERROR 50
| #include <gcc-plugin.h>
| 	      #include <tree.h>
| 	      #include <gimple.h>
| 	      #if defined __INTEL_COMPILER || defined __ICC
| 	      Beware, this compiler is a fake.  Don't use it.
| 	      #endif
| 	      tree fndecl; gimple call;
| int
| main ()
| /* Clang 3.1 doesn't support nested functions, so try to
| 	         discriminate it this way.  */
| 	      tree foo (void)
| 	        return lookup_name (get_identifier ("puts"));
| 	      fndecl = foo ();
| 	      call = gimple_build_call (fndecl, 0);
|   return 0;
configure:31259: result: no
configure:31543: WARNING: GCC plug-ins not supported; StarPU's GCC plug-in will not be built
configure:31681: checking for OpenMP runtime support
configure:31698: result: no
configure:31728: checking for SOCL
configure:31743: result: yes
configure:31765: checking for clGetExtensionFunctionAddressForPlatform
configure:31765: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3  -fopenmp  -D_GNU_SOURCE  -I/opt/cuda/include  -gdwarf-2 -g3  conftest.c -lrt -lm -lpthread  >&5
/tmp/ccNPWdOu.o: In function `main':
/home/wafa/StarPU/conftest.c:122: undefined reference to `clGetExtensionFunctionAddressForPlatform'
configure:31765: $? = 1
| /* confdefs.h */
| /* Define clGetExtensionFunctionAddressForPlatform to an innocuous variant, in case <limits.h> declares clGetExtensionFunctionAddressForPlatform.
|    For example, HP-UX 11i <limits.h> declares gettimeofday.  */
| #define clGetExtensionFunctionAddressForPlatform innocuous_clGetExtensionFunctionAddressForPlatform
| /* System header to define __stub macros and hopefully few prototypes,
|     which can conflict with char clGetExtensionFunctionAddressForPlatform (); below.
|     Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
|     <limits.h> exists even on freestanding compilers.  */
| #ifdef __STDC__
| # include <limits.h>
| #else
| # include <assert.h>
| #endif
| #undef clGetExtensionFunctionAddressForPlatform
| #ifdef __cplusplus
| extern "C"
| #endif
| /* The GNU C library defines this for functions which it implements
|     to always fail with ENOSYS.  Some functions are actually named
|     something starting with __ and the normal name is an alias.  */
| #if defined __stub_clGetExtensionFunctionAddressForPlatform || defined __stub___clGetExtensionFunctionAddressForPlatform
| choke me
| #endif
| int
| main ()
| return clGetExtensionFunctionAddressForPlatform ();
|   return 0;
configure:31765: result: no
configure:31792: checking for gdb
configure:31810: found /usr/bin/gdb
configure:31823: result: /usr/bin/gdb
configure:32051: checking whether OpenGL rendering is enabled
configure:32055: result: no
configure:32066: checking for X
configure:32174: gcc -E  -D_GNU_SOURCE  -I/opt/cuda/include conftest.c
configure:32174: $? = 0
configure:32205: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3  -fopenmp  -D_GNU_SOURCE  -I/opt/cuda/include  -gdwarf-2 -g3  conftest.c -lX11 -lrt -lm -lpthread  >&5
