- To:
- Subject: Re: [cgal-discuss] algorithms for polygons
- Date: Tue, 06 Mar 2007 10:19:26 +0100
Iosif Pinelis wrote:
Hi,
I am a mathematician and a complete novice, and don't know C or C++. My _main interest_ at this point is to find out what algorithms are used in CGAL to check such polygon properties as the simplicity and convexity, as well as the rigorous definitions of these notions as assumed in CGAL. I have been able to find online only extremely brief descriptions of the corresponding pieces of code. As for the polygon simplicity, it is said there that a sweep algorithm is used, but no details are given. As for the polygon convexity, nothing at all is said about the algorithm. In no case I have been able to find rigorous definitions.
For the simplicity, the sweep algorithm is probably some variant of the famous Bentley-Ottmann algorithm
described in all text book on computational geometry.
For convexity, I don't know but it might as well be a naive test on all successive polygon angles....
I guess I could try to read the CGAL C++ code for these algorithms, but I can't find such code either in the CGAL download. I have tried to install CGAL on Windows XP (after installing Visual C++ 2005 Express edition and also boost), but the installation fails to complete. A CGAL installation manual says that only Visual C++ 2003 (version 7.1) is supported by CGAL, but 7.1 does not appear to be available any more, as it has been replaced by 8.0 by Microsoft.
Your help concerning the algorithms (and also the installation) would be very valuable to me. Thank you.
Iosif Pinelis
- Re: [cgal-discuss] Assertion in arrangement_2, Jens Egeblad, 03/02/2007
- Re: [cgal-discuss] Assertion in arrangement_2, Efi Fogel, 03/04/2007
- algorithms for polygons, Iosif Pinelis, 03/04/2007
- Re: [cgal-discuss] algorithms for polygons, Mariette Yvinec, 03/06/2007
- Re: [cgal-discuss] algorithms for polygons, Iosif Pinelis, 03/06/2007
- Re: [cgal-discuss] algorithms for polygons, Andreas Fabri, 03/06/2007
- Re: [cgal-discuss] Assertion in arrangement_2, Efraim Fogel, 03/06/2007
- Re: [cgal-discuss] Assertion in arrangement_2, Jens Egeblad, 03/07/2007
- Re: [cgal-discuss] Assertion in arrangement_2, Andreas Fabri, 03/07/2007
- Polygon transformation, Olivier Tournaire, 03/07/2007
