Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] StarPU code hangs when using a lot of GPU memory
Archives de la liste
Chronologique Discussions
  • To: samuel.thibault@inria.fr
  • Cc: Starpu Devel <starpu-devel@lists.gforge.inria.fr>
  • Subject: Re: [Starpu-devel] StarPU code hangs when using a lot of GPU memory
  • Date: Fri, 01 Mar 2019 18:16:27 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mirkom@cs.umu.se; spf=Pass smtp.mailfrom=mirkom@cs.umu.se; spf=None smtp.helo=postmaster@mail.cs.umu.se
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi again,
On 2019-03-01 18:11, Mirko Myllykoski wrote:
The output of the macro was not very informative:
(gdb) starpu-memusage
Node 0:
Total used: 14, 364MiB
WT: 0, 0MiB
home: 0, 0MiB
redux: 0, 0MiB
relax: 10, 307MiB
noref: 10, 307MiB
nosubdataref: 2, 28MiB
nodataref: 2, 28MiB
cached: 0, 0MiB
Node 1:
Total used: 5815, 4493MiB
WT: 0, 0MiB
home: 0, 0MiB
redux: 0, 0MiB
relax: 0, 0MiB
noref: 0, 0MiB
nosubdataref: 0, 0MiB
nodataref: 0, 0MiB
cached: 0, 0MiB
I forgot to mention that it took between 10-15 seconds to print out the statistics for the Node 1. I also noticed that all CPU cores seem to stay idle after I executed the continue command (all threads are paused somehow).
- Mirko
Haut de le page