configure:32205: $? = 0
configure:32255: result: libraries , headers
configure:32354: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3  -fopenmp  -D_GNU_SOURCE  -I/opt/cuda/include  -gdwarf-2 -g3  conftest.c -lrt -lm -lpthread   -lX11 >&5
configure:32354: $? = 0
configure:32452: checking for gethostbyname
configure:32452: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3  -fopenmp  -D_GNU_SOURCE  -I/opt/cuda/include  -gdwarf-2 -g3  conftest.c -lrt -lm -lpthread  >&5
configure:32452: $? = 0
configure:32452: result: yes
configure:32549: checking for connect
configure:32549: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3  -fopenmp  -D_GNU_SOURCE  -I/opt/cuda/include  -gdwarf-2 -g3  conftest.c -lrt -lm -lpthread  >&5
configure:32549: $? = 0
configure:32549: result: yes
configure:32598: checking for remove
configure:32598: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3  -fopenmp  -D_GNU_SOURCE  -I/opt/cuda/include  -gdwarf-2 -g3  conftest.c -lrt -lm -lpthread  >&5
configure:32598: $? = 0
configure:32598: result: yes
configure:32647: checking for shmat
configure:32647: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3  -fopenmp  -D_GNU_SOURCE  -I/opt/cuda/include  -gdwarf-2 -g3  conftest.c -lrt -lm -lpthread  >&5
configure:32647: $? = 0
configure:32647: result: yes
configure:32705: checking for IceConnectionNumber in -lICE
configure:32730: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3  -fopenmp  -D_GNU_SOURCE  -I/opt/cuda/include  -gdwarf-2 -g3  conftest.c -lICE  -lrt -lm -lpthread  >&5
configure:32730: $? = 0
configure:32739: result: yes
configure:33222: checking for library containing sgemm_
configure:33253: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3  -fopenmp  -D_GNU_SOURCE  -I/opt/cuda/include  -gdwarf-2 -g3  conftest.c  >&5
/tmp/ccv5EyUd.o: In function `main':
/home/wafa/StarPU/conftest.c:101: undefined reference to `sgemm_'
configure:33253: $? = 1
| /* confdefs.h */
| #define STARPU_GDB_PATH "/usr/bin/gdb"
| #define STARPU_HAVE_X11 1
| #ifdef __cplusplus
| extern "C"
| #endif
| char sgemm_ ();
| int
| main ()
| return sgemm_ ();
|   return 0;
configure:33253: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3  -fopenmp  -D_GNU_SOURCE  -I/opt/cuda/include  -gdwarf-2 -g3  conftest.c -lblas   >&5
/usr/bin/ld: cannot find -lblas
| /* confdefs.h */
| #ifdef __cplusplus
| extern "C"
| #endif
| char sgemm_ ();
| int
| main ()
| return sgemm_ ();
|   return 0;
configure:33270: result: no
configure:33341: checking which BLAS lib should be used
configure:33343: result: none
configure:33367: checking for FFTW
configure:33375: $PKG_CONFIG --exists --print-errors "fftw3"
Package fftw3 was not found in the pkg-config search path.
Perhaps you should add the directory containing `fftw3.pc'
to the PKG_CONFIG_PATH environment variable
No package 'fftw3' found
configure:33378: $? = 1
configure:33393: $PKG_CONFIG --exists --print-errors "fftw3"
configure:33396: $? = 1
configure:33424: result: no
