- To:
- Subject: Re: [cgal-discuss] Arrangement changes between 3.1 and 3.3.1
- Date: Tue, 25 Sep 2007 15:33:29 +0200 (CEST)
- Organization: Institut fuer Werkstoffe TU Braunschweig
Dear Efi,
probably I am doing something stupid, but it still does not
work. Here's the full program, copied almost directly from the 3.1
manual and replacing Arrangement_2 with Arrangement_with_history_2:
#include <iostream>
// CGAL stuff
#include <CGAL/Cartesian.h>
#include <CGAL/Quotient.h>
#include <CGAL/MP_Float.h>
#include <CGAL/Point_2.h>
#include <CGAL/enum.h>
#include <CGAL/intersections.h>
#include <CGAL/Arr_segment_traits_2.h>
#include <CGAL/Arr_default_dcel.h>
#include <CGAL/Arrangement_with_history_2.h>
typedef CGAL::Quotient<CGAL::MP_Float> NT;
typedef CGAL::Cartesian<NT> TutorialR;
typedef CGAL::Arr_segment_traits_2<TutorialR> Traits;
typedef Traits::Point_2 Point_2;
typedef Traits::Curve_2 Curve_2;
typedef Traits::X_monotone_curve_2 X_monotone_curve_2;
typedef CGAL::Arrangement_with_history_2<Traits> Arr_2;
int main()
Arr_2 arr;
//insertion of the curves
arr.insert(Curve_2(Point_2(0, 0), Point_2(1, 1)));
arr.insert(Curve_2(Point_2(0, 1), Point_2(1, 0)));
//traversal of the curves
Arr_2::Curve_iterator cit;
Arr_2::Edge_iterator eit;
for (cit = arr.curve_node_begin(); cit != arr.curve_node_end(); ++cit)
std::cout << std::endl << "Curve level:" << std::endl << cit->curve()
<< std::endl ;
std::cout << "Edge level:" << std::endl;
//traversal of the edges of the current curve
for (eit = cit->edges_begin(); eit != cit->edges_end(); ++eit)
std::cout << eit->x_curve() << std::endl ;
return 0;
Still, when I'm trying to compile this, I get the same error messages as
before:
minitest.C:26: Fehler: »class Arr_2« hat kein Element namens »insert«
minitest.C:27: Fehler: »class Arr_2« hat kein Element namens »insert«
minitest.C:31: Fehler: »class Arr_2« hat kein Element namens
»curve_node_begin«
minitest.C:31: Fehler: »class Arr_2« hat kein Element namens »curve_node_end«
minitest.C:33: Fehler: »class
CGAL::Arrangement_with_history_2<CGAL::Arr_segment_traits_2<CGAL::Cartesian<CGAL::Quotient<CGAL::MP_Float>
CGAL::Arr_default_dcel<CGAL::Arr_segment_traits_2<CGAL::Cartesian<CGAL::Quotient<CGAL::MP_Float>
> > > >::Curve_halfedges« hat kein Element namens »curve«
If you have any hint what I am doing wrong, I'd be grateful.
Thanks a lot,
Martin.
> The functionality to are referring to (iterating over the curves) has
> been preserved, but it is part of the arrangement with history data
> structure. In the past We use to have Planar_map_2 and Arrangement_2.
> These were replaced by Arrangement_2 and Arrangement_with_history_2, so
> simply define the type Arr_2 to be Arrangement_with_history_2<...>
> Martin Baeker wrote:
> > Dear experts,
> > I am currently updating my code from version 3.1 to 3.3.1.
> > In between, the Arrangement_2-class has changed drastically and I am
> > missing the old possibility of iterating over the curves of an
> > Arrangement:
> > Old code (taken almost directly from the 3.1 manual)
> > Arr_2 pm;
> > // Trial: Insert the segments one by one
> > pm.insert(seglist.begin(), seglist.end());
> > for (unsigned int i=0; i< seglist.size(); i++)
> > pm.insert_curve(seglist[i]);
> > std::cout << "\n\nWriting pm's halfedges" << std::endl;
> > unsigned int edgeCounter=0;
> > for (cit = pm.curve_node_begin(); cit != pm.curve_node_end(); ++cit)
> > << std::endl ;
> > edgeCounter++;
> > However, this does not work anymore because there is no
> > Arr_2::Curve_iterator class anymore. I searched through the Docs but
> > could not find how this can be replaced with another iterator.
> > Is it still possible to traverse the Curves of an Arrangement?
> > Thanks a lot in advance,
> > Martin.
> > Priv.-Doz. Dr. Martin Bäker
> > Institut für Werkstoffe
> > Technische Universität Braunschweig
> > Langer Kamp 8
> > 38106 Braunschweig
> > Germany
> > Tel.: 00-49-531-391-3073
> > Fax 00-49-531-391-3058
> > You are currently subscribed to cgal-discuss.
> > To unsubscribe or access the archives, go to
> > https://lists-sop.inria.fr/wws/info/cgal-discuss
> ____ _ ____ _
> /_____/_) o /__________ __ //
> (____ ( ( ( (_/ (_/-(-'_(/
> _/
Langer Kamp 8
38106 Braunschweig
Germany
- Arrangement changes between 3.1 and 3.3.1, Martin Baeker, 09/24/2007
- Re: [cgal-discuss] Arrangement changes between 3.1 and 3.3.1, Efraim Fogel, 09/24/2007
- Re: [cgal-discuss] Arrangement changes between 3.1 and 3.3.1, Martin Baeker, 09/25/2007
- Re: [cgal-discuss] Arrangement changes between 3.1 and 3.3.1, Efraim Fogel, 09/25/2007
- Re: [cgal-discuss] Arrangement changes between 3.1 and 3.3.1, Martin Baeker, 09/26/2007
- Re: [cgal-discuss] Arrangement changes between 3.1 and 3.3.1, Efi Fogel, 09/26/2007
- Arrangement_with_history::Induced_edge_iterator problem, Martin Baeker, 09/27/2007
- Re: [cgal-discuss] Arrangement_with_history::Induced_edge_iterator problem, Efi Fogel, 09/28/2007
- Re: [cgal-discuss] Arrangement_with_history::Induced_edge_iterator problem, Martin Baeker, 09/28/2007
