- To: "Zimmermann Paul" <Paul.Zimmermann@inria.fr>
- Cc: "cado-nfs-discuss@lists.gforge.inria.fr" <cado-nfs-discuss@lists.gforge.inria.fr>
- Subject: Re: [Cado-nfs-discuss] makefb not found in distributed enviroment
- Date: Thu, 25 Jul 2013 17:12:02 +0800 (CST)
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear Paul:
Commit version f78e49c have not this problem. I don't know if this can help you in finding reason.
By the way, I am trying to install openmpi with the following problem.
./scripts/mpi_imrecv_f90.f90.sh /home/greatnet/openmpi-1.7.2/ompi/mpi/fortran/use-mpi-tkr > mpi_imrecv_f90.f90
../../../../libtool: line 1128: gfortran: command not found
However, I am sure that gfortran exists and can run in any directory. When I add "$PATH" after line 1128 in libtool, and then remake, it display "/usr/bin:/bin". Yes, indeed my gcc is not in /usr/bin ,/bin. How to add gcc to that path or how to solve my problem?
Thank you.
Regards,
Meng
Thank you.
Regards,
Meng
At 2013-07-25 15:39:37,"Zimmermann Paul" <Paul.Zimmermann@inria.fr> wrote: > Dear Meng, > >> #0 0x00000039f5a7a064 in memset () from /lib64/libc.so.6 >> #1 0x0000000000413bbe in init_rat_norms_bucket_region ( > >I got a similar problem with the development version: > >https://gforge.inria.fr/tracker/index.php?func=detail&aid=16159 > >It is under investigation. > >Paul Zimmermann
- Re: [Cado-nfs-discuss] makefb not found in distributed enviroment, (continued)
- Re: [Cado-nfs-discuss] makefb not found in distributed enviroment, Pierrick Gaudry, 07/18/2013
- Re: [Cado-nfs-discuss] makefb not found in distributed enviroment, meng, 07/18/2013
- Re: [Cado-nfs-discuss] makefb not found in distributed enviroment, Zimmermann Paul, 07/18/2013
- Re: [Cado-nfs-discuss] makefb not found in distributed enviroment, Zimmermann Paul, 07/19/2013
- Message not available
- Re: [Cado-nfs-discuss] makefb not found in distributed enviroment, Zimmermann Paul, 07/22/2013
- Re: [Cado-nfs-discuss] makefb not found in distributed enviroment, meng, 07/24/2013
- Re: [Cado-nfs-discuss] makefb not found in distributed enviroment, Alexander Kruppa, 07/24/2013
- Re: [Cado-nfs-discuss] makefb not found in distributed enviroment, meng, 07/25/2013
- Re: [Cado-nfs-discuss] makefb not found in distributed enviroment, Zimmermann Paul, 07/25/2013
- Re: [Cado-nfs-discuss] makefb not found in distributed enviroment, gcc version?, Zimmermann Paul, 07/22/2013
