Archives de la liste
- To: samuel.thibault@inria.fr
- Cc: Starpu Devel <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] StarPU code hangs when using a lot of GPU memory
- Date: Sat, 02 Mar 2019 12:24:57 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mirkom@cs.umu.se; spf=Pass smtp.mailfrom=mirkom@cs.umu.se; spf=None smtp.helo=postmaster@mail.cs.umu.se
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hi,
On 2019-03-02 05:59, Samuel Thibault wrote:
Could you update your gdbinit to the latest version which includes a lot
more information, and rerun starpu-memusage to get a more precise idea?
Here is the macro output from the latest git version (STARPU_LIMIT_CUDA_MEM=1000):
(gdb) starpu-memusage
Node 0:
Total used: 7, 66MiB
WT: 0, 0MiB
home: 0, 0MiB
OOC: 7, 66MiB
diduse: 6, 54MiB
redux: 0, 0MiB
relax: 2, 29MiB
noref: 2, 29MiB
normal: 5, 36MiB
owner: 2, 12MiB
shared: 3, 24MiB
invalid: 0, 0MiB
nosubdataref: 3, 24MiB
nodataref: 3, 24MiB
reading: 0, 0MiB
writing: 0, 0MiB
cached: 0, 0MiB
Node 1:
Total used: 984, 768MiB
WT: 0, 0MiB
home: 0, 0MiB
OOC: 984, 768MiB
diduse: 18, 24MiB
redux: 0, 0MiB
relax: 1, 2MiB
noref: 0, 0MiB
normal: 983, 765MiB
owner: 980, 741MiB
shared: 3, 24MiB
invalid: 0, 0MiB
nosubdataref: 0, 0MiB
nodataref: 0, 0MiB
reading: 0, 0MiB
writing: 0, 0MiB
cached: 0, 0MiB
- Mirko
- Re: [Starpu-devel] StarPU code hangs when using a lot of GPU memory, Mirko Myllykoski, 01/03/2019
- Re: [Starpu-devel] StarPU code hangs when using a lot of GPU memory, Samuel Thibault, 01/03/2019
- Re: [Starpu-devel] StarPU code hangs when using a lot of GPU memory, Samuel Thibault, 02/03/2019
- Re: [Starpu-devel] StarPU code hangs when using a lot of GPU memory, Mirko Myllykoski, 02/03/2019
