- To: <>, <>
- Subject: AW: Re: Re: [cgal-discuss] Bug in 3 Planes intersection?
- Date: Mon, 10 Sep 2007 20:10:14 +0200
I agree in principle, but it could still be the case that a too naive
floating-point implementation is the reason for unnecessarily bad behavior
under double arithmetic. For example, the planes that Amir sent define a 3x3
linear system (for computing the intersection point) that seems to be
well-conditioned; if the solution is still way off, this could mean that the
solution method cannot properly deal with non-critical degeneracies like the
x- and y-coordinate of both the first and third plane being almost equal (up
to scaling).
Best,
Bernd.
________________________________
Von: Fernando Cacciola
[mailto:]
Gesendet: Mo 10.09.2007 16:41
An:
Betreff: Re: Re: Re: [cgal-discuss] Bug in 3 Planes intersection?
Hello Amir,
One way to see if this is a robustness issue or a bug in CGAL is to try
with:
Exact_predicate_exact_constructions_kernel
If you get incorrect results using that then almost certainly there is a bug
in CGAL.
But conversely, if results are correct using that kernel, then you just have
a robustness issue which you need to solve by following the advice given.
HTH
Fernando Cacciola
GeometyFactory
- Re: Re: [cgal-discuss] Bug in 3 Planes intersection?, avaxman, 09/10/2007
- Re: [cgal-discuss] Bug in 3 Planes intersection?, Bernd Gaertner, 09/10/2007
- Re: Re: [cgal-discuss] Bug in 3 Planes intersection?, Christophe Delage, 09/10/2007
- Re: [cgal-discuss] Bug in 3 Planes intersection?, Deepak Bandyopadhyay, 09/13/2007
- <Possible follow-up(s)>
- Re: Re: Re: [cgal-discuss] Bug in 3 Planes intersection?, avaxman, 09/10/2007
- Re: Re: Re: [cgal-discuss] Bug in 3 Planes intersection?, Christophe Delage, 09/10/2007
- Re: Re: Re: [cgal-discuss] Bug in 3 Planes intersection?, Fernando Cacciola, 09/10/2007
- AW: Re: Re: [cgal-discuss] Bug in 3 Planes intersection?, Gärtner Bernd, 09/10/2007
