- To:
- Subject: Re: [cgal-discuss] Regular_triangulation_3 Bug, CGAL 3.3
- Date: Mon, 30 Jul 2007 16:49:03 +0200
I had a quicklook at your files and they are not easy to read...
could you better isolate the problem?
In your first test, it seems that the program crashes only AFTER the triangulation is built ("Starting Postprocessing..."), right?
best
Monique
Bernhard Kornberger wrote:
I've encountered a bug in the 3-dimensional Regular Triangulation:
CGAL 3.3:
typedef CGAL::Regular_triangulation_filtered_traits_3<K> RegtrTraits;
typedef CGAL::Regular_triangulation_3<RegtrTraits> Regular_triangulation;
Starting my software with:
./minkowski -i input1 -j input2
...I get this output:
Starting All...
Starting PowerDiagram Construction...
Reading input1
Number of spheres: 125
Reading input2
Number of spheres: 46
Triangulator: inserting 8 bounding spheres
lower=-2396.4, upper=2595.59
a
b
c
d
e
f
g
h
Number of spheres to be visualized in union1.list: 125
Number of spheres to be visualized in union2.list: 46
Time for PowerDiagram Construction: [2.2 s]
****** Starting the postprocessing of 2213 spheres, tolerance=1 *********
CGAL error: assertion violation!
Expr: !(i>s)
File: /opt/CGAL330/include/CGAL/Interval_nt.h
Line: 77
Explanation: Variable used before being initialized (or CGAL bug)
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: !(i>s)
Line: 77
Aborted (core dumped)
Starting the Software in valgrind:
valgrind ./minkowski -i input1 -j input2
...it crashes even earlier:
/usr/bin/g++ -pg -I../../include -Wall -frounding-math '-I/opt/CGAL330/include' -I/usr/include/qt3 -O3 -c Triangulator.cpp
/usr/bin/g++ -o minkowski minkowski.o Triangulator.o UnionOfSpheres.o VisualizerGV.o -lm -ldl -pg '-L/opt/CGAL330/lib' -L/usr/lib/qt3 -Wl,-R/opt/CGAL330/lib/i686_Linux-2.6_g++-4.1.2:/usr/lib/qt3 -lCGAL -lCGALcore++ -lCGALQt -lCGALimageIO -lCGALPDB -lqt-mt -lGL -lGLU -lz -lmpfr -lgmpxx -lgmp -lX11 -lboost_program_options -lm
==5523== Memcheck, a memory error detector.
==5523== Copyright (C) 2002-2006, and GNU GPL'd, by Julian Seward et al.
==5523== Using LibVEX rev 1658, a library for dynamic binary translation.
==5523== Copyright (C) 2004-2006, and GNU GPL'd, by OpenWorks LLP.
==5523== Using valgrind-3.2.1-Debian, a dynamic binary instrumentation framework.
==5523== Copyright (C) 2000-2006, and GNU GPL'd, by Julian Seward et al.
==5523== For more details, rerun with: -v
==5523==
Starting All...
Reading input1
Reading input2
a
b
c
d
e
f
CGAL error: precondition violation!
Expr: orientation(p0, p1, p2, p3) == POSITIVE
File: /opt/CGAL330/include/CGAL/Regular_triangulation_3.h
Line: 890
terminate called after throwing an instance of 'std::logic_error'
what(): basic_string::_S_construct NULL not valid
==5523==
==5523== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 97 from 1)
==5523== malloc/free: in use at exit: 1,165,510 bytes in 898 blocks.
==5523== malloc/free: 3,772 allocs, 2,874 frees, 1,309,384 bytes allocated.
==5523== For counts of detected errors, rerun with: -v
==5523== searching for pointers to 898 not-freed blocks.
==5523== checked 2,218,584 bytes.
==5523==
==5523== LEAK SUMMARY:
==5523== definitely lost: 0 bytes in 0 blocks.
==5523== possibly lost: 222 bytes in 7 blocks.
==5523== still reachable: 1,165,288 bytes in 891 blocks.
==5523== suppressed: 0 bytes in 0 blocks.
==5523== Reachable blocks (those to which a pointer was found) are not shown.
==5523== To see them, rerun with: --show-reachable=yes
..however, nothing happens if the assertions are disabled. You can try
it with my code: dist.ist.tugraz.at/test.tar.bz2
(includes and typedefs in common.h, the error occurs in
Triangulator.cpp)
g++ (GCC) 4.1.2 (Ubuntu 4.1.2-0ubuntu4)
Options:
-pg \
-I../../include \
$(CGAL_CXXFLAGS) \
$(LONG_NAME_PROBLEM_CXXFLAGS) \
-O3
Best
Bernhard
- Regular_triangulation_3 Bug, CGAL 3.3, Bernhard Kornberger, 07/30/2007
- Re: [cgal-discuss] Regular_triangulation_3 Bug, CGAL 3.3, Monique . Teillaud, 07/30/2007
- Re: [cgal-discuss] Regular_triangulation_3 Bug, CGAL 3.3, Bernhard Kornberger, 07/31/2007
- Re: [cgal-discuss] Regular_triangulation_3 Bug, CGAL 3.3, Andreas Fabri, 07/31/2007
- Re: [cgal-discuss] Regular_triangulation_3 Bug, CGAL 3.3, Monique . Teillaud, 07/31/2007
- Re: [cgal-discuss] Regular_triangulation_3 Bug, CGAL 3.3, Camille Wormser, 07/31/2007
