Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] StarPU code hangs when using a lot of GPU memory
Archives de la liste
Chronologique Discussions
  • To: Mirko Myllykoski <mirkom@cs.umu.se>
  • Cc: Starpu Devel <starpu-devel@lists.gforge.inria.fr>
  • Subject: Re: [Starpu-devel] StarPU code hangs when using a lot of GPU memory
  • Date: Sat, 2 Mar 2019 07:39:36 -0800
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
  • Organization: I am not organized
Mirko Myllykoski, le sam. 02 mars 2019 12:24:57 +0100, a ecrit:
> normal: 983, 765MiB
> owner: 980, 741MiB
> shared: 3, 24MiB
> invalid: 0, 0MiB
> nosubdataref: 0, 0MiB
> nodataref: 0, 0MiB
> reading: 0, 0MiB
> writing: 0, 0MiB
Mmm, no transfers apparently, I wonder how there can be references then.
StarPU keeps references for ready tasks only once they have been taken
for execution by the driver. I guess you are not using a lot of streams
on the same CUDA device with STARPU_NWORKER_PER_CUDA, and not using a
very large CUDA pipeline with STARPU_CUDA_PIPELINE? I also guess you are
not using starpu_data_acquire on the CUDA GPU?
Could you re-run with the latest gdbinit version where I added more
details?
Samuel
Haut de le page
