Archives de la liste
- To: typographie AT listes.irisa.fr
- Subject: Re: [typo] Especes d'espaces...
- Date: Tue, 10 Aug 2004 14:22:00 -0600
Bonjour à tous,
I started to go through this entire thread to write a summary, but was a little overwhelmed by the quantity of emails. Instead, I'll suggest some possible solutions and wait for the fireworks...
How many of the problems discussed would be solved by some combination of the following:
- all typographic spaces added by Unicode (all relative spaces, I believe) are treated as non-justifying.
- an additional justifying space is allowed, which allows a different min/max range than the existing word space. There are at least two ways this might work: 1) The user can choose which type is used first when justifying text. The first type is used to its maximum range before using the second type; or 2) The two types of spaces are used together when expanding or contracting a line, but at a different rate, as defined by a proportion.
- an additional user-defined space is added with whatever width is needed. One could, I suppose, allow a user to control the width of the Unicode typographic spaces, but this like it might go against the intent of these spaces. The definition of them is so vague, I think an application could vary them and still comply with the Unicode standard. ;)
It would also be nice to have the language-specific uses of fine spaces done automatically, but I suppose that is another discussion. (A rule set that is applied like a style sheet? Or should these changes be performed on request?)
-Rob Keeble
- Especes d'espaces..., (suite)
- Especes d'espaces..., Alain Hurtig, 04/08/2004
- Annulation d'abonnement, FFWP_ FR, 04/08/2004
- Re: [typo] Especes d'espaces..., Thierry Bouche, 05/08/2004
- Re: [typo] Especes d'espaces..., Alain Hurtig, 06/08/2004
- Re: [typo] Especes d'espaces..., Thierry Bouche, 09/08/2004
- Dictionnaire des noms propres, Fateh, 06/08/2004
- Re: [typo] Dictionnaire des noms propres, Jef Tombeur, 06/08/2004
- Re: Dictionnaire des noms propres, Fateh, 07/08/2004
- Re: [typo] Especes d'espaces..., Alain Hurtig, 07/08/2004
- Re: [typo] Especes d'espaces..., Alain Hurtig, 10/08/2004
- Re: [typo] Especes d'espaces..., Robert Keeble, 10/08/2004
- Re: [typo] Especes d'espaces..., Robert Keeble, 11/08/2004
- Re: [typo] Especes d'espaces..., Robert Keeble, 12/08/2004
- Re: [typo] Especes d'espaces..., Alain Hurtig, 13/08/2004
- Re: [typo] Especes d'espaces..., Robert Keeble, 14/08/2004
- Re: [typo] Especes d'espaces..., Alain Hurtig, 14/08/2004
- Re: [typo] Especes d'espaces..., Robert Keeble, 15/08/2004
- Re: [typo] Especes d'espaces..., Thierry Bouche, 30/08/2004
