cgal-discuss - Re: Re: Re: [cgal-discuss] Bug in 3 Planes intersection?
  • To: <>
  • Subject: Re: Re: Re: [cgal-discuss] Bug in 3 Planes intersection?
  • Date: Mon, 10 Sep 2007 11:41:39 -0300
  • Organization: SciSoft
Hello Amir,
One way to see if this is a robustness issue or a bug in CGAL is to try with:
Exact_predicate_exact_constructions_kernel
If you get incorrect results using that then almost certainly there is a bug in CGAL.
But conversely, if results are correct using that kernel, then you just have a robustness issue which you need to solve by following the advice given.
HTH
Fernando Cacciola
GeometyFactory
