- To:
- Subject: Re: [cgal-discuss] Regular_triangulation_3 Bug, CGAL 3.3
- Date: Tue, 31 Jul 2007 17:37:04 +0200
Bernhard Kornberger a écrit :
This solves the problem. Sure, this is documented, but a programmerI agree with you.
can not expect that behavior.
When I checked your code, I assumed that it was a bug (and not a feature...), and I corrected it. I attach modified versions of the HalfedgeDS_items_decorator and the Polyhedron_builder_3 which work "as expected" (that is, when the Supports_face_plane flag is true, the equation is computed).
With these files, your program works fine (without valgrind...).
And even worse, the function returnsThe problem is that the Supports_face_plane flag triggers a curious behavior: when it is true, a Plane data member is present in the HDS Face base, BUT it is not computed. Even stranger is the fact that Supports_face_plane is true by default. If it were false, you would have had a compile time error, as expected.
a wrong plane instead of some error message. Shouldn't the function
have an assertion like assert(plane_is_valid()); ??
Camille
// Copyright (c) 1997 Utrecht University (The Netherlands), // ETH Zurich (Switzerland), Freie Universitaet Berlin (Germany), // INRIA Sophia-Antipolis (France), Martin-Luther-University Halle-Wittenberg // (Germany), Max-Planck-Institute Saarbruecken (Germany), RISC Linz (Austria), // and Tel-Aviv University (Israel). All rights reserved. // // This file is part of CGAL (www.cgal.org); you can redistribute it and/or // modify it under the terms of the GNU Lesser General Public License as // published by the Free Software Foundation; version 2.1 of the License. // See the file LICENSE.LGPL distributed with CGAL. // // Licensees holding a valid commercial license may use this file in // accordance with the commercial license agreement provided with the software. // // This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE // WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. // // $URL: svn+ssh:///svn/cgal/trunk/HalfedgeDS/include/CGAL/HalfedgeDS_items_decorator.h $ // $Id: HalfedgeDS_items_decorator.h 28567 2006-02-16 14:30:13Z lsaboret $ // // // Author(s) : Lutz Kettner <> #ifndef CGAL_HALFEDGEDS_ITEMS_DECORATOR_H #define CGAL_HALFEDGEDS_ITEMS_DECORATOR_H 1 #include <CGAL/basic.h> #include <cstddef> #warning -x-x-x-x-x-x-x-x-x- LOCAL HalfedgeDS_items_decorator.h CGAL_BEGIN_NAMESPACE template < class p_HDS > class HalfedgeDS_items_decorator { public: // TYPES // ---------------------------------- typedef p_HDS HDS; typedef p_HDS HalfedgeDS; typedef typename HDS::Traits Traits; typedef typename HDS::Vertex Vertex; typedef typename HDS::Halfedge Halfedge; typedef typename HDS::Face Face; typedef typename HDS::Vertex_handle Vertex_handle; typedef typename HDS::Vertex_const_handle Vertex_const_handle; typedef typename HDS::Vertex_iterator Vertex_iterator; typedef typename HDS::Vertex_const_iterator Vertex_const_iterator; typedef typename HDS::Halfedge_handle Halfedge_handle; typedef typename HDS::Halfedge_const_handle Halfedge_const_handle; typedef typename HDS::Halfedge_iterator Halfedge_iterator; typedef typename HDS::Halfedge_const_iterator Halfedge_const_iterator; typedef typename HDS::Face_handle Face_handle; typedef typename HDS::Face_const_handle Face_const_handle; typedef typename HDS::Face_iterator Face_iterator; typedef typename HDS::Face_const_iterator Face_const_iterator; typedef typename HDS::size_type size_type; typedef typename HDS::difference_type difference_type; typedef typename HDS::iterator_category iterator_category; // The following types are equal to either `Tag_true' or `Tag_false', // dependent whether the named feature is supported or not. typedef typename HDS::Supports_vertex_halfedge Supports_vertex_halfedge; typedef typename HDS::Supports_halfedge_prev Supports_halfedge_prev; typedef typename HDS::Supports_halfedge_vertex Supports_halfedge_vertex; typedef typename HDS::Supports_halfedge_face Supports_halfedge_face; typedef typename HDS::Supports_face_halfedge Supports_face_halfedge; typedef typename HDS::Supports_removal Supports_removal; protected: typedef typename Vertex::Base VBase; typedef typename Halfedge::Base HBase; typedef typename Halfedge::Base_base HBase_base; typedef typename Face::Base FBase; // MODIF vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv typedef typename FBase::Supports_face_plane Supports_face_plane; typedef typename FBase::Plane Plane; // MODIF ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ public: // CREATION // ---------------------------------- HalfedgeDS_items_decorator() {} // Access Functions // ---------------------------------- Halfedge_handle get_vertex_halfedge( Vertex_handle v) const { // returns the incident halfedge of v if supported, // `Halfedge_handle()' otherwise. return get_vertex_halfedge( v, Supports_vertex_halfedge()); } Vertex_handle get_vertex( Halfedge_handle h) const { // returns the incident vertex of h if supported, // `Vertex_handle()' otherwise. return get_vertex( h, Supports_halfedge_vertex()); } Halfedge_handle get_prev( Halfedge_handle h) const { // returns the previous halfedge of h if supported, // `Halfedge_handle()' otherwise. return get_prev( h, Supports_halfedge_prev()); } Halfedge_handle find_prev( Halfedge_handle h) const { // returns the previous halfedge of h. Uses the `prev()' method if // supported or performs a search around the face using `next()'. return find_prev( h, Supports_halfedge_prev()); } Halfedge_handle find_prev_around_vertex( Halfedge_handle h) const { // returns the previous halfedge of h. Uses the `prev()' method if // supported or performs a