Archives de la liste
- To: Nathalie Furmento <nathalie.furmento@labri.fr>, Samuel Thibault <samuel.thibault@inria.fr>
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] StarPU Configuration error
- Date: Wed, 6 Apr 2016 09:45:41 +0000 (UTC)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=wafa_nafti@yahoo.fr; spf=Pass smtp.mailfrom=wafa_nafti@yahoo.fr; spf=None smtp.helo=postmaster@nm34-vm9.bullet.mail.gq1.yahoo.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Thank you Nathalie. It's Ok for the installation.
However I have this error when I try to compile an example :
~/StarPU/examples/basic_examples$ gcc `pkg-config starpu-1.1 --cflags` block.c \ -fplugin=`pkg-config starpu-1.1 --variable=gccplugin` \ `pkg-config starpu-1.1 --libs`
gcc: error: -fplugin=: No such file or directory
gcc: error: -L/usr/local/lib: No such file or directory
Wafa NAFTI
ENSIT, Tunisie
Le Mercredi 6 avril 2016 10h45, Nathalie Furmento <nathalie.furmento@labri.fr> a écrit :
Looks like hwloc is not installed in a
standard location.
Here what configure is reporting.
Package hwloc was not found in the pkg-config search path.
Perhaps you should add the directory containing `hwloc.pc'
to the PKG_CONFIG_PATH environment variable
You should find out the location of the file hwloc.pc on your machine and add the directory to the PKG_CONFIG_PATH environment variable before starting configure.
Cheers,
Nathalie
Cheers,
Nathalie
Ok, it's in attachment.------------------------Wafa NAFTIENSIT, Tunisie
Le Mercredi 6 avril 2016 9h43, Samuel Thibault <samuel.thibault@inria.fr> a écrit :
Hello,
Wafa Nafti, on Wed 06 Apr 2016 07:37:21 +0000, wrote:
> libhwloc-dev is already the newest version.
Ok.
> Thus, it is already installed. However it always gives me the same error
> message during the configuration.
Please post the content of config.log, that's where the actuel error
message lies.
Samuel
_______________________________________________ Starpu-devel mailing list Starpu-devel@lists.gforge.inria.fr http://lists.gforge.inria.fr/mailman/listinfo/starpu-devel
- [Starpu-devel] StarPU Configuration error, Wafa Nafti, 05/04/2016
- Re: [Starpu-devel] StarPU Configuration error, Samuel Thibault, 05/04/2016
- Re: [Starpu-devel] StarPU Configuration error, Wafa Nafti, 06/04/2016
- Re: [Starpu-devel] StarPU Configuration error, Samuel Thibault, 06/04/2016
- Re: [Starpu-devel] StarPU Configuration error, Nathalie Furmento, 06/04/2016
