Accéder au contenu.
Menu Sympa
typographie - Re: [typo] Le ou la Covid-19 ?...
Archives de la liste
Chronologique Discussions
  • To: typographie AT listes.irisa.fr
  • Subject: Re: [typo] Le ou la Covid-19 ?...
  • Date: Fri, 8 May 2020 10:46:36 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jacques.melot AT isholf.is; spf=Pass smtp.mailfrom=jacques.melot AT isholf.is; spf=None smtp.helo=postmaster AT smtp-out-04.simnet.is
  • Ironport-phdr: 9a23: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
  • Ironport-phdr: 9a23:+9GmlBdpEcOlOa7mTtmQ8NKdlGMj4e+mFxMJ6pchl7NFe7ii+JKnBkHE+PFxlwCRD57e9+oBjPfK9vi8H3cB5JCMrGgYd9pNTExNhcYXmlkmB8iIQQ3+IeXxZiM3VMJFSBd+/n69PEQUUMbzblHfuDuzuDgVHBjy
  • Ironport-sdr: NiFAQWioXVvA+2TaASeZB7Eif+8p7EcVcRHTM6Jxs31uBMaToBAr4fFp8gaWWNDQGDNkgrNAcv xH14SPFWHMxqGCxwzqgDf0tBcvwrqAv2PSiSr2Y1Y0EeR3KRC6gq0512/i6TY4aU0LNeqimKXV Ms6vslX3GSdb8xqwQpepeGkQyly+6QpUDI76S00mrdSmVGcWf13hvz9BzXo42ia5r3EDItxtt9 kRIkT4xCAF5t8f9O/lErRLLYsoNL15emc8iDB5FT52emf0Ha58z/7dx+ULM09wQp4YfuOqRGrH rWY=
Le 8 mai 2020 à 00:19, Yoann LE BARS a écrit :
> Salut à tous !
> Le 08/05/2020 à 00:10, Thierry Bouche a écrit :
>> C'est assez rigolo d'assister à votre discussion, mais avez-vous
>> conscience qu'elle n'a absolument aucun rapport avec la typographie ?
> En même temps, c’est tellement courant sur cette liste.
[J. M.] C'est aussi ce qui en fait sa richesse et qui montre sa vitalité.
On ne s'en plaignait pas du temps de Lacroux où, partant d'un sujet
indéniablement typographique, de fil en aiguille, par enchaînement, nous
enrichissions le sujet pour finalement parvenir à des conclusions plus
solides, plus riches que si nous nous étions conduits en simples techniciens.
C'est là l'expression d'un penchant typiquement français : l'aspiration à
traiter les choses à la manière et avec l'enthousiasme émulant des
encyclopédistes. L'univers est un tout dans lequel l'explication des causes
et donc leur recherche peut nous faire sortir, peu à peu mais manifestement,
hors du domaine concerné, c'est-à-dire celui où le problème de la cause ou de
l'explication s'est posé.
« Peut-être que pour comprendre la Nature, il faut la dépasser de beaucoup. »
(Sade)
[De mémoire, la citation n'est donc peut-être pas exacte au mot près.]
On peut citer l'exemple de forums tels que le nôtre, ici, des forums où
l'on s'est mis à proscrire rigoureusement le hors sujet et pour s'en assurer
à mettre de plus le forum en mode modération : les messages n'étaient plus
diffusés que si le modérateur décidait qu'ils puissent l'être. Le résultat ne
s'est pas fait attendre. D'un forum aux discussions passionnantes et qui
n'étaient jamais d'emblée hors sujet on est passé au silence. Désormais la
circulation des messages s'est réduite à deux ou trois messages purement
techniques par an. Voilà comment on tue un forum.
Le forum Typographie n'est absolument pas menacé de dérive, pas plus qu'il
ne l'était du temps de Lacroux.
J. M.
> À bientôt.
> Yoann LE BARS
> http://le-bars.net/yoann/
> Diaspora* :
> ylebars AT framasphere.org
> La liste Typo — discussions typographiques
> Les archives : https://sympa.inria.fr/sympa/arc/typographie
> Désabonnement :
> <mailto:sympa_inria AT inria.fr?subject=unsubscribe%20typographie>
Archives gérées par MHonArc 2.6.18.
Haut de le page
