cgal-discuss - Re: [cgal-discuss] Arrangement changes between 3.1 and 3.3.1
  • To:
  • Subject: Re: [cgal-discuss] Arrangement changes between 3.1 and 3.3.1
  • Date: Wed, 26 Sep 2007 14:11:04 +0200
All release notes are gathered in the "Release History" page accessible from the main page (bottom of 1st menu section on the left). The examples might be of additional help.
Martin Baeker wrote:
Dear efi,
I'm really sorry for being too stupid by half, but I just cannot find
where the release notes are.
Are they in the manual somewhere? I
could find neither a chapter nor an index entry called release notes.
Sorry for being a bother,
Martin.
Dear Martin,
The interface went through a few more changes since the last time you were
using it. For starters, the 'arr.insert[_blah](...)' member functions were
replaced by corresponding free functions 'insert[_blah](arr, ...)'. All
differences are listed in the release notes. The manual was enhanced, and many
examples were introduced including some that show how to construct and
maintain arrangements with history.
Dear Efi,
probably I am doing something stupid, but it still does not
work. Here's the full program, copied almost directly from the 3.1
manual and replacing Arrangement_2 with Arrangement_with_history_2:
#include <iostream>
// CGAL stuff
#include <CGAL/Cartesian.h>
#include <CGAL/Quotient.h>
#include <CGAL/MP_Float.h>
#include <CGAL/Point_2.h>
#include <CGAL/enum.h>
#include <CGAL/intersections.h>
#include <CGAL/Arr_segment_traits_2.h>
#include <CGAL/Arr_default_dcel.h>
#include <CGAL/Arrangement_with_history_2.h>
typedef CGAL::Quotient<CGAL::MP_Float>                      NT;
typedef CGAL::Cartesian<NT>                                 TutorialR;
typedef CGAL::Arr_segment_traits_2<TutorialR>                  Traits;
typedef Traits::Point_2                                 Point_2;
typedef Traits::Curve_2                                 Curve_2;
typedef Traits::X_monotone_curve_2                      X_monotone_curve_2;
typedef CGAL::Arrangement_with_history_2<Traits> Arr_2;
int main() {
  Arr_2 arr;
  //insertion of the curves
  arr.insert(Curve_2(Point_2(0, 0), Point_2(1, 1)));
  arr.insert(Curve_2(Point_2(0, 1), Point_2(1, 0))); //traversal of the
  curves
  Arr_2::Curve_iterator cit;
  Arr_2::Edge_iterator eit;
  for (cit = arr.curve_node_begin(); cit != arr.curve_node_end(); ++cit) {
    std::cout << std::endl << "Curve level:" << std::endl << cit->curve()
              << std::endl ;
    std::cout << "Edge level:" << std::endl;
    //traversal of the edges of the current curve
    for (eit = cit->edges_begin(); eit != cit->edges_end(); ++eit) {
      std::cout << eit->x_curve() << std::endl ;
  return 0;
Still, when I'm trying to compile this, I get the same error messages as
before:
minitest.C:26: Fehler: »class Arr_2« hat kein Element namens »insert«
minitest.C:27: Fehler: »class Arr_2« hat kein Element namens »insert«
minitest.C:31: Fehler: »class Arr_2« hat kein Element namens
»curve_node_begin«
minitest.C:31: Fehler: »class Arr_2« hat kein Element namens »curve_node_end
minitest.C:33: Fehler: »class
CGAL::Arrangement_with_history_2<CGAL::Arr_segment_traits_2<CGAL::Cartesian<CGAL::Quotient<CGAL::MP_Float>
CGAL::Arr_default_dcel<CGAL::Arr_segment_traits_2<CGAL::Cartesian<CGAL::Quotient<CGAL::MP_Float>
::Curve_halfedges« hat kein Element namens »curve«
If you have any hint what I am doing wrong, I'd be grateful.
Thanks a lot,
Martin.
The functionality to are referring to (iterating over the curves) has
been preserved, but it is part of the arrangement with history data
structure. In the past We use to have Planar_map_2 and Arrangement_2.
These were replaced by Arrangement_2 and Arrangement_with_history_2, so
simply define the type Arr_2 to be Arrangement_with_history_2<...>
Dear experts,
I am currently updating my code from version 3.1 to 3.3.1.
In between, the Arrangement_2-class has changed drastically and I am
missing the old possibility of iterating over the curves of an
Arrangement:
Old code (taken almost directly from the 3.1 manual)
Arr_2 pm;
// Trial: Insert the segments one by one
pm.insert(seglist.begin(), seglist.end());
for (unsigned int i=0; i< seglist.size(); i++)
     pm.insert_curve(seglist[i]);
std::cout << "\n\nWriting pm's halfedges" << std::endl;
unsigned int edgeCounter=0;
for (cit = pm.curve_node_begin(); cit != pm.curve_node_end(); ++cit)
     cit->curve()
               << std::endl ;
    edgeCounter++;
However, this does not work anymore because there is no
Arr_2::Curve_iterator class anymore. I searched through the Docs but
could not find how this can be replaced with another iterator.
Is it still possible to traverse the Curves of an Arrangement?
Thanks a lot in advance,
Martin.
                   Priv.-Doz. Dr. Martin Bäker
                   Institut für Werkstoffe
                   Technische Universität Braunschweig
                   Langer Kamp 8
                   38106 Braunschweig
                   Germany
                   Tel.: 00-49-531-391-3073
                   Fax   00-49-531-391-3058
                   e-mail --
 ____  _        ____             _
/_____/_) o    /__________  __  //
(____ (   (    (    (_/ (_/-(-'_(/
                        _/
                   Langer Kamp 8
                   38106 Braunschweig
                   Germany
                   e-mail --
____  _        ____             _
                       _/
                   Langer Kamp 8
                   38106 Braunschweig
                   Germany
                   e-mail --
   ____  _        ____             _
                         _/