configure:33454: checking for FFTWF
configure:33462: $PKG_CONFIG --exists --print-errors "fftw3f"
Package fftw3f was not found in the pkg-config search path.
Perhaps you should add the directory containing `fftw3f.pc'
No package 'fftw3f' found
configure:33465: $? = 1
configure:33480: $PKG_CONFIG --exists --print-errors "fftw3f"
configure:33483: $? = 1
configure:33511: result: no
configure:33541: checking for FFTWL
configure:33549: $PKG_CONFIG --exists --print-errors "fftw3l"
Package fftw3l was not found in the pkg-config search path.
Perhaps you should add the directory containing `fftw3l.pc'
No package 'fftw3l' found
configure:33552: $? = 1
configure:33567: $PKG_CONFIG --exists --print-errors "fftw3l"
configure:33570: $? = 1
configure:33598: result: no
configure:33694: checking for HWLOC
configure:33702: $PKG_CONFIG --exists --print-errors "hwloc"
Package hwloc was not found in the pkg-config search path.
Perhaps you should add the directory containing `hwloc.pc'
No package 'hwloc' found
configure:33705: $? = 1
configure:33720: $PKG_CONFIG --exists --print-errors "hwloc"
configure:33723: $? = 1
configure:33751: result: no
configure:33834: error: cannot find hwloc
## Cache variables. ##
ac_cv_build=x86_64-unknown-linux-gnu
ac_cv_c_compiler_gnu=yes
ac_cv_c_restrict=__restrict
ac_cv_cxx_compiler_gnu=yes
ac_cv_env_BLAS_LIBS_set=
ac_cv_env_BLAS_LIBS_value=
ac_cv_env_CCC_set=
ac_cv_env_CCC_value=
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_CXXCPP_set=
ac_cv_env_CXXCPP_value=
ac_cv_env_CXXFLAGS_set=
ac_cv_env_CXXFLAGS_value=
ac_cv_env_CXX_set=
ac_cv_env_CXX_value=
ac_cv_env_F77_set=
ac_cv_env_F77_value=
ac_cv_env_FCFLAGS_set=
ac_cv_env_FCFLAGS_value=
ac_cv_env_FC_set=
ac_cv_env_FC_value=
ac_cv_env_FFLAGS_set=
ac_cv_env_FFLAGS_value=
ac_cv_env_FFTWF_CFLAGS_set=
ac_cv_env_FFTWF_CFLAGS_value=
ac_cv_env_FFTWF_LIBS_set=
ac_cv_env_FFTWF_LIBS_value=
ac_cv_env_FFTWL_CFLAGS_set=
ac_cv_env_FFTWL_CFLAGS_value=
ac_cv_env_FFTWL_LIBS_set=
ac_cv_env_FFTWL_LIBS_value=
ac_cv_env_FFTW_CFLAGS_set=
ac_cv_env_FFTW_CFLAGS_value=
ac_cv_env_FFTW_LIBS_set=
ac_cv_env_FFTW_LIBS_value=
ac_cv_env_FXT_CFLAGS_set=
ac_cv_env_FXT_CFLAGS_value=
ac_cv_env_FXT_LDFLAGS_set=
ac_cv_env_FXT_LDFLAGS_value=
ac_cv_env_FXT_LIBS_set=
ac_cv_env_FXT_LIBS_value=
ac_cv_env_HWLOC_CFLAGS_set=
ac_cv_env_HWLOC_CFLAGS_value=
ac_cv_env_HWLOC_LIBS_set=
ac_cv_env_HWLOC_LIBS_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_LIBS_set=
ac_cv_env_LIBS_value=
ac_cv_env_MAGMA_CFLAGS_set=
ac_cv_env_MAGMA_CFLAGS_value=
ac_cv_env_MAGMA_LIBS_set=
ac_cv_env_MAGMA_LIBS_value=
ac_cv_env_NVCCFLAGS_set=
ac_cv_env_NVCCFLAGS_value=
ac_cv_env_NVCC_set=
ac_cv_env_NVCC_value=
ac_cv_env_PKG_CONFIG_set=
ac_cv_env_PKG_CONFIG_value=
ac_cv_env_POTI_CFLAGS_set=
ac_cv_env_POTI_CFLAGS_value=
ac_cv_env_POTI_LIBS_set=
ac_cv_env_POTI_LIBS_value=
ac_cv_env_STARPU_MS_LIB_set=
ac_cv_env_STARPU_MS_LIB_value=
ac_cv_env_XMKMF_set=
ac_cv_env_XMKMF_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_f77_compiler_gnu=no
