cado-nfs - Re: [Cado-nfs-discuss] makefb not found in distributed enviroment
  • To: "Zimmermann Paul" <Paul.Zimmermann@inria.fr>
  • Cc: Alexander Kruppa <alexander.kruppa@inria.fr>, "cado-nfs-discuss@lists.gforge.inria.fr" <cado-nfs-discuss@lists.gforge.inria.fr>
  • Subject: Re: [Cado-nfs-discuss] makefb not found in distributed enviroment
  • Date: Thu, 18 Jul 2013 22:12:46 +0800 (CST)
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear Paul Zimmermann,
   At the hint of you, Shi Bai, Pierrick and Alex, I put the configuration of localhost at the bottom of the mach_desc and the makefb not found problem disappears.  Thank you all.
  But another  problem still exists. I succeeds in factor c90 in distributed mode with the two computers. With the same environment, when factoring rsa100, the screen says:
1. Info:Checking job: rsa100 localhost        2720000  2740000
        Warning:Dead?!
2. Info:Retrieving `rsa100.rels.2720000-2740000.gz' from `localhost'...
        Warning:File `/home/greatnet/c100/rsa100.rels.2720000-2740000' contains no useable data. Deleting...
3. Info:Starting new jobs...
Info:Starting job: rsa100 localhost        2720000  2740000
Maybe it is still makefb that causes this problem?
  Thank you all.
   Best regards.
Meng
At 2013-07-18 15:24:34,"Zimmermann Paul" <Paul.Zimmermann@inria.fr> wrote: >       Dear Meng, > >in your first message you say: > >> where the master  is a remote computer > >this is strange, since as far as I know, the cadofactor script is supposed to >run "makefb" on the (local) computer where you run the script. What is you >"mach_desc" file? Can you send us the full output of the cadofactor script with >the -v option? > >Paul Zimmermann
