Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Deadlock with starpu_calibrate
Archives de la liste
Chronologique Discussions
  • To: Mathieu Faverge <mathieu.faverge@inria.fr>
  • Cc: Ian Masliah <ian.masliah@inria.fr>, starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Deadlock with starpu_calibrate
  • Date: Sun, 4 Dec 2016 19:44:44 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
  • Ironport-phdr: 9a23:ainW2RX0Qhvd/ufiXDjou1o+9iDV8LGtZVwlr6E/grcLSJyIuqrYZhaCt8tkgFKBZ4jH8fUM07OQ6PG7HzBeqsvf+DBaKdoXCE9D0Z1X1yUbQ+e7SmTDZMbwaCI7GMkQHHRExFqcdXZvJcDlelfJqWez5zNBUj/2NA5yO/inUtWK15f//6mI9pbSewRFgiamKfM3dU3u7FaZis5DpIJ+Kqc811Pnq2VFYetbjTdtLE6TnhvhoMm54pN5/Cl4uvQ79scGX7+sLIoiSrkNNz0jLm0xrPHrtBPKUA+Tri8HW2ALnx4OHwjE5hjnWovZsy3gt+M71jPMbp6+dqw9RTn3t/QjcxTvkipScmdhqGw=
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello,
Mathieu Faverge, on Sun 04 Dec 2016 19:39:07 +0100, wrote:
> doesn't seem to make any progress. It is stuck after printing:
> $ starpu_calibrate_bus
> [starpu][check_bus_config_file] No performance model for the bus,
> calibrating...
> [starpu][benchmark_all_gpu_devices] CUDA 0...
> [starpu][benchmark_all_gpu_devices] CUDA 1...
> [starpu][benchmark_all_gpu_devices] CUDA 2...
> [starpu][benchmark_all_gpu_devices] CUDA 0 -> 1...
> [starpu][measure_bandwidth_between_dev_and_dev_cuda] GPU-Direct 1 -> 0
> [starpu][measure_bandwidth_between_dev_and_dev_cuda] GPU-Direct 0 -> 1
Could you get a backtrace? I'm afraid it's probably just stuck inside a
CUDA call.
Samuel
Haut de le page