ac_cv_fc_compiler_gnu=no
ac_cv_func_clEnqueueMarkerWithWaitList=yes
ac_cv_func_clGetExtensionFunctionAddressForPlatform=no
ac_cv_func_clock_gettime=yes
ac_cv_func_connect=yes
ac_cv_func_drand48=yes
ac_cv_func_erand48_r=yes
ac_cv_func_gethostbyname=yes
ac_cv_func_memalign=yes
ac_cv_func_mkostemp=yes
ac_cv_func_nearbyintf=yes
ac_cv_func_posix_memalign=yes
ac_cv_func_pread=yes
ac_cv_func_pthread_barrier_init=yes
ac_cv_func_pthread_setaffinity_np=yes
ac_cv_func_pthread_spin_lock=yes
ac_cv_func_pwrite=yes
ac_cv_func_remove=yes
ac_cv_func_rintf=yes
ac_cv_func_sched_yield=yes
ac_cv_func_setenv=yes
ac_cv_func_shmat=yes
ac_cv_func_strerror_r=yes
ac_cv_func_sysconf=yes
ac_cv_func_unsetenv=yes
ac_cv_have_gcc_plugins=no
ac_cv_have_sync_bool_compare_and_swap=yes
ac_cv_have_sync_fetch_and_add=yes
ac_cv_have_sync_fetch_and_or=yes
ac_cv_have_sync_lock_test_and_set=yes
ac_cv_have_sync_synchronize=yes
ac_cv_have_sync_val_compare_and_swap=yes
ac_cv_have_x='have_x=yes	ac_x_includes='\'''\''	ac_x_libraries='\'''\'''
ac_cv_header_Ayudame_h=no
ac_cv_header_RCCE_h=no
ac_cv_header_aio_h=yes
ac_cv_header_dlfcn_h=yes
ac_cv_header_glpk_h=no
ac_cv_header_inttypes_h=yes
ac_cv_header_leveldb_db_h=no
ac_cv_header_malloc_h=yes
ac_cv_header_memory_h=yes
ac_cv_header_stdc=yes
ac_cv_header_stdint_h=yes
ac_cv_header_stdlib_h=yes
ac_cv_header_string_h=yes
ac_cv_header_strings_h=yes
ac_cv_header_sys_stat_h=yes
ac_cv_header_sys_types_h=yes
ac_cv_header_unistd_h=yes
ac_cv_header_valgrind_helgrind_h=no
ac_cv_header_valgrind_memcheck_h=no
ac_cv_header_valgrind_valgrind_h=no
ac_cv_host=x86_64-unknown-linux-gnu
ac_cv_lib_ICE_IceConnectionNumber=yes
ac_cv_lib_OpenCL=ac_cv_lib_OpenCL_main
ac_cv_lib_RCCE_bigflags_nongory_nopwrmgmt_RCCE_init=no
ac_cv_lib_cublas=ac_cv_lib_cublas_main
ac_cv_lib_cuda=ac_cv_lib_cuda_main
ac_cv_lib_cudart=ac_cv_lib_cudart_main
ac_cv_lib_glpk_main=no
ac_cv_lib_leveldb_main=no
ac_cv_lib_pthread_pthread_create=yes
ac_cv_lib_rt_clock_gettime=yes
ac_cv_lib_ws2_32=ac_cv_lib_ws2_32_main
ac_cv_lib_ws2_32_main=no
ac_cv_objext=o
ac_cv_path_EGREP='/bin/grep -E'
ac_cv_path_FGREP='/bin/grep -F'
ac_cv_path_GDB=/usr/bin/gdb
ac_cv_path_GREP=/bin/grep
ac_cv_path_NVCC=not-found
ac_cv_path_QMAKE=/usr/bin/qmake
ac_cv_path_SED=/bin/sed
ac_cv_path_ac_pt_PKG_CONFIG=/usr/bin/pkg-config
ac_cv_path_install='/usr/bin/install -c'
ac_cv_path_mkdir=/bin/mkdir
ac_cv_path_mpicc_path=no
ac_cv_path_mpiexec_path=no
ac_cv_path_svncommand=/usr/bin/svn
ac_cv_path_svnversioncommand=/usr/bin/svnversion
ac_cv_prog_AWK=gawk
ac_cv_prog_BASH=/bin/bash
ac_cv_prog_CPP='gcc -E'
ac_cv_prog_CXXCPP='g++ -E'
ac_cv_prog_PROG_DATE=date
ac_cv_prog_PROG_STAT=stat
ac_cv_prog_ac_ct_AR=ar
ac_cv_prog_ac_ct_CC=gcc
ac_cv_prog_ac_ct_CXX=g++
ac_cv_prog_ac_ct_MANIFEST_TOOL=mt
ac_cv_prog_ac_ct_OBJDUMP=objdump
ac_cv_prog_ac_ct_RANLIB=ranlib
ac_cv_prog_ac_ct_STRIP=strip
ac_cv_prog_c_openmp=-fopenmp
ac_cv_prog_cc_c89=
ac_cv_prog_cc_g=yes
ac_cv_prog_cxx_g=yes
ac_cv_prog_f77_g=no
