- To:
- Subject: Re: [cgal-discuss] algorithms for polygons
- Date: Tue, 06 Mar 2007 17:07:21 +0100
Hello,
With a sweep you can detect intersections of line segments.
When the line segments of a polygon intersect it is not simple.
For convexity: find the leftmost point of the polygon and
walk along the polygon. On the upper side you should always
progress in x-direction, and three consecutive vertices should
always make a right turn.
hope this helps. You can't expect a PhD thesis to describe the above.
andreas
Iosif Pinelis wrote:
Hi,
I am a mathematician and a complete novice, and don't know C or C++. My _main interest_ at this point is to find out what algorithms are used in CGAL to check such polygon properties as the simplicity and convexity, as well as the rigorous definitions of these notions as assumed in CGAL. I have been able to find online only extremely brief descriptions of the corresponding pieces of code. As for the polygon simplicity, it is said there that a sweep algorithm is used, but no details are given. As for the polygon convexity, nothing at all is said about the algorithm. In no case I have been able to find rigorous definitions.
For the simplicity, the sweep algorithm is probably some variant of the famous Bentley-Ottmann algorithm
described in all text book on computational geometry.
For convexity, I don't know but it might as well be a naive test on all successive polygon angles....
Thank you Mariette for your response. Such a naive test would be pretty bad, since it won't work unless the polygon is first tested for simplicity. But the simplicity test in CGAL is said to require Omega(n log n) operations (and apparently this lower bound cannot be improved), while the convexity can be tested (not naively) in O(n) operations (see LEDA or http://arxiv.org/abs/cs.CG/0609141 or http://arxiv.org/abs/cs.CG/0701045).
All the more, I would like to find out exactly what algorithms and what exact definitions (of polygon simplicity, convexity, etc.) are used in such tests in CGAL or, short of that, what the corresponding code is. Are those algorithms essentially the same as in LEDA? (LEDA has detailed enough descriptions of those algorithms.)
CGAL is open-source, no? I guess this should mean that all of its code is accessible. How then could I look at it? Many thanks for any further help.
Iosif Pinelis
I guess I could try to read the CGAL C++ code for these algorithms, but I can't find such code either in the CGAL download. I have tried to install CGAL on Windows XP (after installing Visual C++ 2005 Express edition and also boost), but the installation fails to complete. A CGAL installation manual says that only Visual C++ 2003 (version 7.1) is supported by CGAL, but 7.1 does not appear to be available any more, as it has been replaced by 8.0 by Microsoft.
Your help concerning the algorithms (and also the installation) would be very valuable to me. Thank you.
Iosif Pinelis
- Re: [cgal-discuss] Assertion in arrangement_2, Jens Egeblad, 03/02/2007
- Re: [cgal-discuss] Assertion in arrangement_2, Efi Fogel, 03/04/2007
- algorithms for polygons, Iosif Pinelis, 03/04/2007
- Re: [cgal-discuss] algorithms for polygons, Mariette Yvinec, 03/06/2007
- Re: [cgal-discuss] algorithms for polygons, Iosif Pinelis, 03/06/2007
- Re: [cgal-discuss] algorithms for polygons, Andreas Fabri, 03/06/2007
- Re: [cgal-discuss] Assertion in arrangement_2, Efraim Fogel, 03/06/2007
- Re: [cgal-discuss] Assertion in arrangement_2, Jens Egeblad, 03/07/2007
- Re: [cgal-discuss] Assertion in arrangement_2, Andreas Fabri, 03/07/2007
- Polygon transformation, Olivier Tournaire, 03/07/2007
