cado-nfs - Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?
  • To: paul.leyland@gmail.com
  • Cc: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] Possible problem with "purge!'s ARGV?
  • Date: Sat, 06 Apr 2013 14:05:46 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Paul,
> From: Paul Leyland <paul.leyland@gmail.com>
> Reply-To: paul.leyland@gmail.com
> On Fri, 2013-04-05 at 09:36 +0200, Zimmermann Paul wrote:
> > Paul,
> > I hope the issue is fixed on your side now.
> Very probably. purge.log now ends with
> new_nrows=19342364 new_ncols=19185740 (156624) at 400.68
> excess < 0.10 * #primes. See -required_excess argument.
> The previous version had an excess of 1749. #primes is ~53M so another
> two or three iterations should be enough.
any news of your first factorization with CADO-NFS?
> > Anyway we will change our code so that when an error occurs in purge,
> > the factorization is aborted, to avoid it runs forever as you experienced.
> Thanks. When I've finished this factorization and perhaps another one,
> I'll put together a list of suggestions based on my experience with this
> code and with other NFS implementations. I may even be able to
> implement one or two of them!
you are most welcome!
Paul
