- To:
- Subject: Arrangement_with_history::Induced_edge_iterator problem
- Date: Thu, 27 Sep 2007 14:34:07 +0200 (CEST)
- Organization: Institut fuer Werkstoffe TU Braunschweig
Dear Efi,
thanks a lot for your patience. I think I am getting closer, but one
thing is still not working.
I am using the following code fragment:
Arr_2::Induced_edge_iterator eit;
for (cit = arr.curves_begin(); cit != arr.curves_end(); ++cit)
std::cout << std::endl << "Curve level:" << std::endl << *cit
<< std::endl ;
std::cout << "Edge level:" << std::endl;
//traversal of the edges of the current curve
for (eit = arr.induced_edges_begin(cit); eit !=
arr.induced_edges_end(cit); ++eit)
std::cout << eit->curve() << std::endl ; // ERROR
However, when I try to compile this, the compiler complains about the line
marked with ERROR because
eit "has no element called curve()".
I am puzzled by this because the manual says that
Induced_edge_iterator returns a halfedge handle, and this does have a
curve() function, doesn't it?
The following construction works:
Arr_2::Edge_iterator eit2;
for (eit2 = arr.edges_begin(); eit2 != arr.edges_end(); ++eit2)
std::cout << "[" << eit2->curve() << std::endl;
but for my application I want to travel over the edges curve-wise. Can
you tell me how I have to do it to make it work?
BTW, there is a small typo in the manual:
The class is not
Arrangement_with_history_2::Induced_edges_iterator
but
Arrangement_with_history_2::Induced_edge_iterator
Would be nice if you could correct this.
Thanks again,
Martin.
Priv.-Doz. Dr. Martin Bäker
Institut für Werkstoffe
Technische Universität Braunschweig
Langer Kamp 8
38106 Braunschweig
Germany
Tel.: 00-49-531-391-3073
Fax 00-49-531-391-3058
- Arrangement changes between 3.1 and 3.3.1, Martin Baeker, 09/24/2007
- Re: [cgal-discuss] Arrangement changes between 3.1 and 3.3.1, Efraim Fogel, 09/24/2007
- Re: [cgal-discuss] Arrangement changes between 3.1 and 3.3.1, Martin Baeker, 09/25/2007
- Re: [cgal-discuss] Arrangement changes between 3.1 and 3.3.1, Efraim Fogel, 09/25/2007
- Re: [cgal-discuss] Arrangement changes between 3.1 and 3.3.1, Martin Baeker, 09/26/2007
- Re: [cgal-discuss] Arrangement changes between 3.1 and 3.3.1, Efi Fogel, 09/26/2007
- Arrangement_with_history::Induced_edge_iterator problem, Martin Baeker, 09/27/2007
- Re: [cgal-discuss] Arrangement_with_history::Induced_edge_iterator problem, Efi Fogel, 09/28/2007
- Re: [cgal-discuss] Arrangement_with_history::Induced_edge_iterator problem, Martin Baeker, 09/28/2007