ac_cv_prog_fc_g=no
ac_cv_prog_make_make_set=yes
ac_cv_search_set_mempolicy=no
ac_cv_search_sgemm_=no
ac_cv_search_sqrt=-lm
ac_cv_sizeof_void_p=8
ac_cv_target=x86_64-unknown-linux-gnu
ac_cv_type_cufftDoubleComplex=yes
ac_cv_type_struct_timespec=yes
am_cv_CC_dependencies_compiler_type=gcc3
am_cv_CXX_dependencies_compiler_type=gcc3
am_cv_ar_interface=ar
am_cv_make_support_nested_variables=yes
am_cv_prog_cc_c_o=yes
lt_cv_ar_at_file=@
lt_cv_archive_cmds_need_lc=no
lt_cv_deplibs_check_method=pass_all
lt_cv_file_magic_cmd='$MAGIC_CMD'
lt_cv_file_magic_test_file=
lt_cv_ld_reload_flag=-r
lt_cv_nm_interface='BSD nm'
lt_cv_objdir=.libs
lt_cv_path_LD=/usr/bin/ld
lt_cv_path_LDCXX='/usr/bin/ld -m elf_x86_64'
lt_cv_path_NM='/usr/bin/nm -B'
lt_cv_path_mainfest_tool=no
lt_cv_prog_compiler_c_o=yes
lt_cv_prog_compiler_c_o_CXX=yes
lt_cv_prog_compiler_pic='-fPIC -DPIC'
lt_cv_prog_compiler_pic_CXX='-fPIC -DPIC'
lt_cv_prog_compiler_pic_works=yes
lt_cv_prog_compiler_pic_works_CXX=yes
lt_cv_prog_compiler_rtti_exceptions=no
lt_cv_prog_compiler_static_works=yes
lt_cv_prog_compiler_static_works_CXX=yes
lt_cv_prog_gnu_ld=yes
lt_cv_prog_gnu_ldcxx=yes
lt_cv_sharedlib_from_linklib_cmd='printf %s\n'
lt_cv_shlibpath_overrides_runpath=no
lt_cv_sys_global_symbol_pipe='sed -n -e '\''s/^.*[	 ]\([ABCDGIRSTW][ABCDGIRSTW]*\)[	 ][	 ]*\([_A-Za-z][_A-Za-z0-9]*\)$/\1 \2 \2/p'\'' | sed '\''/ __gnu_lto/d'\'''
lt_cv_sys_global_symbol_to_c_name_address='sed -n -e '\''s/^: \([^ ]*\)[ ]*$/  {\"\1\", (void *) 0},/p'\'' -e '\''s/^[ABCDGIRSTW]* \([^ ]*\) \([^ ]*\)$/  {"\2", (void *) \&\2},/p'\'''
lt_cv_sys_global_symbol_to_c_name_address_lib_prefix='sed -n -e '\''s/^: \([^ ]*\)[ ]*$/  {\"\1\", (void *) 0},/p'\'' -e '\''s/^[ABCDGIRSTW]* \([^ ]*\) \(lib[^ ]*\)$/  {"\2", (void *) \&\2},/p'\'' -e '\''s/^[ABCDGIRSTW]* \([^ ]*\) \([^ ]*\)$/  {"lib\2", (void *) \&\2},/p'\'''
lt_cv_sys_global_symbol_to_cdecl='sed -n -e '\''s/^T .* \(.*\)$/extern int \1();/p'\'' -e '\''s/^[ABCDGIRSTW]* .* \(.*\)$/extern char \1;/p'\'''
lt_cv_sys_max_cmd_len=1572864
lt_cv_to_host_file_cmd=func_convert_file_noop
lt_cv_to_tool_file_cmd=func_convert_file_noop
## Output variables. ##
ACLOCAL='${SHELL} /home/wafa/StarPU/build-aux/missing aclocal-1.14'
AMDEPBACKSLASH='\'
AMDEP_FALSE='#'
AMDEP_TRUE=''
AMTAR='$${TAR-tar}'
AM_BACKSLASH='\'
AM_DEFAULT_V='$(AM_DEFAULT_VERBOSITY)'
AM_DEFAULT_VERBOSITY='0'
AM_V='$(V)'
AR='ar'
AS='as'
ATLASDIR=''
ATLAS_BLAS_LIB_FALSE=''
ATLAS_BLAS_LIB_TRUE='#'
AUTOCONF='${SHELL} /home/wafa/StarPU/build-aux/missing autoconf'
AUTOHEADER='${SHELL} /home/wafa/StarPU/build-aux/missing autoheader'
AUTOMAKE='${SHELL} /home/wafa/StarPU/build-aux/missing automake-1.14'
AWK='gawk'
BASH='/bin/bash'
BLAS_LIB='none'
BLAS_LIBS=''
BUILD_DOC_FALSE=''
BUILD_DOC_TRUE=''
BUILD_EXAMPLES_FALSE='#'
BUILD_EXAMPLES_TRUE=''
BUILD_GCC_PLUGIN_FALSE=''
BUILD_GCC_PLUGIN_TRUE='#'
BUILD_SOCL_FALSE='#'
BUILD_SOCL_TRUE=''
BUILD_STARPUFFT_EXAMPLES_FALSE=''
BUILD_STARPUFFT_EXAMPLES_TRUE='#'
