cgal-discuss - Re: [cgal-discuss] Regular_triangulation_3 Bug, CGAL 3.3
  • To:
  • Subject: Re: [cgal-discuss] Regular_triangulation_3 Bug, CGAL 3.3
  • Date: Tue, 31 Jul 2007 17:07:38 +0200
Hello Bernhard,
You haven't computed the plane equation. See:
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Polyhedron/Chapter_main.html#Subsection_12.3.4
andreas
Thank you, Andreas!
This solves the problem. Sure, this is documented, but a programmer
can not expect that behavior. And even worse, the function returns
a wrong plane instead of some error message. Shouldn't the function
have an assertion like assert(plane_is_valid()); ??
FYI: The other problem where the software only crashes when it is
started in valgrind is still there.
Best
Bernhard
