Archives de la liste
- To: Mirko Myllykoski <mirkom@cs.umu.se>
- Cc: Starpu Devel <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] Data target node + STARPU_VARIABLE_NBUFFERS
- Date: Fri, 5 Oct 2018 10:15:06 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: I am not organized
Mirko Myllykoski, le ven. 05 oct. 2018 10:02:42 +0200, a ecrit:
> Is there a way to set the data target node when starpu_codelet::nbuffers is
> set to STARPU_VARIABLE_NBUFFERS
You can use dyn_nodes instead of nodes, yes.
Samuel
- [Starpu-devel] Data target node + STARPU_VARIABLE_NBUFFERS, Mirko Myllykoski, 05/10/2018
- Re: [Starpu-devel] Data target node + STARPU_VARIABLE_NBUFFERS, Samuel Thibault, 05/10/2018
- Re: [Starpu-devel] Data target node + STARPU_VARIABLE_NBUFFERS, Mirko Myllykoski, 05/10/2018