BUILD_STARPUFFT_FALSE='#'
BUILD_STARPUFFT_TRUE=''
BUILD_STARPU_TOP_FALSE=''
BUILD_STARPU_TOP_TRUE='#'
BUILD_TESTS_FALSE='#'
BUILD_TESTS_TRUE=''
CC='gcc'
CCDEPMODE='depmode=gcc3'
CC_OR_MPICC='gcc'
CFLAGS='-O3 -g -O2 -gdwarf-2 -g3  -fopenmp'
COVERAGE='no'
CPP='gcc -E'
CPPFLAGS=' -D_GNU_SOURCE  -I/opt/cuda/include'
CXX='g++'
CXXCPP='g++ -E'
CXXDEPMODE='depmode=gcc3'
CXXFLAGS='-O3 -g -O2 -gdwarf-2 -g3 '
CYGPATH_W='echo'
DEFS=''
DEPDIR='.deps'
DLLTOOL='false'
DSYMUTIL=''
DUMPBIN=''
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EXEEXT=''
F77=''
FC=''
FCFLAGS=''
FFLAGS=''
FFTWF_CFLAGS=''
FFTWF_LIBS=''
FFTWL_CFLAGS=''
FFTWL_LIBS=''
FFTW_CFLAGS=''
FFTW_LIBS=''
FXTDIR=''
FXT_CFLAGS=''
FXT_LDFLAGS=''
FXT_LIBS=''
GCC_FOR_PLUGIN=''
GCC_FOR_PLUGIN_LIBTOOL_TAG=''
GCC_PLUGIN_DIR_PKGCONFIG=''
GCC_PLUGIN_INCLUDE_DIR='plugin/include'
GCC_PLUGIN_PKGCONFIG=''
GDB='/usr/bin/gdb'
GLOBAL_AM_CFLAGS=' -Wall -Werror=implicit -Werror=implicit-function-declaration'
GOTODIR=''
GOTO_BLAS_LIB_FALSE=''
GOTO_BLAS_LIB_TRUE='#'
GREP='/bin/grep'
GUILE=''
HAVE_FFTWFL=''
HAVE_OPENGL_FALSE=''
HAVE_OPENGL_TRUE='#'
HAVE_PTR_DEREFS_MAY_ALIAS_P_FALSE=''
HAVE_PTR_DEREFS_MAY_ALIAS_P_TRUE='#'
HAVE_X11_FALSE='#'
HAVE_X11_TRUE=''
HELP2MAN=''
HWLOC_CFLAGS=''
HWLOC_LIBS=''
HWLOC_REQUIRES=''
ICC=''
INSTALL_DATA='${INSTALL} -m 644'
INSTALL_PROGRAM='${INSTALL}'
INSTALL_SCRIPT='${INSTALL}'
INSTALL_STRIP_PROGRAM='$(install_sh) -c -s'
LD='/usr/bin/ld -m elf_x86_64'
LDFLAGS=' -gdwarf-2 -g3 '
LIBOBJS=''
LIBS='-lrt -lm -lpthread '
LIBSOCL_INTERFACE_AGE='0'
LIBSOCL_INTERFACE_CURRENT='0'
LIBSOCL_INTERFACE_REVISION='0'
LIBSTARPUFFT_INTERFACE_AGE='0'
LIBSTARPUFFT_INTERFACE_CURRENT='0'
LIBSTARPUFFT_INTERFACE_REVISION='0'
LIBSTARPUMPI_INTERFACE_AGE='0'
LIBSTARPUMPI_INTERFACE_CURRENT='0'
LIBSTARPUMPI_INTERFACE_REVISION='0'
LIBSTARPU_INTERFACE_AGE='0'
LIBSTARPU_INTERFACE_CURRENT='0'
LIBSTARPU_INTERFACE_REVISION='0'
LIBSTARPU_LDFLAGS=''
LIBSTARPU_LINK=''
LIBTOOL='$(SHELL) $(top_builddir)/libtool'
LIPO=''
LN_S='ln -s'
LTLIBOBJS=''
MAGMA_CFLAGS=''
MAGMA_LIBS=''
MAKEINFO='${SHELL} /home/wafa/StarPU/build-aux/missing makeinfo'
MANIFEST_TOOL=':'
MKDIR_P='/bin/mkdir -p'
MKL_BLAS_LIB_FALSE=''
MKL_BLAS_LIB_TRUE='#'
MPICC='no'
MPICC_LDFLAGS=''
MPIEXEC=''
NM='/usr/bin/nm -B'
NMEDIT=''
NO_BLAS_LIB_FALSE='#'
NO_BLAS_LIB_TRUE=''
NVCC='not-found'
NVCCFLAGS=' -ccbin ${CC} -I/opt/cuda/include'
OBJDUMP='objdump'
OBJEXT='o'
OPENMP_CFLAGS='-fopenmp'
OTOOL64=''
OTOOL=''
PACKAGE='starpu'
PACKAGE_BUGREPORT='starpu-devel@lists.gforge.inria.fr'
PACKAGE_NAME='StarPU'
PACKAGE_STRING='StarPU 1.3.0'
PACKAGE_TARNAME='starpu'
PACKAGE_URL='http://runtime.bordeaux.inria.fr/StarPU/'
PACKAGE_VERSION='1.3.0'
PATH_SEPARATOR=':'
PKG_CONFIG='/usr/bin/pkg-config'
POTI_CFLAGS=''
POTI_LIBS=''
PROG_DATE='date'
PROG_STAT='stat'
QMAKE='/usr/bin/qmake'
QWT_PRI=''
RANLIB='ranlib'
RUN_GCC_PLUGIN_TESTS_FALSE=''
RUN_GCC_PLUGIN_TESTS_TRUE='#'
SED='/bin/sed'
SET_MAKE=''
SHELL='/bin/bash'
SIMGRID_CFLAGS=''
SIMGRID_LIBS=''
