Archives de la liste
- To: Mirko Myllykoski <mirkom@cs.umu.se>, Starpu Devel <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] Data target node + STARPU_VARIABLE_NBUFFERS
- Date: Fri, 5 Oct 2018 10:16:00 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: I am not organized
Samuel Thibault, le ven. 05 oct. 2018 10:15:06 +0200, a ecrit:
> Mirko Myllykoski, le ven. 05 oct. 2018 10:02:42 +0200, a ecrit:
> > Is there a way to set the data target node when starpu_codelet::nbuffers
> > is
> > set to STARPU_VARIABLE_NBUFFERS
> You can use dyn_nodes instead of nodes, yes.
Ah, sorry, read too fast. Mmm, with variable nbuffers, I don't think we
have implemented something yet, but it should be easy.
Samuel
- [Starpu-devel] Data target node + STARPU_VARIABLE_NBUFFERS, Mirko Myllykoski, 05/10/2018
- Re: [Starpu-devel] Data target node + STARPU_VARIABLE_NBUFFERS, Samuel Thibault, 05/10/2018
- Re: [Starpu-devel] Data target node + STARPU_VARIABLE_NBUFFERS, Mirko Myllykoski, 05/10/2018
