- To:
- Subject: Re: [cgal-discuss] Assertion in arrangement_2
- Date: Wed, 28 Feb 2007 14:24:28 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:to:subject:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references; b=AyIvyICkQmDFn9Pv2QVFcVgS118a8G20CTyFCKrkTnqgnxSDRhPUCWvxEio7CZNPf3bvSpqJ0SDlMwkPE2YTcM0mFQ1HKTLBvBdewnAWGOin6Zv72BhwcQJV11bOPMmgHwnYuLcw/9I1NQdmxkW3hm09VJIxxCI546B+zAeFD04=
Hi again
I hope someone can help me out here... Anyway I did a little bit more
research and these are the x/y-values of cv.left(), cv.right() and p.
cv.left(): -4.241547e+01, 9.937383e-01,
cv.right(): -4.241547e+01, 3.496869e+00,
p: -4.241547e+01, 2.289501e+00
Looks like it is a vertical edge, which seems a bit odd... Can anyone help?
- Jens
On 2/28/07,
wrote:
Hi
I get an assertion when I try to build an arrangement with a lot of lines:
CGAL error: precondition violation!
Expr: Segment_assertions::_assert_is_point_on (p, cv, Has_exact_division()) &&
compare_xy(cv.left(), p) == SMALLER && compare_xy(cv.right(), p) == LARGER
File: /Users/jegeblad/CGAL_Install/include/CGAL/Arr_segment_traits_2.h
Line: 730
Abort trap
Does anyone know what could cause this problem? Could it be a floating-point
problem?
Best - Jens
- Re: [cgal-discuss] Assertion in arrangement_2, Jens Egeblad, 03/02/2007
- Re: [cgal-discuss] Assertion in arrangement_2, Efi Fogel, 03/04/2007
- algorithms for polygons, Iosif Pinelis, 03/04/2007
- Re: [cgal-discuss] algorithms for polygons, Mariette Yvinec, 03/06/2007
- Re: [cgal-discuss] algorithms for polygons, Iosif Pinelis, 03/06/2007
- Re: [cgal-discuss] algorithms for polygons, Andreas Fabri, 03/06/2007
- Re: [cgal-discuss] Assertion in arrangement_2, Efraim Fogel, 03/06/2007
- Re: [cgal-discuss] Assertion in arrangement_2, Jens Egeblad, 03/07/2007
- Re: [cgal-discuss] Assertion in arrangement_2, Andreas Fabri, 03/07/2007
