cgal-discuss - Arrangement changes between 3.1 and 3.3.1
  • To: CGAL Mailinglist <>
  • Subject: Arrangement changes between 3.1 and 3.3.1
  • Date: Mon, 24 Sep 2007 10:19:23 +0200 (CEST)
  • Organization: Institut fuer Werkstoffe TU Braunschweig
Dear experts,
I am currently updating my code from version 3.1 to 3.3.1.
In between, the Arrangement_2-class has changed drastically and I am
missing the old possibility of iterating over the curves of an
Arrangement:
Old code (taken almost directly from the 3.1 manual)
Arr_2 pm;
// Trial: Insert the segments one by one
pm.insert(seglist.begin(), seglist.end());
for (unsigned int i=0; i< seglist.size(); i++)
pm.insert_curve(seglist[i]);
std::cout << "\n\nWriting pm's halfedges" << std::endl;
Arr_2::Edge_iterator eit;
Arr_2::Curve_iterator cit;
unsigned int edgeCounter=0;
for (cit = pm.curve_node_begin(); cit != pm.curve_node_end(); ++cit)
std::cout << std::endl << "Curve level:" << std::endl << cit->curve()
<< std::endl ;
std::cout << "Edge level:" << std::endl;
edgeCounter++;
for (eit = cit->edges_begin(); eit != cit->edges_end(); ++eit)
std::cout << eit->x_curve() << std::endl ;
However, this does not work anymore because there is no
Arr_2::Curve_iterator class anymore. I searched through the Docs but
could not find how this can be replaced with another iterator.
Is it still possible to traverse the Curves of an Arrangement?
Thanks a lot in advance,
Martin.
Priv.-Doz. Dr. Martin Bäker
Institut für Werkstoffe
Technische Universität Braunschweig
Langer Kamp 8
38106 Braunschweig
Germany
Tel.: 00-49-531-391-3073
Fax 00-49-531-391-3058
e-mail