SOCL_OCL_LIB_OPENCL_DIR=''
SOCL_VENDORS=''
STARPU_BLAS_LDFLAGS=' '
STARPU_BUILD_DIR='/home/wafa/StarPU'
STARPU_BUILD_SC_HYPERVISOR_FALSE=''
STARPU_BUILD_SC_HYPERVISOR_TRUE='#'
STARPU_COI_CPPFLAGS=''
STARPU_COI_LDFLAGS=''
STARPU_COVERAGE_ENABLED_FALSE=''
STARPU_COVERAGE_ENABLED_TRUE='#'
STARPU_CROSS_COMPILING_FALSE=''
STARPU_CROSS_COMPILING_TRUE='#'
STARPU_CUDA_CPPFLAGS='-I/opt/cuda/include'
STARPU_CUDA_FORTRAN_LDFLAGS=''
STARPU_CUDA_LDFLAGS=''
STARPU_CUFFT_LDFLAGS=''
STARPU_CURAND_LDFLAGS=''
STARPU_DEVEL_FALSE=''
STARPU_DEVEL_TRUE='#'
STARPU_EFFECTIVE_VERSION='1.3'
STARPU_EXPORTED_LIBS=''
STARPU_EXPORT_DYNAMIC=''
STARPU_GCC_VERSION_MAJOR=''
STARPU_GCC_VERSION_MINOR=''
STARPU_GLPK_LDFLAGS=' '
STARPU_HAVE_AM111_FALSE=''
STARPU_HAVE_AM111_TRUE=''
STARPU_HAVE_CUFFTDOUBLECOMPLEX_FALSE='#'
STARPU_HAVE_CUFFTDOUBLECOMPLEX_TRUE=''
STARPU_HAVE_DARWIN_FALSE=''
STARPU_HAVE_DARWIN_TRUE='#'
STARPU_HAVE_F77_H=''
STARPU_HAVE_F77_H_FALSE=''
STARPU_HAVE_F77_H_TRUE=''
STARPU_HAVE_FC_FALSE=''
STARPU_HAVE_FC_TRUE='#'
STARPU_HAVE_FFTW=''
STARPU_HAVE_FFTWF=''
STARPU_HAVE_FFTWF_FALSE=''
STARPU_HAVE_FFTWF_TRUE='#'
STARPU_HAVE_FFTWL_FALSE=''
STARPU_HAVE_FFTWL_TRUE='#'
STARPU_HAVE_FFTW_FALSE=''
STARPU_HAVE_FFTW_TRUE='#'
STARPU_HAVE_HELP2MAN_FALSE=''
STARPU_HAVE_HELP2MAN_TRUE=''
STARPU_HAVE_HWLOC=''
STARPU_HAVE_HWLOC_FALSE=''
STARPU_HAVE_HWLOC_TRUE='#'
STARPU_HAVE_ICC_FALSE=''
STARPU_HAVE_ICC_TRUE=''
STARPU_HAVE_LEVELDB_FALSE=''
STARPU_HAVE_LEVELDB_TRUE='#'
STARPU_HAVE_MAGMA=''
STARPU_HAVE_MAGMA_FALSE=''
STARPU_HAVE_MAGMA_TRUE='#'
STARPU_HAVE_MS_LIB_FALSE=''
STARPU_HAVE_MS_LIB_TRUE='#'
STARPU_HAVE_OPENMP_FALSE='#'
STARPU_HAVE_OPENMP_TRUE=''
STARPU_HAVE_WINDOWS_FALSE=''
STARPU_HAVE_WINDOWS_TRUE='#'
STARPU_HWLOC_HAVE_TOPOLOGY_DUP_FALSE=''
STARPU_HWLOC_HAVE_TOPOLOGY_DUP_TRUE=''
STARPU_LEVELDB_LDFLAGS=' '
STARPU_LIBNUMA_LDFLAGS=' '
STARPU_LINUX_SYS_FALSE='#'
STARPU_LINUX_SYS_TRUE=''
STARPU_LONG_CHECK_FALSE=''
STARPU_LONG_CHECK_TRUE='#'
STARPU_MAJOR_VERSION='1'
STARPU_MINOR_VERSION='3'
STARPU_MPI_CHECK_FALSE=''
STARPU_MPI_CHECK_TRUE='#'
STARPU_MS_LIB=''
STARPU_MS_LIB_ARCH='X64'
STARPU_NEW_CHECK_FALSE=''
STARPU_NEW_CHECK_TRUE='#'
STARPU_OPENCL_CPPFLAGS=' -DSTARPU_OPENCL_DATADIR=${prefix}/share/starpu/opencl -DCL_USE_DEPRECATED_OPENCL_1_1_APIS'
STARPU_OPENCL_DATAdir='NONE/share/starpu/opencl/examples'
STARPU_OPENCL_LDFLAGS=' -lOpenCL'
STARPU_OPENGL_RENDER='no'
STARPU_OPENGL_RENDER_LDFLAGS=''
STARPU_OPENMP_FALSE=''
STARPU_OPENMP_TRUE='#'
STARPU_PERF_DEBUG='no'
STARPU_QUICK_CHECK_FALSE=''
STARPU_QUICK_CHECK_TRUE='#'
STARPU_QWT_INCLUDE=''
STARPU_QWT_LDFLAGS=''
STARPU_RCCE_CFLAGS=''
STARPU_RCCE_CPPFLAGS=''
STARPU_RCCE_LDFLAGS=''
STARPU_RELEASE_VERSION='0'
STARPU_SANITIZE_FALSE=''
STARPU_SANITIZE_TRUE=''
STARPU_SCIF_CPPFLAGS=''
STARPU_SCIF_LDFLAGS=''
STARPU_SC_HYPERVISOR=''
STARPU_SC_HYPERVISOR_DEBUG='no'
STARPU_SC_HYPERVISOR_DEBUG_FALSE=''
STARPU_SC_HYPERVISOR_DEBUG_TRUE='#'
STARPU_SIMGRID_FALSE=''
STARPU_SIMGRID_TRUE='#'
STARPU_SRC_DIR='/home/wafa/StarPU/.'