search around the vertex using `next()'. return find_prev_around_vertex( h, Supports_halfedge_prev()); } Face_handle get_face( Halfedge_handle h) const { // returns the incident face of h if supported, // `Face_handle()' otherwise. return get_face( h, Supports_halfedge_face()); } Halfedge_handle get_face_halfedge( Face_handle f) const { // returns the incident halfedge of f if supported, // `Halfedge_handle()' otherwise. return get_face_halfedge( f, Supports_face_halfedge()); } // Const Access Functions // ---------------------------------- Halfedge_const_handle get_vertex_halfedge( Vertex_const_handle v) const { return get_vertex_halfedge( v, Supports_vertex_halfedge()); } Vertex_const_handle get_vertex( Halfedge_const_handle h) const { return get_vertex( h, Supports_halfedge_vertex()); } Halfedge_const_handle get_prev( Halfedge_const_handle h) const { return get_prev( h, Supports_halfedge_prev()); } Halfedge_const_handle find_prev( Halfedge_const_handle h) const { return find_prev( h, Supports_halfedge_prev()); } Halfedge_const_handle find_prev_around_vertex( Halfedge_const_handle h) const { return find_prev_around_vertex( h, Supports_halfedge_prev()); } Face_const_handle get_face( Halfedge_const_handle h) const { return get_face( h, Supports_halfedge_face()); } Halfedge_const_handle get_face_halfedge( Face_const_handle f) const { return get_face_halfedge( f, Supports_face_halfedge()); } // Modifying Functions (Primitives) // ---------------------------------- void set_vertex_halfedge( Vertex_handle v, Halfedge_handle g) const { // sets the incident halfedge of v to g. set_vertex_halfedge( v, g, Supports_vertex_halfedge()); } void set_vertex_halfedge( Halfedge_handle h) const { // sets the incident halfedge of the vertex incident to h to h. set_vertex_halfedge( h, h, Supports_halfedge_vertex()); } void set_vertex( Halfedge_handle h, Vertex_handle v) const { // sets the incident vertex of h to v. set_vertex(h, v, Supports_halfedge_vertex()); } void set_prev( Halfedge_handle h, Halfedge_handle g) const { // sets the previous link of h to g. set_prev( h, g, Supports_halfedge_prev()); } void set_face( Halfedge_handle h, Face_handle f) const { // sets the incident face of h to f. set_face(h, f, Supports_halfedge_face()); } void set_face_halfedge( Face_handle f, Halfedge_handle g) const { // sets the incident halfedge of f to g. set_face_halfedge( f, g, Supports_face_halfedge()); } void set_face_halfedge( Halfedge_handle h) const { // sets the incident halfedge of the face incident to h to h. set_face_halfedge( h, h, Supports_halfedge_face()); } // MODIF vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv void set_face_plane( Face_handle f, Vertex_handle u, Vertex_handle v, Vertex_handle w) const { set_face_plane( f, u, v, w, Supports_face_plane()); } void set_face_plane( Face_handle f) const { set_face_plane( f, Supports_face_plane()); } // MODIF ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ // Modifying Functions (Composed) // ---------------------------------- void close_tip( Halfedge_handle h) const { // makes `h->opposite()' the successor of h. h->HBase::set_next( h->opposite()); set_prev( h->opposite(), h); } void close_tip( Halfedge_handle h, Vertex_handle v) const { // makes `h->opposite()' the successor of h and sets the incident // vertex of h to v. h->HBase::set_next( h->opposite()); set_prev( h->opposite(), h); set_vertex( h, v); set_vertex_halfedge( h); } void insert_tip( Halfedge_handle h, Halfedge_handle v) const { // inserts the tip of the edge h into the halfedges around the // vertex pointed to by v. Halfedge `h->opposite()' is the new // successor of v and `h->next()' will be set to `v->next()'. The // vertex of h will be set to the vertex v refers to if vertices // are supported. h->HBase::set_next( v->next()); v->HBase::set_next( h->opposite()); set_prev( h->next(), h); set_prev( h->opposite(), v); set_vertex( h, get_vertex( v)); } void remove_tip( Halfedge_handle h) const { // removes the edge `h->next()->opposite()' from the halfedge // circle around the vertex referred to by h. The new successor // halfedge of h will be `h->next()->opposite()->next()'. h->HBase::set_next( h->next()->opposite()->next()); set_prev( h->next(), h); } void insert_halfedge( Halfedge_handle h, Halfedge_handle f) const { // inserts the halfedge h between f and `f->next()'. The face of h // will be the one f refers to if faces are supported. h->HBase::set_next( f->next()); f->HBase::set_next( h); set_prev( h->next(), h); set_prev( h, f); set_face( h, get_face( f)); } void remove_halfedge( Halfedge_handle h) const { // removes edge `h->next()' from the halfedge circle around the // face referred to by h. The new successor of h will be // `h->next()->next()'. h->HBase::set_next( h->next()->next()); set_prev( h->next(), h); } void set_vertex_in_vertex_loop( Halfedge_handle h, Vertex_handle v, Tag_false) const {} void set_vertex_in_vertex_loop( Halfedge_handle h, Vertex_handle v, Tag_true) const { CGAL_assertion_code( std::size_t termination_count = 0;) Halfedge_handle end = h; do { CGAL_assertion( ++termination_count != 0); h->HBase::set_vertex( v); h = h->next()->opposite(); } while ( h != end); } void set_vertex_in_vertex_loop( Halfedge_handle h, Vertex_handle v) const { // loops around the vertex incident to h and sets all vertex // pointers to v. Precondition: `h != Halfedge_handle()'. CGAL_precondition( h != Halfedge_handle()); set_vertex_in_vertex_loop( h, v, Supports_halfedge_vertex()); } void set_face_in_face_loop( Halfedge_handle h, Face_handle f, Tag_false) const {} void set_face_in_face_loop( Halfedge_handle h, Face_handle f, Tag_true) const { CGAL_assertion_code( std::size_t termination_count = 0;) Halfedge_handle end = h; do { CGAL_assertion( ++termination_count != 0); h->HBase::set_face( f); h = h->next(); } while ( h != end); } void set_face_in_face_loop( Halfedge_handle h, Face_handle f) const { // loops around the face incident to h and sets all face pointers // to f. Precondition: `h != Halfedge_handle()'. CGAL_precondition( h != Halfedge_handle()); set_face_in_face_loop( h, f, Supports_halfedge_face()); } Halfedge_handle flip_edge( Halfedge_handle h) const { // performs an edge flip. It returns h after // rotating the edge h one vertex in the direction of the face // orientation. Precondition: `h != Halfedge_handle()' and both // incident faces of h are triangles. CGAL_precondition( h != Halfedge_handle()); CGAL_precondition( h == h->next()->next()->next()); CGAL_precondition( h->opposite() == h->opposite()->next()->next()->next()); Halfedge_handle hprev = h->next()->next(); Halfedge_handle gprev = h->opposite()->next()->next(); remove_tip( hprev); remove_tip( gprev); set_face_halfedge( hprev); set_face_halfedge( gprev); set_vertex_halfedge( hprev); set_vertex_halfedge( gprev); set_face( hprev->next(), hprev->face()); set_face( gprev->next(), gprev->face()); hprev = hprev->next(); gprev = gprev->next(); insert_tip( h, gprev); insert_tip( h->opposite(), hprev); CGAL_postcondition( h == h->next()->next()->next()); CGAL_postcondition( h->opposite() == h->opposite()->next()->next()->next()); return h; } // Implementing These Functions. // ==================================================== // Access Functions // ---------------------------------- Halfedge_handle get_vertex_halfedge( Vertex_handle , Tag_false) const { return Halfedge_handle(); } Halfedge_handle get_vertex_halfedge( Vertex_handle v, Tag_true) const { return v->halfedge(); } Vertex_handle get_vertex( Halfedge_handle , Tag_false) const { return Vertex_handle(); } Vertex_handle get_vertex( Halfedge_handle h, Tag_true) const { return h->vertex(); } Halfedge_handle get_prev( Halfedge_handle , Tag_false) const { return Halfedge_handle(); } Halfedge_handle get_prev( Halfedge_handle h, Tag_true) const { return h->HBase::prev(); } Halfedge_handle find_prev( Halfedge_handle h, Tag_true) const { return h->HBase::prev(); } Halfedge_handle find_prev( Halfedge_handle h, Tag_false) const { Halfedge_handle g = h; while ( g->next() != h) g = g->next(); return g; } Halfedge_handle find_prev_around_vertex( Halfedge_handle h, Tag_true) const { return h->HBase::prev(); } Halfedge_handle find_prev_around_vertex( Halfedge_handle h, Tag_false) const { Halfedge_handle g = h->opposite(); while ( g->next() != h) g = g->next()->opposite(); return g; } Face_handle get_face( Halfedge_handle , Tag_false) const { return Face_handle(); } Face_handle get_face( Halfedge_handle h, Tag_true) const { return h->face(); } Halfedge_handle get_face_halfedge( Face_handle , Tag_false) const { return Halfedge_handle(); } Halfedge_handle get_face_halfedge( Face_handle f, Tag_true) const { return f->halfedge(); } // Const Access Functions // ---------------------------------- Halfedge_const_handle get_vertex_halfedge( Vertex_const_handle ,Tag_false) const { return Halfedge_const_handle(); } Halfedge_const_handle get_vertex_halfedge( Vertex_const_handle v,Tag_true) const { return v->halfedge(); } Vertex_const_handle get_vertex( Halfedge_const_handle , Tag_false) const { return Vertex_const_handle(); } Vertex_const_handle get_vertex( Halfedge_const_handle h, Tag_true) const { return h->vertex(); } Halfedge_const_handle get_prev( Halfedge_const_handle , Tag_false) const { return Halfedge_const_handle(); } Halfedge_const_handle get_prev( Halfedge_const_handle h, Tag_true) const { return h->HBase::prev(); } Halfedge_const_handle find_prev( Halfedge_const_handle h, Tag_true) const { return h->HBase::prev(); } Halfedge_const_handle find_prev( Halfedge_const_handle h, Tag_false) const { Halfedge_const_handle g = h; while ( g->next() != h) g = g->next(); return g; } Halfedge_const_handle find_prev_around_vertex( Halfedge_const_handle h, Tag_true) const { return h->HBase::prev(); } Halfedge_const_handle find_prev_around_vertex( Halfedge_const_handle h, Tag_false) const { Halfedge_const_handle g = h->opposite(); while ( g->next() != h) g = g->next()->opposite(); return g; } Face_const_handle get_face( Halfedge_const_handle , Tag_false) const { return Face_const_handle(); } Face_const_handle get_face( Halfedge_const_handle h, Tag_true) const { return h->face(); } Halfedge_const_handle get_face_halfedge( Face_const_handle , Tag_false) const { return Halfedge_const_handle(); } Halfedge_const_handle get_face_halfedge( Face_const_handle f, Tag_true) const { return f->halfedge(); } // Modifying Function Primitives // ---------------------------------- void set_vertex_halfedge( Vertex_handle, Halfedge_handle, Tag_false) const {} void set_vertex_halfedge( Vertex_handle v, Halfedge_handle g, Tag_true) const { v->VBase::set_halfedge(g); } void set_vertex_halfedge( Halfedge_handle, Halfedge_handle, Tag_false) const {} void set_vertex_halfedge( Halfedge_handle h, Halfedge_handle g, Tag_true) const { set_vertex_halfedge( h->vertex(), g); } void set_vertex( Halfedge_handle, Vertex_handle, Tag_false) const {} void set_vertex( Halfedge_handle h, Vertex_handle v, Tag_true) const { h->HBase::set_vertex(v); } void set_prev( Halfedge_handle, Halfedge_handle, Tag_false) const {} void set_prev( Halfedge_handle h, Halfedge_handle g, Tag_true) const { h->HBase::set_prev( g); } void set_face( Halfedge_handle, Face_handle, Tag_false) const {} void set_face( Halfedge_handle h, Face_handle