- To:
- Subject: Re: [cgal-discuss] Assertion in arrangement_2
- Date: Wed, 28 Feb 2007 17:33:50 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:to:subject:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references; b=k6TuNovml4ut/2/83G5yzp1HtgiiyLhvwOfufDajMRxpPUFWCWTD+iVNU0lsJ9JyHlVfyRrD8swB1ObB/j+VxGgUCrno3MrRJjvWvSQDST+4C168nrotXZhXMebKPP0cvH9UnDgFCFtITPD63/SkenKuoPH68rP+1gYIo4nbsR4=
Sorry to spam you like this.
Ok, so as I suspected it seems like my problem has to do with
precision. I thought arrangement_2 was very robust. Am I missing
something?
I have been using doubles but I have no problem with MP_Float.
I would really like to use an efficient number type since this is a
performance critical applications.
Is MP_Float efficient enough or does anyone have better idea?
Best - Jens
On 2/28/07, Jens Egeblad
wrote:
Hi again
I hope someone can help me out here... Anyway I did a little bit more
research and these are the x/y-values of cv.left(), cv.right() and p.
cv.left(): -4.241547e+01, 9.937383e-01,
cv.right(): -4.241547e+01, 3.496869e+00,
p: -4.241547e+01, 2.289501e+00
Looks like it is a vertical edge, which seems a bit odd... Can anyone help?
- Jens
On 2/28/07,
wrote:
> Hi
> I get an assertion when I try to build an arrangement with a lot of lines:
> CGAL error: precondition violation!
> Expr: Segment_assertions::_assert_is_point_on (p, cv, Has_exact_division()) &&
compare_xy(cv.left(), p) == SMALLER && compare_xy(cv.right(), p) == LARGER
> File: /Users/jegeblad/CGAL_Install/include/CGAL/Arr_segment_traits_2.h
> Line: 730
> Abort trap
> Does anyone know what could cause this problem? Could it be a
floating-point problem?
> Best - Jens
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- Re: [cgal-discuss] Assertion in arrangement_2, Jens Egeblad, 03/02/2007
- Re: [cgal-discuss] Assertion in arrangement_2, Efi Fogel, 03/04/2007
- algorithms for polygons, Iosif Pinelis, 03/04/2007
- Re: [cgal-discuss] algorithms for polygons, Mariette Yvinec, 03/06/2007
- Re: [cgal-discuss] algorithms for polygons, Iosif Pinelis, 03/06/2007
- Re: [cgal-discuss] algorithms for polygons, Andreas Fabri, 03/06/2007
- Re: [cgal-discuss] Assertion in arrangement_2, Efraim Fogel, 03/06/2007
- Re: [cgal-discuss] Assertion in arrangement_2, Jens Egeblad, 03/07/2007
- Re: [cgal-discuss] Assertion in arrangement_2, Andreas Fabri, 03/07/2007
- Polygon transformation, Olivier Tournaire, 03/07/2007