STARPU_USE_CPU='yes'
STARPU_USE_CPU_FALSE='#'
STARPU_USE_CPU_TRUE=''
STARPU_USE_CUDA='no'
STARPU_USE_CUDA_FALSE=''
STARPU_USE_CUDA_TRUE='#'
STARPU_USE_FXT='no'
STARPU_USE_FXT_FALSE=''
STARPU_USE_FXT_TRUE='#'
STARPU_USE_MIC_FALSE=''
STARPU_USE_MIC_TRUE='#'
STARPU_USE_MP_FALSE=''
STARPU_USE_MP_TRUE='#'
STARPU_USE_OPENCL='yes'
STARPU_USE_OPENCL_FALSE='#'
STARPU_USE_OPENCL_TRUE=''
STARPU_USE_SCC_FALSE=''
STARPU_USE_SCC_TRUE='#'
STARPU_USE_SC_HYPERVISOR_FALSE=''
STARPU_USE_SC_HYPERVISOR_TRUE='#'
STARPU_USE_SOCL_FALSE='#'
STARPU_USE_SOCL_TRUE=''
STARPU_USE_TOP='no'
STRIP='strip'
SYSTEM_BLAS_LIB_FALSE=''
SYSTEM_BLAS_LIB_TRUE='#'
USE_MPI='no'
USE_MPI_FALSE=''
USE_MPI_TRUE='#'
VERSION='1.3.0'
XMKMF=''
X_CFLAGS=''
X_EXTRA_LIBS=''
X_LIBS=''
X_PRE_LIBS=' -lSM -lICE'
YACC='${SHELL} /home/wafa/StarPU/build-aux/missing bison'
ac_ct_AR='ar'
ac_ct_CC='gcc'
ac_ct_CXX='g++'
ac_ct_DUMPBIN=''
ac_ct_F77=''
ac_ct_FC=''
am__EXEEXT_FALSE=''
am__EXEEXT_TRUE=''
am__fastdepCC_FALSE='#'
am__fastdepCC_TRUE=''
am__fastdepCXX_FALSE='#'
am__fastdepCXX_TRUE=''
am__include='include'
am__isrc=''
am__leading_dot='.'
am__nodep='_no'
am__quote=''
am__tar='$${TAR-tar} chof - "$$tardir"'
am__untar='$${TAR-tar} xf -'
bindir='${exec_prefix}/bin'
build='x86_64-unknown-linux-gnu'
build_alias=''
build_cpu='x86_64'
build_os='linux-gnu'
build_vendor='unknown'
datadir='${datarootdir}'
datarootdir='${prefix}/share'
docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
doxygencommand=''
dvidir='${docdir}'
epstopdfcommand=''
exec_prefix='NONE'
gccplugindir=''
host='x86_64-unknown-linux-gnu'
host_alias=''
host_cpu='x86_64'
host_os='linux-gnu'
host_vendor='unknown'
htmldir='${docdir}'
includedir='${prefix}/include'
infodir='${datarootdir}/info'
install_sh='${SHELL} /home/wafa/StarPU/build-aux/install-sh'
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localedir='${datarootdir}/locale'
localstatedir='${prefix}/var'
mandir='${datarootdir}/man'
mkdir_p='$(MKDIR_P)'
mpicc_path='no'
mpiexec_path=''
oldincludedir='/usr/include'
pdfdir='${docdir}'
pdflatexcommand=''
pkglibdir='${libdir}/starpu'
prefix='NONE'
program_transform_name='s,x,x,'
psdir='${docdir}'
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
smpirun_path=''
svncommand='/usr/bin/svn'
svnversioncommand='/usr/bin/svnversion'
sysconfdir='${prefix}/etc'
target='x86_64-unknown-linux-gnu'
target_alias=''
target_cpu='x86_64'
target_os='linux-gnu'
target_vendor='unknown'
## confdefs.h. ##
/* confdefs.h */
#define PACKAGE_NAME "StarPU"
#define PACKAGE_TARNAME "starpu"
#define PACKAGE_VERSION "1.3.0"
#define PACKAGE_STRING "StarPU 1.3.0"
#define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr"
#define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/";
#define STARPU_MAJOR_VERSION 1
#define STARPU_MINOR_VERSION 3
#define STARPU_RELEASE_VERSION 0
#define PACKAGE "starpu"
#define VERSION "1.3.0"
configure: exit 1
Haut de le page
