Archives de la liste
- To: typographie AT listes.irisa.fr
- Subject: Re: [typo] Le ou la Covid-19 ?...
- Date: Fri, 8 May 2020 12:52:22 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=pb-latex AT gmx.fr; spf=Pass smtp.mailfrom=pb-latex AT gmx.fr; spf=None smtp.helo=postmaster AT mout.gmx.net
- Importance: normal
- Ironport-phdr: 9a23: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
- Sensitivity: Normal
Je plussoie... et remercie Jacques Melot pour la citation de Sade, que je ne connaissais pas.
Patrick Bideault
Le 8 mai 2020 à 00:19, Yoann LE BARS a écrit :
> Salut à tous !
> Le 08/05/2020 à 00:10, Thierry Bouche a écrit :
>> C'est assez rigolo d'assister à votre discussion, mais avez-vous conscience qu'elle n'a absolument aucun rapport avec la typographie ?
> En même temps, c’est tellement courant sur cette liste.
[J. M.] C'est aussi ce qui en fait sa richesse et qui montre sa vitalité. On ne s'en plaignait pas du temps de Lacroux où, partant d'un sujet indéniablement typographique, de fil en aiguille, par enchaînement, nous enrichissions le sujet pour finalement parvenir à des conclusions plus solides, plus riches que si nous nous étions conduits en simples techniciens. C'est là l'_expression_ d'un penchant typiquement français : l'aspiration à traiter les choses à la manière et avec l'enthousiasme émulant des encyclopédistes. L'univers est un tout dans lequel l'explication des causes et donc leur recherche peut nous faire sortir, peu à peu mais manifestement, hors du domaine concerné, c'est-à-dire celui où le problème de la cause ou de l'explication s'est posé.
« Peut-être que pour comprendre la Nature, il faut la dépasser de beaucoup. » (Sade)
[De mémoire, la citation n'est donc peut-être pas exacte au mot près.]
On peut citer l'exemple de forums tels que le nôtre, ici, des forums où l'on s'est mis à proscrire rigoureusement le hors sujet et pour s'en assurer à mettre de plus le forum en mode modération : les messages n'étaient plus diffusés que si le modérateur décidait qu'ils puissent l'être. Le résultat ne s'est pas fait attendre. D'un forum aux discussions passionnantes et qui n'étaient jamais d'emblée hors sujet on est passé au silence. Désormais la circulation des messages s'est réduite à deux ou trois messages purement techniques par an. Voilà comment on tue un forum.
Le forum Typographie n'est absolument pas menacé de dérive, pas plus qu'il ne l'était du temps de Lacroux.
J. M.
> À bientôt.
> Yoann LE BARS
> http://le-bars.net/yoann/
> Diaspora* : ylebars AT framasphere.org
> La liste Typo — discussions typographiques
> Les archives : https://sympa.inria.fr/sympa/arc/typographie
> Désabonnement : <mailto:sympa_inria AT inria.fr?subject=unsubscribe%20typographie>
Envoyé: vendredi 8 mai 2020 à 10:46
De: "Jacques Melot" <jacques.melot AT isholf.is>
À: typographie AT listes.irisa.fr
Objet: Re: [typo] Le ou la Covid-19 ?...
> Salut à tous !
J. M.
> À bientôt.
> Yoann LE BARS
- Re: [typo] Le ou la Covid-19 ?..., (suite)
- Re: [typo] Le ou la Covid-19 ?..., Yoann LE BARS, 07/05/2020
- Re: [typo] Le ou la Covid-19 ?..., Jacques Melot, 07/05/2020
- Re: [typo] Le ou la Covid-19 ?..., Philippe MICHEL, 08/05/2020
- Re: [typo] Le ou la Covid-19 ?..., Yoann LE BARS, 08/05/2020
- Re: [typo] Le ou la Covid-19 ?..., Thierry Bouche, 08/05/2020
- Re: [typo] Le ou la Covid-19 ?..., Jacques Melot, 08/05/2020
- Re: [typo] Le ou la Covid-19 ?..., Alain Poncet, 08/05/2020
- Re: [typo] Le ou la Covid-19 ?..., Patrick Bideault, 08/05/2020
- Re: [typo] Le ou la Covid-19 ?..., jtombeur, 08/05/2020
- Re: [typo] Le ou la Covid-19 ?..., Marion Gevers, 09/05/2020
- RE: [typo] Le ou la Covid-19 ?..., diconoma, 08/05/2020
- Re: [typo] Le ou la Covid-19 ?..., Jacques PYRAT, 11/05/2020
- Re: [typo] Le ou la Covid-19 ?..., Eric Guichard, 11/05/2020
- Re: [typo] Le ou la Covid-19 ?..., Alexandre Pachot, 13/05/2020
- Re: [typo] Le ou la Covid-19 ?..., Jacques Melot, 12/05/2020
Archives gérées par MHonArc 2.6.18.