f, Tag_true) const { h->HBase::set_face(f); } void set_face_halfedge( Face_handle, Halfedge_handle, Tag_false) const {} void set_face_halfedge( Face_handle f, Halfedge_handle g, Tag_true) const { f->FBase::set_halfedge(g); } void set_face_halfedge( Halfedge_handle, Halfedge_handle, Tag_false) const {} void set_face_halfedge( Halfedge_handle h, Halfedge_handle g, Tag_true) const { set_face_halfedge( h->face(), g); } // MODIF vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv void set_face_plane( Face_handle f, Vertex_handle u, Vertex_handle v, Vertex_handle w, Tag_false) const {} void set_face_plane( Face_handle f, Vertex_handle u, Vertex_handle v, Vertex_handle w, Tag_true) const { f->plane() = Plane(u->point(), v->point(), w->point()); } void set_face_plane( Face_handle f, Tag_false) const {} void set_face_plane( Face_handle f, Tag_true) const { Vertex_handle u, v, w; Halfedge_handle h = f->halfedge(); u = h->vertex(); h = h->HBase::prev(); v = h->vertex(); h = h->HBase::prev(); w = h->vertex(); while(CGAL::collinear(u->point(), v->point(), w->point())) { h = h->HBase::prev(); w = h->vertex(); } set_face_plane(f, u, v, w, Tag_true()); } // MODIF ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ }; CGAL_END_NAMESPACE #endif // CGAL_HALFEDGEDS_ITEMS_DECORATOR_H // // EOF //
// Copyright (c) 1997 ETH Zurich (Switzerland). // All rights reserved. // // This file is part of CGAL (www.cgal.org); you may redistribute it under // the terms of the Q Public License version 1.0. // See the file LICENSE.QPL distributed with CGAL. // // Licensees holding a valid commercial license may use this file in // accordance with the commercial license agreement provided with the software. // // This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE // WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. // // $URL: svn+ssh:///svn/cgal/trunk/Polyhedron/include/CGAL/Polyhedron_incremental_builder_3.h $ // $Id: Polyhedron_incremental_builder_3.h 36779 2007-03-03 08:57:28Z spion $ // // // Author(s) : Lutz Kettner <>) #ifndef CGAL_POLYHEDRON_INCREMENTAL_BUILDER_3_H #define CGAL_POLYHEDRON_INCREMENTAL_BUILDER_3_H 1 #include <CGAL/basic.h> #include <CGAL/Random_access_adaptor.h> #include <CGAL/HalfedgeDS_decorator.h> #include <CGAL/Unique_hash_map.h> #include <CGAL/IO/Verbose_ostream.h> #include <vector> #include <cstddef> #warning -x-x-x-x-x-x-x-x-x- LOCAL Polyhedron_incremental_builder_3 CGAL_BEGIN_NAMESPACE template < class HalfedgeDS_> class Polyhedron_incremental_builder_3 { public: typedef HalfedgeDS_ HDS; // internal typedef HalfedgeDS_ HalfedgeDS; typedef typename HDS::Vertex Vertex; typedef typename HDS::Halfedge Halfedge; typedef typename HDS::Face Face; typedef typename HDS::Vertex_handle Vertex_handle; typedef typename HDS::Halfedge_handle Halfedge_handle; typedef typename HDS::Face_handle Face_handle; typedef typename HDS::Face_handle Facet_handle; typedef typename Vertex::Base VBase; typedef typename Halfedge::Base HBase; typedef typename Vertex::Point Point_3; typedef typename HDS::size_type size_type; protected: typedef typename HDS::Supports_vertex_halfedge Supports_vertex_halfedge; typedef typename HDS::Supports_removal Supports_removal; typedef typename HDS::Vertex_iterator Vertex_iterator; typedef typename HDS::Halfedge_iterator Halfedge_iterator; typedef Random_access_adaptor<Vertex_iterator> Random_access_index; bool m_error; bool m_verbose; HDS& hds; size_type rollback_v; size_type rollback_f; size_type rollback_h; size_type new_vertices; size_type new_faces; size_type new_halfedges; Face_handle current_face; Random_access_index index_to_vertex_map; std::vector< Halfedge_handle> vertex_to_edge_map; Halfedge_handle g1; // first halfedge, 0 denotes none. Halfedge_handle gprime; Halfedge_handle h1; // current halfedge size_type w1; // first vertex. size_type w2; // second vertex. size_type v1; // current vertex bool first_vertex; bool last_vertex; CGAL_assertion_code( int check_protocoll;) // use to check protocoll. // states for checking: 0 = created, 1 = constructing, 2 = make face. // Implement the vertex_to_edge_map either with an array or // the halfedge pointer in the vertices (if supported). // ---------------------------------------------------- void initialize_vertex_to_edge_map( size_type n, bool mode, Tag_true) { vertex_to_edge_map.clear(); vertex_to_edge_map.resize(n); if ( mode) { // go through all halfedges and keep a halfedge for each // vertex found in a hashmap. size_type i = 0; for ( Vertex_iterator vi = hds.vertices_begin(); vi != hds.vertices_end(); ++vi) { set_vertex_to_edge_map( i, vi->halfedge()); ++i; } } } void initialize_vertex_to_edge_map( size_type n, bool mode, Tag_false){ vertex_to_edge_map.clear(); vertex_to_edge_map.resize(n); if ( mode) { // go through all halfedges and keep a halfedge for each // vertex found in a hashmap. typedef Unique_hash_map< Vertex_iterator, Halfedge_handle> V_map; Halfedge_handle hh; V_map v_map( hh, hds.size_of_vertices()); for ( Halfedge_iterator hi = hds.halfedges_begin(); hi != hds.halfedges_end(); ++hi) { v_map[ hi->vertex()] = hi; } size_type i = 0; for ( Vertex_iterator vi = hds.vertices_begin(); vi != hds.vertices_end(); ++vi) { //set_vertex_to_edge_map( i, v_map[ index_to_vertex_map[i]]); set_vertex_to_edge_map( i, v_map[ vi]); ++i; } } } void initialize_vertex_to_edge_map( size_type n, bool mode) { initialize_vertex_to_edge_map(n, mode, Supports_vertex_halfedge()); } void push_back_vertex_to_edge_map( Halfedge_handle h, Tag_true) { push_back_vertex_to_edge_map( h, Tag_false()); } void push_back_vertex_to_edge_map( Halfedge_handle h, Tag_false) { vertex_to_edge_map.push_back(h); } void