- To: "" <>
- Subject: Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem
- Date: Fri, 4 Jan 2008 16:25:45 +0800
- Disposition-notification-to: "LoadCom" <>
- Organization: LoadCom
Hello Mahmood NT,
This time the point the program stoped at is different.
The location as well as the call stack is captered as
attached.
Thanks for your help.
Max
>Thank you very much for your reply.
>My environment:
>CGAL 3.3.1
>Windows XP/SP2
>VS 2003
>The program causes a runtime error, see the attached 1.png. (debug mode)
Did you set project properties properly. check your project propeties with a
simple example or demo (if you use QT).
Also it would be helpful to post the call stack.
Mahmood NT
Description: Binary data
- [cgal-discuss][Polyhedron] Simple program problem, LoadCom, 01/03/2008
- Re: [cgal-discuss][Polyhedron] Simple program problem, Peter Hachenberger, 01/03/2008
- Re: Re: [cgal-discuss][Polyhedron] Simple program problem, LoadCom, 01/04/2008
- [cgal-discuss][Polyhedron] How to perform coordinate system conversion, LoadCom, 01/04/2008
- <Possible follow-up(s)>
- Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Mahmood NT, 01/04/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, LoadCom, 01/04/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Peter Hachenberger, 01/07/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, LoadCom, 01/08/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Peter Hachenberger, 01/08/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, LoadCom, 01/09/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Peter Hachenberger, 01/09/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Max, 01/10/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Peter Hachenberger, 01/10/2008
- Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Max, 01/11/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, LoadCom, 01/05/2008
