- To: paul.leyland@gmail.com
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?
- Date: Sat, 13 Apr 2013 19:26:06 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Paul,
> > any news of your first factorization with CADO-NFS?
> Yes. Success, at last.
> Info:Calling Block-Wiedemann...
> Info:Adding characters...
> Info:25 vectors remaining after characters.
> Info:--------------------------------------------------------------------------
> Info:Square root
> Info:Preparing 25 dependency files
> Info:Testing dependency number 0...
> Info:Factorization was successful!
> Info:938162157466439248706242446740994666550032835844927071820158466530202226253
> [prime]
> Info:167833726244347054883741985866275357519984119769032664266435089934119867
> [prime]
> Info:Doing gcds with previously known composite factors
> Info:non-trivial factor:
> [prime]
> [prime]
> Info:Now: 2 prime factors, 0 composite factors
> Info:Factorization complete
> Info:All done!
congratulations!
> Nice to see it was not an ECM miss.
> This number was the last remaining sub-C150 composite from the
> generalized Cullen & Woodall tables at
> http://www.leyland.vispa.com/numth/factorization/cullen_woodall/cw.html
> and was the cofactor of GC(8,233) aka 233*8^233+1.
> With one exception, all the problems I had with the CADO-NFS
> factorization arose from my incompetence. I expected to hit various
> issues with a new (to me) and complex piece of software because I've had
> similar experiences in the past with the CWI suite and with
> msieve/ggnfs. CADO-NFS was certainly *much* easier to build than ggnfs!
thank you for your feedback.
> The one exception is that cadofactor.pl doesn't handle relative paths
> properly. Most of the time they work fine but the linear algebra fails.
> Someone with ability to create a bug report in the tracker should do so.
> I don't have the requisite permissions.
> Thanks all.
> Paul L.
it is very easy to create an account on gforge.inria.fr, moreover it will be
needed if you want to contribute...
Best regards,
Paul Z.
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, (continued)
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Paul Leyland, 04/05/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Zimmermann Paul, 04/06/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Paul Leyland, 04/07/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Zimmermann Paul, 04/07/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Paul Leyland, 04/08/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Paul Leyland, 04/10/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Emmanuel Thomé, 04/10/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Zimmermann Paul, 04/10/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Paul Leyland, 04/13/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Zimmermann Paul, 04/13/2013
