- To: "" <>
- Subject: [cgal-discuss][Polyhedron] How to perform coordinate system conversion
- Date: Fri, 4 Jan 2008 13:54:08 +0800
- Disposition-notification-to: "LoadCom" <>
- Organization: LoadCom
Hello all,
There's Aff_transformation_3 and Aff_transformation_2 in CGAL perform
affine transformation. But I don't know how to perform such a conversion
using CGAL:
Given 3 points in 3D space, say A, B and C, I need to construct a
'user coord system' in this manner: use A as the origin of the new system,
vector AB to be along the x axis, z axis pass through A and extends to the
normal direction of the plane determined by the 3 points.
with such a user system, then I will perform coord transformation from
the default system to this user system and vice versa.
Thanks for any help.
Max
- [cgal-discuss][Polyhedron] Simple program problem, LoadCom, 01/03/2008
- Re: [cgal-discuss][Polyhedron] Simple program problem, Peter Hachenberger, 01/03/2008
- Re: Re: [cgal-discuss][Polyhedron] Simple program problem, LoadCom, 01/04/2008
- [cgal-discuss][Polyhedron] How to perform coordinate system conversion, LoadCom, 01/04/2008
- <Possible follow-up(s)>
- Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Mahmood NT, 01/04/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, LoadCom, 01/04/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Peter Hachenberger, 01/07/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, LoadCom, 01/08/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Peter Hachenberger, 01/08/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, LoadCom, 01/09/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Peter Hachenberger, 01/09/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Max, 01/10/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Peter Hachenberger, 01/10/2008
- Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Max, 01/11/2008
