Archives de la liste
- To: Samuel Thibault <samuel.thibault@inria.fr>, Mathieu Faverge <mathieu.faverge@inria.fr>, starpu-devel@lists.gforge.inria.fr, Ian Masliah <ian.masliah@inria.fr>
- Subject: Re: [Starpu-devel] Deadlock with starpu_calibrate
- Date: Sun, 4 Dec 2016 20:07:32 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
I didn't find a solution to the problem unfortuntaley and it happened on multiple machines with K40 and K20s. I tried to recompile with a different
CUDA toolkit but it didn't change anything for me so I'm not sure.
I did try to disable GPU_DIRECT with export STARPU_ENABLE_CUDA_GPU_GPU_DIRECT=0 but it didn't work
either at that time.
2016-12-04 20:02 GMT+01:00 Samuel Thibault <samuel.thibault@inria.fr>:
Mathieu Faverge, on Sun 04 Dec 2016 19:53:01 +0100, wrote:
> Here it is:
> #0 0x00007ffff7ff9b24 in clock_gettime ()
> #1 0x00007ffff7858ea6 in clock_gettime () from /lib64/librt.so.1
> #2 0x00007ffff3be2f1e in ?? () from /usr/lib64/nvidia/libcuda.so.1
> #3 0x00007ffff3c70325 in ?? () from /usr/lib64/nvidia/libcuda.so.1
> #4 0x00007ffff3ba890e in ?? () from /usr/lib64/nvidia/libcuda.so.1
> #5 0x00007ffff3ba8b01 in ?? () from /usr/lib64/nvidia/libcuda.so.1
> #6 0x00007ffff3ae192a in ?? () from /usr/lib64/nvidia/libcuda.so.1
> #7 0x00007ffff3c0b648 in cuCtxSynchronize () from
> #8 0x00007ffff6dca179 in ?? () from /opt/cuda/8.0/lib64/libcudart.so.8.0
> #9 0x00007ffff6deb5f9 in cudaThreadSynchronize () from
> And if you do a strace, the number of calls to clock_gettime is just insane.
So it really looks like CUDA getting stuck in there. Not StarPU's fault
then. You could try to set
in case CUDA has troubles with GPU direct.
Mathieu Faverge, on Sun 04 Dec 2016 19:59:55 +0100, wrote:
> Ok I'll check but it might just be that I didn't use the same cuda on the
> compilation and compute node.
That could be a problem indeed, I'm not really surprised by CUDA bugs
any more :)
Samuel
- [Starpu-devel] Deadlock with starpu_calibrate, Mathieu Faverge, 04/12/2016
- Re: [Starpu-devel] Deadlock with starpu_calibrate, Samuel Thibault, 04/12/2016
- Re: [Starpu-devel] Deadlock with starpu_calibrate, Mathieu Faverge, 04/12/2016
- Re: [Starpu-devel] Deadlock with starpu_calibrate, Ian Masliah, 04/12/2016
