Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: Wafa Nafti <wafa_nafti@yahoo.fr>, Samuel Thibault <samuel.thibault@inria.fr>
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] StarPU Configuration error
- Date: Wed, 6 Apr 2016 10:45:51 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=Pass smtp.mailfrom=nathalie.furmento@labri.fr; spf=Pass smtp.helo=postmaster@iona.labri.fr
- Ironport-phdr: 9a23:5oDl4R1tvlp+7arxsmDT+DRfVm0co7zxezQtwd8ZsekUIvad9pjvdHbS+e9qxAeQG96Lu7QY0qGO6ujJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6CyZjunLjrs7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cYk7sb+sVBSaT3ebgjBfwdVWx+cjN92Mq+ihDNREOp73UAUy1CjRNGCj/D5R/mX7/guyv9saxzwn/edfb/SK05XXye76ZhQQLslG9TLDc87WzTzNBwjahSvRa9jx152Y/dJo+PYqlQZKTYKPUTWWpIWsdcHwJcGIaxaZcIR74HNPpYpo38qh0AsAG7CA+wA8vrwzVShzn4x/tpgKwaDQja0Vl4TJo1u3POoYCwbf9KXA==
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Looks like hwloc is not installed in a
standard location.
Here what configure is reporting. Package hwloc was not found in the pkg-config search path. Perhaps you should add the directory containing `hwloc.pc' to the PKG_CONFIG_PATH environment variable You should find out the location of the file hwloc.pc on your machine and add the directory to the PKG_CONFIG_PATH environment variable before starting configure. Cheers, Nathalie On 06/04/2016 09:46, Wafa Nafti wrote: Ok, it's in
attachment.
Wafa NAFTI
ENSIT, Tunisie
Le Mercredi 6
avril 2016 9h43, Samuel Thibault
<samuel.thibault@inria.fr> a écrit :
Hello,
Wafa Nafti, on Wed 06 Apr 2016 07:37:21 +0000, wrote: > libhwloc-dev is already the newest version. Ok. > Thus, it is already installed. However it always gives me the same error > message during the configuration. Please post the content of config.log, that's where the actuel error message lies. Samuel _______________________________________________ Starpu-devel mailing list Starpu-devel@lists.gforge.inria.fr http://lists.gforge.inria.fr/mailman/listinfo/starpu-devel |
- [Starpu-devel] StarPU Configuration error, Wafa Nafti, 05/04/2016
- Re: [Starpu-devel] StarPU Configuration error, Samuel Thibault, 05/04/2016
- Re: [Starpu-devel] StarPU Configuration error, Wafa Nafti, 06/04/2016
- Re: [Starpu-devel] StarPU Configuration error, Samuel Thibault, 06/04/2016
- Re: [Starpu-devel] StarPU Configuration error, Nathalie Furmento, 06/04/2016
