- To:
- Subject: Re: [cgal-discuss] algorithms for polygons
- Date: Tue, 06 Mar 2007 11:55:03 -0500
Andreas Fabri wrote:
Hello,
With a sweep you can detect intersections of line segments.
When the line segments of a polygon intersect it is not simple.
For convexity: find the leftmost point of the polygon and
walk along the polygon. On the upper side you should always
progress in x-direction, and three consecutive vertices should
always make a right turn.
hope this helps. You can't expect a PhD thesis to describe the above.
Thanks Andreas. My question was not how one could test the polygon simplicity or convexity. Rather, it was this: specifically in CGAL, exactly what definitions of the polygon simplicity, convexity, etc. are assumed and what corresponding algorithms are used?
There are many disparate definitions of these notions in the literature and on the web, most of them informal and some even contradictory in themselves; and oftentimes (perhaps more often than not) these terms are used without any definition. It should not then be very surprising that claims about these notions in a number of places are simply incorrect. I think rigorous definitions are important, because otherwise we end up with "definitions" like this: "a polygon is convex if and only if my own test says it is so". Such practice would result in as many definitions of a notion as there are tests for it! Unfortunately, this or something pretty close to this kind of practice seems to be the case today.
Concerning your particular suggestions, one may ask: how do you define the notion of polygon convexity (say) or even that of a polygon itself? And how do you define the "upper side" of a general (not necessarily simple) polygon? And what about a lower side, etc.?
But, again, my questions are about CGAL specifically. Thanks again for any further help concerning CGAL.
Iosif Pinelis
Iosif Pinelis wrote:
Hi,
I am a mathematician and a complete novice, and don't know C or C++. My _main interest_ at this point is to find out what algorithms are used in CGAL to check such polygon properties as the simplicity and convexity, as well as the rigorous definitions of these notions as assumed in CGAL. I have been able to find online only extremely brief descriptions of the corresponding pieces of code. As for the polygon simplicity, it is said there that a sweep algorithm is used, but no details are given. As for the polygon convexity, nothing at all is said about the algorithm. In no case I have been able to find rigorous definitions.
For the simplicity, the sweep algorithm is probably some variant of the famous Bentley-Ottmann algorithm
described in all text book on computational geometry.
For convexity, I don't know but it might as well be a naive test on all successive polygon angles....
Thank you Mariette for your response. Such a naive test would be pretty bad, since it won't work unless the polygon is first tested for simplicity. But the simplicity test in CGAL is said to require Omega(n log n) operations (and apparently this lower bound cannot be improved), while the convexity can be tested (not naively) in O(n) operations (see LEDA or http://arxiv.org/abs/cs.CG/0609141 or http://arxiv.org/abs/cs.CG/0701045).
All the more, I would like to find out exactly what algorithms and what exact definitions (of polygon simplicity, convexity, etc.) are used in such tests in CGAL or, short of that, what the corresponding code is. Are those algorithms essentially the same as in LEDA? (LEDA has detailed enough descriptions of those algorithms.)
CGAL is open-source, no? I guess this should mean that all of its code is accessible. How then could I look at it? Many thanks for any further help.
Iosif Pinelis
I guess I could try to read the CGAL C++ code for these algorithms, but I can't find such code either in the CGAL download. I have tried to install CGAL on Windows XP (after installing Visual C++ 2005 Express edition and also boost), but the installation fails to complete. A CGAL installation manual says that only Visual C++ 2003 (version 7.1) is supported by CGAL, but 7.1 does not appear to be available any more, as it has been replaced by 8.0 by Microsoft.
Your help concerning the algorithms (and also the installation) would be very valuable to me. Thank you.
Iosif Pinelis
- Re: [cgal-discuss] Assertion in arrangement_2, Jens Egeblad, 03/02/2007
- Re: [cgal-discuss] Assertion in arrangement_2, Efi Fogel, 03/04/2007
- algorithms for polygons, Iosif Pinelis, 03/04/2007
- Re: [cgal-discuss] algorithms for polygons, Mariette Yvinec, 03/06/2007
- Re: [cgal-discuss] algorithms for polygons, Iosif Pinelis, 03/06/2007
- Re: [cgal-discuss] algorithms for polygons, Andreas Fabri, 03/06/2007
- Re: [cgal-discuss] Assertion in arrangement_2, Efraim Fogel, 03/06/2007
- Re: [cgal-discuss] Assertion in arrangement_2, Jens Egeblad, 03/07/2007
- Re: [cgal-discuss] Assertion in arrangement_2, Andreas Fabri, 03/07/2007
- Polygon transformation, Olivier Tournaire, 03/07/2007
