cado-nfs - Re: [Cado-nfs-discuss] makefb not found in distributed enviroment
  • To: meng <qsmeng@126.com>
  • Cc: alexander.kruppa@inria.fr, cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] makefb not found in distributed enviroment
  • Date: Fri, 19 Jul 2013 09:31:48 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear Meng,
> Date: Thu, 18 Jul 2013 22:12:46 +0800 (CST)
> From: meng <qsmeng@126.com>
> Dear Paul Zimmermann,
> At the hint of you, Shi Bai, Pierrick and Alex, I put the configuration
> of localhost at the bottom of the mach_desc and the makefb not found
> problem disappears. Thank you all.
yes, the master binaries are searched in the first section.
> But another problem still exists. I succeeds in factor c90 in
> distributed mode with the two computers. With the same environment, when
> factoring rsa100, the screen says:
> 1. Info:Checking job: rsa100 localhost 2720000 2740000
> Warning:Dead?!
> 2. Info:Retrieving `rsa100.rels.2720000-2740000.gz' from `localhost'...
> Warning:File `/home/greatnet/c100/rsa100.rels.2720000-2740000'
> contains no useable data. Deleting...
> 3. Info:Starting new jobs...
> Info:Starting job: rsa100 localhost 2720000 2740000
> Maybe it is still makefb that causes this problem?
> Thank you all.
> Best regards.
> Meng
I don't know. Please can you restart cadofactor with the environment variable
CADO_DEBUG set and the -v option? Then please redo manually the "las" command
corresponding to rsa100.rels.2720000-2740000, and send us the corresponding
file (with rsa100.poly and rsa100.roots).
Btw, which version of CADO-NFS are you using?
Paul Zimmermann
