cgal-discuss - Re:[cgal-discuss] CGAL::Polyhedron_incremental_builder_3<HDS> problem
  • To: "cgal-discuss" <>
  • Subject: Re:[cgal-discuss] CGAL::Polyhedron_incremental_builder_3<HDS> problem
  • Date: Tue, 17 Jul 2007 20:54:26 +0200
Am Tue, 17 Jul 2007 20:28:10 +0200 (CEST), schrieb
Hi!
>> (Is there some automatism which can do this automatically?
>> What is the best practice to fix those triangles?)
>Usually, you do not extract these triangles from your 3D triangulation
>randomly: you extract a triangle as the neighbor of an already extracted
>triangle. You just have to check that you give the newly extracted
>triangle the same orientation as its predecessor.
In my case, this must not be true. I iterate over a triangulation
using a the facet iterator. If a facet fullfills a criterion I add it
to my list of points and facets and later they get inserted into a
Polyhedron. As you can see, it is possible to happen, that there are
faces which are not of the same orientation. What can I do? Fixing
every face is going to be an intensive task which I want to avoid
if possible.
Best regards,
,yours Thomas Zangl, Bakk.rer.soc.oec. -
- Freelancer - IT Consulting & Software Development -
- Student of Software Development-Economy (Master) -
