cgal-discuss - Re: Re:[cgal-discuss] CGAL::Polyhedron_incremental_builder_3<HDS> problem
  • To:
  • Subject: Re: Re:[cgal-discuss] CGAL::Polyhedron_incremental_builder_3<HDS> problem
  • Date: Wed, 18 Jul 2007 16:15:05 +0200
Hi,
How do you extract the vertices from a triangle? I'm not completely sure
how our triangulation works, but I would assume that the vertices of a
facet should be oriented consistently if you triangulate an orientable
surface.
Peter
On Tue, 2007-07-17 at 20:54 +0200, Thomas Zangl - Home wrote:
> Am Tue, 17 Jul 2007 20:28:10 +0200 (CEST), schrieb
> Hi!
> >> (Is there some automatism which can do this automatically?
> >> What is the best practice to fix those triangles?)
> >Usually, you do not extract these triangles from your 3D triangulation
> >randomly: you extract a triangle as the neighbor of an already extracted
> >triangle. You just have to check that you give the newly extracted
> >triangle the same orientation as its predecessor.
> In my case, this must not be true. I iterate over a triangulation
> using a the facet iterator. If a facet fullfills a criterion I add it
> to my list of points and facets and later they get inserted into a
> Polyhedron. As you can see, it is possible to happen, that there are
> faces which are not of the same orientation. What can I do? Fixing
> every face is going to be an intensive task which I want to avoid
> if possible.
> Best regards,
> ,yours Thomas Zangl, Bakk.rer.soc.oec. -
> - Freelancer - IT Consulting & Software Development -
> - Student of Software Development-Economy (Master) -
