Archives de la liste
- To: Mirko Myllykoski <mirkom@cs.umu.se>
- Cc: Starpu Devel <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] StarPU code hangs when using a lot of GPU memory
- Date: Fri, 1 Mar 2019 20:59:22 -0800
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: I am not organized
Mirko Myllykoski, le ven. 01 mars 2019 18:40:02 +0100, a ecrit:
> There is definitively a lot of tasks ready to be scheduled and these tasks
> would end up updating almost the entire matrix in small sections. The entire
> matrix cannot be fitted into the GPU memory so the situation you are
> describing is likely to happen with my code.
Ok. Looking at what takes such references, I only think of scenarii
which are extremely unlikely, but who knows.
Could you update your gdbinit to the latest version which includes a lot
more information, and rerun starpu-memusage to get a more precise idea?
Thanks,
Samuel
- Re: [Starpu-devel] StarPU code hangs when using a lot of GPU memory, Mirko Myllykoski, 01/03/2019
- Re: [Starpu-devel] StarPU code hangs when using a lot of GPU memory, Samuel Thibault, 01/03/2019
- Re: [Starpu-devel] StarPU code hangs when using a lot of GPU memory, Samuel Thibault, 02/03/2019
- Re: [Starpu-devel] StarPU code hangs when using a lot of GPU memory, Mirko Myllykoski, 02/03/2019
