- To: meng <qsmeng@126.com>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] makefb not found in distributed enviroment
- Date: Thu, 18 Jul 2013 09:24:34 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear Meng,
in your first message you say:
> where the master is a remote computer
this is strange, since as far as I know, the cadofactor script is supposed to
run "makefb" on the (local) computer where you run the script. What is you
"mach_desc" file? Can you send us the full output of the cadofactor script
with
the -v option?
Paul Zimmermann
- [Cado-nfs-discuss] makefb not found in distributed enviroment, meng, 07/18/2013
- Re: [Cado-nfs-discuss] makefb not found in distributed enviroment, Pierrick Gaudry, 07/18/2013
- Re: [Cado-nfs-discuss] makefb not found in distributed enviroment, meng, 07/18/2013
- Re: [Cado-nfs-discuss] makefb not found in distributed enviroment, Zimmermann Paul, 07/18/2013
- Re: [Cado-nfs-discuss] makefb not found in distributed enviroment, Zimmermann Paul, 07/19/2013
- Message not available
- Re: [Cado-nfs-discuss] makefb not found in distributed enviroment, Zimmermann Paul, 07/22/2013
- Re: [Cado-nfs-discuss] makefb not found in distributed enviroment, meng, 07/24/2013
- Re: [Cado-nfs-discuss] makefb not found in distributed enviroment, Alexander Kruppa, 07/24/2013
- Re: [Cado-nfs-discuss] makefb not found in distributed enviroment, meng, 07/25/2013
- Re: [Cado-nfs-discuss] makefb not found in distributed enviroment, Zimmermann Paul, 07/25/2013
- Re: [Cado-nfs-discuss] makefb not found in distributed enviroment, gcc version?, Zimmermann Paul, 07/22/2013
