Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Deadlock with starpu_calibrate
Archives de la liste
Chronologique Discussions
  • To: Mathieu Faverge <mathieu.faverge@inria.fr>
  • Cc: Ian Masliah <ian.masliah@inria.fr>, starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Deadlock with starpu_calibrate
  • Date: Sun, 4 Dec 2016 20:02:49 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Mathieu Faverge, on Sun 04 Dec 2016 19:53:01 +0100, wrote:
> Here it is:
> #0 0x00007ffff7ff9b24 in clock_gettime ()
> #1 0x00007ffff7858ea6 in clock_gettime () from /lib64/librt.so.1
> #2 0x00007ffff3be2f1e in ?? () from /usr/lib64/nvidia/libcuda.so.1
> #3 0x00007ffff3c70325 in ?? () from /usr/lib64/nvidia/libcuda.so.1
> #4 0x00007ffff3ba890e in ?? () from /usr/lib64/nvidia/libcuda.so.1
> #5 0x00007ffff3ba8b01 in ?? () from /usr/lib64/nvidia/libcuda.so.1
> #6 0x00007ffff3ae192a in ?? () from /usr/lib64/nvidia/libcuda.so.1
> #7 0x00007ffff3c0b648 in cuCtxSynchronize () from
> #8 0x00007ffff6dca179 in ?? () from /opt/cuda/8.0/lib64/libcudart.so.8.0
> #9 0x00007ffff6deb5f9 in cudaThreadSynchronize () from
> And if you do a strace, the number of calls to clock_gettime is just insane.
So it really looks like CUDA getting stuck in there. Not StarPU's fault
then. You could try to set
export STARPU_ENABLE_CUDA_GPU_GPU_DIRECT=0
in case CUDA has troubles with GPU direct.
Mathieu Faverge, on Sun 04 Dec 2016 19:59:55 +0100, wrote:
> Ok I'll check but it might just be that I didn't use the same cuda on the
> compilation and compute node.
That could be a problem indeed, I'm not really surprised by CUDA bugs
any more :)
Samuel
Haut de le page