push_back_vertex_to_edge_map( Halfedge_handle h) { push_back_vertex_to_edge_map( h, Supports_vertex_halfedge()); } Halfedge_handle get_vertex_to_edge_map( size_type i, Tag_true) { // Use the halfedge pointer within the vertex. //CGAL_assertion( index_to_vertex_map[i]->halfedge() == get_vertex_to_edge_map(i, Tag_false())); return index_to_vertex_map[i]->halfedge(); } Halfedge_handle get_vertex_to_edge_map( size_type i, Tag_false) { // Use the self-managed array vertex_to_edge_map. return vertex_to_edge_map[i]; } Halfedge_handle get_vertex_to_edge_map( size_type i) { return get_vertex_to_edge_map( i, Supports_vertex_halfedge()); } void set_vertex_to_edge_map( size_type i, Halfedge_handle h, Tag_true) { set_vertex_to_edge_map( i, h, Tag_false()); // Use the halfedge pointer within the vertex. index_to_vertex_map[i]->VBase::set_halfedge(h); } void set_vertex_to_edge_map( size_type i, Halfedge_handle h, Tag_false) { // Use the self-managed array vertex_to_edge_map. CGAL_assertion(i < vertex_to_edge_map.size()); vertex_to_edge_map[i] = h; } void set_vertex_to_edge_map( size_type i, Halfedge_handle h) { set_vertex_to_edge_map( i, h, Supports_vertex_halfedge()); } // An Incremental Builder for Polyhedral Surfaces // ---------------------------------------------- // DEFINITION // // Polyhedron_incremental_builder_3<HDS> is an auxiliary class that // supports the incremental construction of polyhedral surfaces. This is // for example convinient when constructing polyhedral surfaces from // files. The incremental construction starts with a list of all point // coordinates and concludes with a list of all facet polygons. Edges are // not explicitly specified. They are derived from the incidence // information provided from the facet polygons. These are given as a // sequence of vertex indices. The correct protocol of method calls to // build a polyhedral surface can be stated as regular expression: // // `begin_surface (add_vertex | (begin_facet add_vertex_to_facet* // end_facet))* end_surface ' // // PARAMETERS // // `HDS' is the halfedge data structure used to represent the // polyhedral surface that is to be constructed. // // CREATION public: bool error() const { return m_error; } Polyhedron_incremental_builder_3( HDS& h, bool verbose = false) // stores a reference to the halfedge data structure `h' in the // internal state. The previous polyhedral surface in `h' // remains unchanged. The incremental builder adds the new // polyhedral surface to the old one. : m_error( false), m_verbose( verbose), hds(h) { CGAL_assertion_code(check_protocoll = 0;) } ~Polyhedron_incremental_builder_3() { CGAL_assertion( check_protocoll == 0); } // OPERATIONS enum { RELATIVE_INDEXING = 0, ABSOLUTE_INDEXING = 1}; void begin_surface( std::size_t v, std::size_t f, std::size_t h = 0, int mode = RELATIVE_INDEXING); // starts the construction. v is the number of new // vertices to expect, f the number of new facets, and h the number of // new halfedges. If h is unspecified (`== 0') it is estimated using // Euler equations (plus 5% for the so far unkown holes and genus // of the object). These values are used to reserve space in the // polyhedron representation `HDS'. If the representation // supports insertion these values do not restrict the class of // readable polyhedrons. If the representation does not support // insertion the object must fit in the reserved sizes. // If `mode' is set to ABSOLUTE_INDEXING the incremental builder // uses absolute indexing and the vertices of the old polyhedral // surface can be used in new facets. Otherwise relative indexing is // used starting with new indices for the new construction. Vertex_handle add_vertex( const Point_3& p) { // adds p to the vertex list. CGAL_assertion( check_protocoll == 1); if ( hds.size_of_vertices() >= hds.capacity_of_vertices()) { Verbose_ostream verr( m_verbose); verr << " " << std::endl; verr << "CGAL::Polyhedron_incremental_builder_3<HDS>::" << std::endl; verr << "add_vertex(): capacity error: more than " << new_vertices << " vertices added." << std::endl; m_error = true; return Vertex_handle(); } HalfedgeDS_decorator<HDS> decorator(hds); Vertex_handle v = decorator.vertices_push_back( Vertex(p)); index_to_vertex_map.push_back( v); decorator.set_vertex_halfedge( v, Halfedge_handle()); push_back_vertex_to_edge_map( Halfedge_handle()); ++new_vertices; return v; } // returns handle for the vertex of index i Vertex_handle vertex( std::size_t i) { if ( i < new_vertices) return index_to_vertex_map[i]; return Vertex_handle(); } Facet_handle begin_facet() { // starts a facet. if ( m_error) return Facet_handle(); CGAL_assertion( check_protocoll == 1); CGAL_assertion_code( check_protocoll = 2;) if ( hds.size_of_faces() >= hds.capacity_of_faces()) { Verbose_ostream verr( m_verbose); verr << " " << std::endl; verr << "CGAL::Polyhedron_incremental_builder_3<HDS>::" << std::endl; verr << "begin_facet(): capacity error: more than " << new_vertices << " facets added." << std::endl; m_error = true; return Facet_handle(); } // initialize all status variables. first_vertex = true; // denotes 'no vertex yet' g1 = Halfedge_handle(); // denotes 'no halfedge yet' last_vertex = false; HalfedgeDS_decorator<HDS> decorator(hds); current_face = decorator.faces_push_back( Face()); return current_face; } void add_vertex_to_facet( std::size_t i); // adds a vertex with index i to the current facet. The first // point added with `add_vertex()' has the index 0. Halfedge_handle end_facet() { // ends a facet. if ( m_error) return Halfedge_handle(); CGAL_assertion( check_protocoll == 2); CGAL_assertion( ! first_vertex); // cleanup all static status