cgal-discuss - Re: Re:[cgal-discuss] CGAL::Polyhedron_incremental_builder_3<HDS> problem
  • To:
  • Subject: Re: Re:[cgal-discuss] CGAL::Polyhedron_incremental_builder_3<HDS> problem
  • Date: Wed, 18 Jul 2007 19:46:52 +0200
Sorry, I must ask more precisely. What kind of triangulation do you use?
Is it from CGAL? If yes, which triangulation?
On Wed, 2007-07-18 at 16:51 +0200, Thomas Zangl - Home wrote:
> Am Wed, 18 Jul 2007 16:15:05 +0200, schrieb "Peter Hachenberger"
> Hi!
> >How do you extract the vertices from a triangle? I'm not completely sure
> >how our triangulation works, but I would assume that the vertices of a
> >facet should be oriented consistently if you triangulate an orientable
> >surface.
> I extract them like this:
> Rt_Facet_iterator fIt = t.facets_begin();
> Rt_Facet_iterator fEnd = t.facets_end();
> if ( fIt == fEnd ) { std::cout << "no faces found" << std::endl ;}
> else {
> while(fIt != fEnd) {
> Rt_Cell_handle cell = fIt->first;
> // this is the index of the facet's opposite vertex
> int faceIndex = fIt->second;
> // "info" is a simple int which holds an index, assigned
> // upon insertion into the triangulation.
> // bascially its just 0, 1, 2, 3, 4, 5 ...
> int a = cell->vertex((faceIndex+1) % 4)->info();
> int b = cell->vertex((faceIndex+2) % 4)->info();
> int c = cell->vertex((faceIndex+3) % 4)->info();
> // I then test here if the triangle is useful for later
> // processing..
> if (isUseFull) {
> intTriple faceOfIndices(a,b,c);
> complex.push_back(faceOfIndices);
> So I end up with a vector of intTriple (which hold the indices of the
> points forming each facet in the vector). And I have another vector
> where I have a mapping index -> point which I need later for building
> the Polyhedron.
> Nothing special :-)
> Best regards,
> ,yours Thomas Zangl, Bakk.rer.soc.oec. -
> - Freelancer - IT Consulting & Software Development -
> - Student of Software Development-Economy (Master) -
