Archives de la liste
- To: samuel.thibault@inria.fr
- Cc: Starpu Devel <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] Data target node + STARPU_VARIABLE_NBUFFERS
- Date: Fri, 05 Oct 2018 13:24:23 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mirkom@cs.umu.se; spf=Pass smtp.mailfrom=mirkom@cs.umu.se; spf=None smtp.helo=postmaster@mail.cs.umu.se
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
On 2018-10-05 10:16, Samuel Thibault wrote:
Samuel Thibault, le ven. 05 oct. 2018 10:15:06 +0200, a ecrit:
Mirko Myllykoski, le ven. 05 oct. 2018 10:02:42 +0200, a ecrit:
> Is there a way to set the data target node when starpu_codelet::nbuffers is
> set to STARPU_VARIABLE_NBUFFERS
You can use dyn_nodes instead of nodes, yes.
Ah, sorry, read too fast. Mmm, with variable nbuffers, I don't think we
have implemented something yet, but it should be easy.
Samuel
Hi,
That functionality would be useful since right now I am copying stuff manually when necessary.
Is that something that could be added to the StarPU 1.2 branch?
- Mirko
- [Starpu-devel] Data target node + STARPU_VARIABLE_NBUFFERS, Mirko Myllykoski, 05/10/2018
- Re: [Starpu-devel] Data target node + STARPU_VARIABLE_NBUFFERS, Samuel Thibault, 05/10/2018
- Re: [Starpu-devel] Data target node + STARPU_VARIABLE_NBUFFERS, Mirko Myllykoski, 05/10/2018
