- To:
- Subject: Re: Re:[cgal-discuss] CGAL::Polyhedron_incremental_builder_3<HDS> problem
- Date: Wed, 18 Jul 2007 20:10:49 +0200
OK, that explains things. The stuff that you triangulate, what kind of
data is it? I ask, because if you just want to triangulate a surface,
you should better write traits classes such that you can use
Triangulation_2. That's far more easy.
Peter
On Wed, 2007-07-18 at 20:00 +0200, Thomas Zangl - Home wrote:
> Am Wed, 18 Jul 2007 19:46:52 +0200, schrieb "Peter Hachenberger"
> Hi!
> >Sorry, I must ask more precisely. What kind of triangulation do you use?
> >Is it from CGAL? If yes, which triangulation?
> Sure its CGAL :-)
> I am using a Regular_Triangulation_3. These are my typedefs in cause
> you need more details:
> typedef CGAL::Exact_predicates_exact_constructions_kernel K;
> typedef CGAL::Regular_triangulation_filtered_traits_3<K> Traits;
> typedef CGAL::Triangulation_vertex_base_with_info_3<int, Traits> Vb;
> typedef CGAL::Regular_triangulation_cell_base_3<Traits> Cb;
> typedef CGAL::Triangulation_data_structure_3<Vb, Cb>
> Tds;
> typedef CGAL::Regular_triangulation_3<Traits, Tds> Regular_triangulation;
> typedef Regular_triangulation::Triangle Rt_Triangle;
> typedef Regular_triangulation::Facet Rt_Facet;
> Best regards,
> ,yours Thomas Zangl, Bakk.rer.soc.oec. -
> - Freelancer - IT Consulting & Software Development -
> - Student of Software Development-Economy (Master) -
- Re:[cgal-discuss] CGAL::Polyhedron_incremental_builder_3<HDS> problem, (continued)
- Re:[cgal-discuss] CGAL::Polyhedron_incremental_builder_3<HDS> problem, Camille . Wormser, 07/17/2007
- Re: [cgal-discuss] CGAL::Polyhedron_incremental_builder_3<HDS> problem, Michael George, 07/17/2007
- Re: [cgal-discuss] CGAL::Polyhedron_incremental_builder_3<HDS> problem, Camille . Wormser, 07/17/2007
- Re:[cgal-discuss] CGAL::Polyhedron_incremental_builder_3<HDS> problem, Thomas Zangl - Home, 07/17/2007
- Re: Re:[cgal-discuss] CGAL::Polyhedron_incremental_builder_3<HDS> problem, Peter Hachenberger, 07/18/2007
- Re:[cgal-discuss] CGAL::Polyhedron_incremental_builder_3<HDS> problem, Thomas Zangl - Home, 07/18/2007