variables add_vertex_to_facet( w1); if ( m_error) return Halfedge_handle(); last_vertex = true; add_vertex_to_facet( w2); if ( m_error) return Halfedge_handle(); CGAL_assertion( check_protocoll == 2); CGAL_assertion_code( check_protocoll = 1;) HalfedgeDS_items_decorator<HDS> decorator; Halfedge_handle h = get_vertex_to_edge_map(w1); decorator.set_face_halfedge( current_face, h); // MODIF vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv decorator.set_face_plane( current_face); // MODIF ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ++new_faces; return h; } template <class InputIterator> Halfedge_handle add_facet( InputIterator first, InputIterator beyond) { // synonym for begin_facet(), a call to add_facet() for each iterator // value type, and end_facet(). begin_facet(); for ( ; ! m_error && first != beyond; ++first) add_vertex_to_facet( *first); if ( m_error) return Halfedge_handle(); return end_facet(); } template <class InputIterator> bool test_facet( InputIterator first, InputIterator beyond) { // tests if the facet described by the vertex indices in the // range [first,beyond) can be inserted without creating a // a non-manifold (and therefore invalid) situation. // First, create a copy of the indices and close it cyclically std::vector< std::size_t> indices( first, beyond); if ( indices.size() < 3) return false; indices.push_back( indices[0]); return test_facet_indices( indices); } bool test_facet_indices( std::vector< std::size_t> indices); void end_surface(); // ends the construction. bool check_unconnected_vertices(); // returns `true' if unconnected vertices are detected. If `verb' // is set to `true' debug information about the unconnected // vertices is printed. bool remove_unconnected_vertices( Tag_true); bool remove_unconnected_vertices( Tag_false) { return ! check_unconnected_vertices(); } bool remove_unconnected_vertices() { // returns `true' if all unconnected vertices could be removed // succesfully. return remove_unconnected_vertices( Supports_removal()); } void rollback(); protected: Halfedge_handle lookup_hole( std::size_t w) { CGAL_assertion( w < new_vertices); return lookup_hole( get_vertex_to_edge_map( w)); } size_type find_vertex( Vertex_handle v) { // Returns 0 if v == NULL. if ( v == Vertex_handle() ) return 0; size_type n = 0; typename HDS::Vertex_iterator it = hds.vertices_begin(); while ( it != v) { CGAL_assertion( it != hds.vertices_end()); ++n; ++it; } n = n - rollback_v; return n; } size_type find_facet( Face_handle f) { // Returns 0 if f == NULL. if ( f == Face_handle()) return 0; size_type n = 0; typename HDS::Face_iterator it = hds.faces_begin(); while ( it != f) { CGAL_assertion( it != hds.faces_end()); ++n; ++it; } n = n - rollback_f; return n; } Halfedge_handle lookup_halfedge( size_type w, size_type v) { // Pre: 0 <= w,v < new_vertices // Case a: It exists an halfedge g from w to v: // g must be a border halfedge and the facet of g->opposite() // must be set and different from the current facet. // Set the facet of g to the current facet. Return the // halfedge pointing to g. // Case b: It exists no halfedge from w to v: // Create a new pair of halfedges g and g->opposite(). // Set the facet of g to the current facet and g->opposite() // to a border halfedge. Assign the vertex references. // Set g->opposite()->next() to g. Return g->opposite(). typedef typename HDS::Supports_halfedge_vertex Supports_halfedge_vertex; Assert_compile_time_tag( Supports_halfedge_vertex(), Tag_true()); CGAL_assertion( w < new_vertices); CGAL_assertion( v < new_vertices); CGAL_assertion( ! last_vertex); HalfedgeDS_items_decorator<HDS> decorator; Halfedge_handle e = get_vertex_to_edge_map( w); if ( e != Halfedge_handle()) { CGAL_assertion( e->vertex() == index_to_vertex_map[w]); // check that the facet has no self intersections if ( current_face != Face_handle() && current_face == decorator.get_face(e)) { Verbose_ostream verr( m_verbose); verr << " " << std::endl; verr << "CGAL::Polyhedron_incremental_builder_3<HDS>::" << std::endl; verr << "lookup_halfedge(): input error: facet " << new_faces << " has a self intersection at vertex " << w << "." << std::endl; m_error = true; return Halfedge_handle(); } Halfedge_handle start_edge( e); do { if ( e->next()->vertex() == index_to_vertex_map[v]) { if ( ! e->next()->is_border()) { Verbose_ostream verr( m_verbose); verr << " " << std::endl; verr << "CGAL::Polyhedron_incremental_builder_3" "<HDS>::" << std::endl; verr << "lookup_halfedge(): input error: facet " << new_faces << " shares a halfedge from " "vertex " << w << " to vertex " << v << " with"; if ( m_verbose && current_face != Face_handle()) verr << " facet " << find_facet( decorator.get_face(e->next())) << '.' << std::endl; else verr << " another facet." << std::endl; m_error = true; return Halfedge_handle(); } CGAL_assertion( ! e->next()->opposite()->is_border()); if ( current_face != Face_handle() && current_face == decorator.get_face( e->next()->opposite())) { Verbose_ostream verr( m_verbose); verr << " " << std::endl; verr << "CGAL::Polyhedron_incremental_builder_3" "<HDS>::" << std::endl; verr << "lookup_halfedge(): input error: facet " << new_faces << " has a self intersection " "at the halfedge from vertex " << w << " to vertex " << v << "." << std::endl; m_error = true; return Halfedge_handle(); } decorator.set_face( e->next(), current_face); return e; } e = e->next()->opposite(); } while ( e != start_edge); } // create a new halfedge if ( hds.size_of_halfedges() >= hds.capacity_of_halfedges()) { Verbose_ostream verr( m_verbose); verr << " " << std::endl; verr << "CGAL::Polyhedron_incremental_builder_3<HDS>::" << std::endl; verr << "lookup_halfedge(): capacity error: more than " << new_halfedges << " halfedges added while creating facet" << new_faces << '.' << std::endl; m_error = true; return Halfedge_handle(); } e = hds.edges_push_back( Halfedge(), Halfedge()); new_halfedges++; new_halfedges++; decorator.set_face( e, current_face); e->HBase::set_vertex( index_to_vertex_map[v]); e->HBase::set_next( Halfedge_handle()); decorator.set_prev( e, e->opposite()); e = e->opposite(); e->HBase::set_vertex( index_to_vertex_map[w]); e->HBase::set_next( e->opposite()); return e; } Halfedge_handle lookup_hole( Halfedge_handle e) { // Halfedge e points to a vertex w. Walk around w to find a hole // in the facet structure. Report an error if none exist. Return // the halfedge at this hole that points to the vertex w. CGAL_assertion( e != Halfedge_handle()); HalfedgeDS_items_decorator<HDS> decorator; Halfedge_handle start_edge( e); do { if ( e->next()->is_border()) { return e; } e = e->next()->opposite(); } while ( e != start_edge); Verbose_ostream verr( m_verbose); verr << " " << std::endl; verr << "CGAL::Polyhedron_incremental_builder_3<HDS>::" << std::endl; verr << "lookup_hole(): input error: at vertex " << find_vertex( e->vertex()) << " a closed surface already exists and facet " << new_faces << " is nonetheless adjacent." << std::endl; if ( m_verbose && current_face != Face_handle()) { verr << " The closed cycle of facets is:"; do { if ( ! e->is_border()) verr << " " << find_facet( decorator.get_face(e)); e = e->next()->opposite(); } while ( e != start_edge); verr << '.' << std::endl; } m_error = true; return Halfedge_handle(); } }; template < class HDS> void Polyhedron_incremental_builder_3<HDS>:: rollback() { CGAL_assertion( rollback_v <= hds.size_of_vertices()); CGAL_assertion( rollback_h <= hds.size_of_halfedges()); CGAL_assertion( rollback_f <= hds.size_of_faces()); if ( rollback_v == 0 && rollback_h == 0 && rollback_f == 0) { hds.clear(); } else { while ( rollback_v != hds.size_of_vertices()) hds.vertices_pop_back(); CGAL_assertion((( hds.size_of_halfedges() - rollback_h) & 1) == 0); while ( rollback_h != hds.size_of_halfedges()) hds.edges_pop_back(); while ( rollback_f != hds.size_of_faces()) hds.faces_pop_back(); } m_error = false; CGAL_assertion_code( check_protocoll = 0;) } template < class HDS> CGAL_MEDIUM_INLINE void Polyhedron_incremental_builder_3<HDS>:: begin_surface( std::size_t v, std::size_t f, std::size_t h, int mode) { CGAL_assertion( check_protocoll == 0); CGAL_assertion_code( check_protocoll = 1;) CGAL_assertion( ! m_error); if ( mode == RELATIVE_INDEXING) { new_vertices = 0; new_faces = 0; new_halfedges = 0; rollback_v = hds.size_of_vertices(); rollback_f = hds.size_of_faces(); rollback_h = hds.size_of_halfedges(); } else { new_vertices = hds.size_of_vertices(); new_faces = hds.size_of_faces(); new_halfedges = hds.size_of_halfedges(); rollback_v = 0; rollback_f = 0; rollback_h = 0; } if ( h == 0) { // Use the Eulerian equation for connected planar graphs. We do // not know the number of facets that are holes and we do not // know the genus of the surface. So we add 12 and a factor of // 5 percent. h = int((v + f - 2 + 12) * 2.1); } hds.reserve( hds.size_of_vertices() + v, hds.size_of_halfedges() + h, hds.size_of_faces() + f); if ( mode == RELATIVE_INDEXING) { index_to_vertex_map = Random_access_index( hds.vertices_end()); index_to_vertex_map.reserve(v); initialize_vertex_to_edge_map( v, false); } else { index_to_vertex_map = Random_access_index( hds.vertices_begin(), hds.vertices_end()); index_to_vertex_map.reserve( hds.size_of_vertices() + v); initialize_vertex_to_edge_map( hds.size_of_vertices() + v, true); } } template < class HDS> void Polyhedron_incremental_builder_3<HDS>:: add_vertex_to_facet( std::size_t v2) { if ( m_error) return; CGAL_assertion( check_protocoll == 2); if ( v2 >= new_vertices) { Verbose_ostream verr( m_verbose); verr << " " << std::endl; verr << "CGAL::Polyhedron_incremental_builder_3<HDS>::" << std::endl; verr << "add_vertex_to_facet(): vertex index " << v2 << " is out-of-range [0," << new_vertices-1 << "]." << std::endl; m_error = true; return; } HalfedgeDS_items_decorator<HDS> decorator; if ( first_vertex) { CGAL_assertion( ! last_vertex); w1 = v2; first_vertex = false; return; } if ( g1 == Halfedge_handle()) { CGAL_assertion( ! last_vertex); gprime = lookup_halfedge( w1, v2); if ( m_error) return; h1 = g1 = gprime->next(); v1 = w2 = v2; return; } // g1, h1, v1, w1, w2 are set. Insert halfedge. // Lookup v1-->v2 Halfedge_handle hprime; if ( last_vertex) hprime = gprime; else { hprime = lookup_halfedge( v1, v2); if ( m_error) return; } Halfedge_handle h2 = hprime->next(); CGAL_assertion( ! last_vertex || h2 == g1); Halfedge_handle prev = h1->next(); h1->HBase::set_next( h2); decorator.set_prev( h2, h1); if ( get_vertex_to_edge_map( v1) == Halfedge_handle()) { // case 1: h2->opposite()->HBase::set_next( h1->opposite()); decorator.set_prev( h1->opposite(), h2->opposite()); } else { // case 2: bool b1 = h1->opposite()->is_border(); bool b2 = h2->opposite()->is_border(); if ( b1 && b2) { Halfedge_handle hole = lookup_hole( v1); if ( m_error) return; CGAL_assertion( hole != Halfedge_handle()); h2->opposite()->HBase::set_next( hole->next()); decorator.set_prev( hole->next(), h2->opposite()); hole->HBase::set_next( h1->opposite()); decorator.set_prev( h1->opposite(), hole); } else if ( b2) { // case 2.b: CGAL_assertion( prev->is_border()); h2->opposite()->HBase::set_next( prev); decorator.set_prev( prev, h2->opposite()); } else if ( b1) { // case 2.c: CGAL_assertion( hprime->is_border()); hprime->HBase::set_next( h1->opposite()); decorator.set_prev( h1->opposite(), hprime); } else