- To:
- Subject: Re: [cgal-discuss] Regular_triangulation_3 Bug, CGAL 3.3
- Date: Tue, 31 Jul 2007 17:29:44 +0200
Bernhard Kornberger wrote:
Hello Bernhard,
You haven't computed the plane equation. See:
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Polyhedron/Chapter_main.html#Subsection_12.3.4
andreas
Thank you, Andreas!
This solves the problem. Sure, this is documented, but a programmer
can not expect that behavior. And even worse, the function returns
a wrong plane instead of some error message. Shouldn't the function
have an assertion like assert(plane_is_valid()); ??
I admit that this isn't fool proof, and leaves space for improvement.
FYI: The other problem where the software only crashes when it is
started in valgrind is still there.
I just downloaded the tarball. Can you please reduce the complexity
of the bug report example to a single file with some includes and typedefs
in the beginning, and a main that generates a triangulation and inserts
some points and still crashes.
I could do it myself, but I think it is your task.
It seems that the points are the points of a cube. Do you observe the
same with simpler values than
double l=-2396.4;
double u=2595.59;
that is with 0 and 1
best
andreas
Best
Bernhard
- Regular_triangulation_3 Bug, CGAL 3.3, Bernhard Kornberger, 07/30/2007
- Re: [cgal-discuss] Regular_triangulation_3 Bug, CGAL 3.3, Monique . Teillaud, 07/30/2007
- Re: [cgal-discuss] Regular_triangulation_3 Bug, CGAL 3.3, Bernhard Kornberger, 07/31/2007
- Re: [cgal-discuss] Regular_triangulation_3 Bug, CGAL 3.3, Andreas Fabri, 07/31/2007
- Re: [cgal-discuss] Regular_triangulation_3 Bug, CGAL 3.3, Monique . Teillaud, 07/31/2007
- Re: [cgal-discuss] Regular_triangulation_3 Bug, CGAL 3.3, Camille Wormser, 07/31/2007
