- To: Zimmermann Paul <Paul.Zimmermann@inria.fr>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?
- Date: Fri, 05 Apr 2013 09:29:32 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
On Fri, 2013-04-05 at 09:36 +0200, Zimmermann Paul wrote:
> Paul,
> I hope the issue is fixed on your side now.
Very probably. purge.log now ends with
new_nrows=19342364 new_ncols=19185740 (156624) at 400.68
excess < 0.10 * #primes. See -required_excess argument.
The previous version had an excess of 1749. #primes is ~53M so another
two or three iterations should be enough.
> Anyway we will change our code so that when an error occurs in purge,
> the factorization is aborted, to avoid it runs forever as you experienced.
Thanks. When I've finished this factorization and perhaps another one,
I'll put together a list of suggestions based on my experience with this
code and with other NFS implementations. I may even be able to
implement one or two of them!
Regards,
Paul (this one)
- [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Paul Leyland, 04/04/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Cyril Bouvier, 04/04/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Paul Leyland, 04/04/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Zimmermann Paul, 04/05/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Paul Leyland, 04/05/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Zimmermann Paul, 04/06/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Paul Leyland, 04/07/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Zimmermann Paul, 04/07/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Paul Leyland, 04/08/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Paul Leyland, 04/10/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Emmanuel Thomé, 04/10/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Zimmermann Paul, 04/10/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Paul Leyland, 04/13/2013
- Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?, Zimmermann Paul, 04/13/2013