if ( h2->opposite()->next() == h1->opposite()) {// case 2.d: // f1 == f2 CGAL_assertion( decorator.get_face( h1->opposite()) == decorator.get_face( h2->opposite())); } else { // case 2.e: if ( prev == h2) { // case _i: // nothing to be done, hole is closed. } else { // case _ii: CGAL_assertion( prev->is_border()); CGAL_assertion( hprime->is_border()); hprime->HBase::set_next( prev); decorator.set_prev( prev, hprime); // Check whether the halfedges around v1 are connected. // It is sufficient to check it for h1 to prev. // Assert loop termination: CGAL_assertion_code( std::size_t k = 0;) // Look for a hole in the facet complex starting at h1. Halfedge_handle hole; Halfedge_handle e = h1; do { if ( e->is_border()) hole = e; e = e->next()->opposite(); CGAL_assertion( k++ < hds.size_of_halfedges()); } while ( e->next() != prev && e != h1); if ( e == h1) { // disconnected facet complexes if ( hole != Halfedge_handle()) { // The complex can be connected with // the hole at hprime. hprime->HBase::set_next( hole->next()); decorator.set_prev( hole->next(), hprime); hole->HBase::set_next( prev); decorator.set_prev( prev, hole); } else { Verbose_ostream verr( m_verbose); verr << " " << std::endl; verr << "CGAL::Polyhedron_incremental_builder_3<" "HDS>::" << std::endl; verr << "add_vertex_to_facet(): input error: " "disconnected facet complexes at vertex " << v1 << ":" << std::endl; if ( m_verbose && current_face != Face_handle()) { verr << " involved facets are:"; do { if ( ! e->is_border()) verr << " " << find_facet( decorator.get_face(e)); e = e->next()->opposite(); } while ( e != h1); verr << " (closed cycle) and"; e = hprime; do { if ( ! e->is_border()) verr << " " << find_facet( decorator.get_face(e)); } while ( e != hprime); verr << "." << std::endl; } m_error = true; return; } } } } } if ( h1->vertex() == index_to_vertex_map[v1]) set_vertex_to_edge_map( v1, h1); CGAL_assertion( h1->vertex() == index_to_vertex_map[v1]); h1 = h2; v1 = v2; } template < class HDS> bool Polyhedron_incremental_builder_3<HDS>:: test_facet_indices( std::vector< std::size_t> indices) { typedef typename HDS::Supports_halfedge_vertex Supports_halfedge_vertex; Assert_compile_time_tag( Supports_halfedge_vertex(), Tag_true()); // tests if the facet described by the vertex indices can be inserted // without creating a a non-manifold (and therefore invalid) situation. // indices are cyclically closed once. std::size_t n = indices.size() - 1; // Test if a vertex is not twice in the indices for ( std::size_t i = 0; i < n; ++i) { CGAL_precondition( indices[i] < new_vertices); // check if vertex indices[i] is already in the sequence [0..i-1] for ( std::size_t k = 0; k+1 < i; ++k) { if ( indices[k] == indices[i]) return false; } } // Test non-manifold edges for ( std::size_t i = 0; i < n; ++i) { // edge goes from vertex indices[i] to indices[i+1] // we know already that the edge is only once in the sequence // (otherwise the end-vertices would be twice in the sequence too) // check if edge is already in the HDS and is not border edge Halfedge_handle v = get_vertex_to_edge_map(indices[i]); Vertex_handle w = index_to_vertex_map[indices[i+1]]; if ( v != Halfedge_handle() && get_vertex_to_edge_map(indices[i+1]) != Halfedge_handle()) { // cycle through halfedge-loop and find edge to indices[i+1] Halfedge_handle vstart = v; do { v = v->next()->opposite(); } while ( v->next()->vertex() != w && v != vstart); if ( v->next()->vertex() == w && ! v->next()->is_border()) return false; } } // test non-manifold vertices for ( std::size_t i = 0; i < n; ++i) { // since we don't allow duplicates in indices[..] and we // tested for non-manifold edges already, we just need to check // if the vertex indices[i] is not a closed manifold yet. Halfedge_handle v = get_vertex_to_edge_map(indices[i]); if ( v != Halfedge_handle()) { Halfedge_handle vstart = v; do { v = v->next()->opposite(); } while ( ! v->is_border() && v != vstart); if ( ! v->is_border()) return false; } } return true; } template < class HDS> CGAL_MEDIUM_INLINE void Polyhedron_incremental_builder_3<HDS>:: end_surface() { if ( m_error) return; CGAL_assertion( check_protocoll == 1); CGAL_assertion_code( check_protocoll = 0;) } template < class HDS> bool Polyhedron_incremental_builder_3<HDS>:: check_unconnected_vertices() { if ( m_error) return false; bool unconnected = false; Verbose_ostream verr( m_verbose); for ( std::size_t i = 0; i < new_vertices; i++) { if ( get_vertex_to_edge_map( i) == Halfedge_handle()) { verr << "CGAL::Polyhedron_incremental_builder_3<HDS>::\n" << "check_unconnected_vertices( verb = true): " << "vertex " << i << " is unconnected." << std::endl; unconnected = true; } } return unconnected; } template < class HDS> bool Polyhedron_incremental_builder_3<HDS>:: remove_unconnected_vertices( Tag_true) { if ( m_error) return true; for( std::size_t i = 0; i < new_vertices; i++) { if( get_vertex_to_edge_map( i) == Halfedge_handle()) { hds.vertices_erase( index_to_vertex_map[i]); } } return true; } CGAL_END_NAMESPACE #endif // CGAL_POLYHEDRON_INCREMENTAL_BUILDER_3_H // // EOF //
- Regular_triangulation_3 Bug, CGAL 3.3, Bernhard Kornberger, 07/30/2007
- Re: [cgal-discuss] Regular_triangulation_3 Bug, CGAL 3.3, Monique . Teillaud, 07/30/2007
- Re: [cgal-discuss] Regular_triangulation_3 Bug, CGAL 3.3, Bernhard Kornberger, 07/31/2007
- Re: [cgal-discuss] Regular_triangulation_3 Bug, CGAL 3.3, Andreas Fabri, 07/31/2007
- Re: [cgal-discuss] Regular_triangulation_3 Bug, CGAL 3.3, Monique . Teillaud, 07/31/2007
- Re: [cgal-discuss] Regular_triangulation_3 Bug, CGAL 3.3, Camille Wormser, 07/31/2007
