- To:
- Subject: Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem
- Date: Thu, 10 Jan 2008 13:28:47 +0100
Yes, but that is exactly what I expected to happen. The assertion line
calls the assign function and then crashes. With the extra lines I
wanted to make sure, that the assign function is used on valid data.
So, what you now can try to do is to compile the CGAL libraries without
the QT support. You do this by going into your CGAL home directory, call
install_cgal -i, go to the support menu, deactivate the QT support, go
to the main menu, and rebuild the libraries. Then try whether the
program still crashes.
Peter
On Thu, 2008-01-10 at 17:21 +0800, Max wrote:
> Hello Peter
> It looks like even stranger. I remember I've tested your code addition
> last time and the program paused at the last new line with an assertion
> failure. But now with a latest trial I get: the program outputs "test
> first sedge 0 0 1" and then stopped at the same position in object_handle.h:
> template <class T>
> bool assign(T &t) const
> const Handle_wrapper<T> *wp =
> dynamic_cast<const Handle_wrapper<T> *>(Ptr()); // HERE !!
> if ( wp == static_cast<Handle_wrapper<T> *>(0) )
> return false;
> t = *(wp);
> Thanks.
> B/Rgds
> Max
> ----- Original Message ----
> From: Peter Hachenberger
> To:
> Sent: 2008-01-09 18:57:22
> > Unfortunately my program behaves exactly as you expected. It passes
> > the first line you gave me and then raise an assertion error at the last
> > new line of code. Then, according to your point, it seems to be true that
> > the cause of the problem is from the installation of my CGAL(but I'm still
> > not sure, or, in other words, I don't know why).
> Before I give you hints of what to do with your CGAL installation, let's
> get one thing clear. Do you get an assertion in the last line of the new
> code or do you get another error?
> > Once a time I also suspected if there's problem related to my
> > installation,
> > and I've unpacked the CGAL 3.3.1 package file into the existing
> > installation
> > folder to overwrite any inadvertant code change, if exists.
> > Thank you very much for your time and help.
> > It has been helpful indeeded.
> > B/Rgds
> > Max
> > To:
> > Sent: 2008-01-08 20:59:03
> > Oh, that was not my brightest idea. Unfortunately, the output function
> > does not give me the desired information, because it uses the same
> > problematic call to show the desired information.
> > I still think that it is not a problem of my code, but of your CGAL
> > installation, but I don't want you to go fishing for problems with your
> > installation before I did not have good evidence for this assumption. To
> > provemy assumption, kick out the new line in polyhedron_to_nef3.h and
> > replace it with
> > std::cerr << "test first sedge "
> > << SM.shalfedges_begin()->source()->point()
> > << std::endl;
> > typename SNC_structure::Object_list ol;
> > ol.push_back(SM.shalfedges_begin());
> > typename SNC_structure::SFace_cycle_iterator sfci(ol.begin());
> > CGAL_assertion(sfci.is_shalfedge());
> > That fourth line is the same call that causes the problem. The
> > is_shalfedge() command calls a dynamic cast that decides whether the
> > Object_handle sfci points to can be cast to an shalfedge. With the lines
> > above I put a valid shalfege into sfci. I know that it's valid from the
> > output generated by the first lines. So, if you know get a correct
> > output by the first line and then got a fault in the assertion line (not
> > a thrown assertion, but the same error as before), then I'm right and
> > there is some problem with the installation.
> > Peter
> > On Tue, 2008-01-08 at 09:12 +0800, LoadCom wrote:
> > > Hello Peter Hachenberger
> > > I've made change as you suggested to polyhedron_3_to_nef_3.h(not
> > > polyhedron_to_nef_3.h).
> > > The program's output before error occur is as dos.png.
> > > The context at the stop point is as snapshot.png.
> > > The 2 files are as attached.
> > > Thanks for your help.
> > > B/Rgds
> > > Max
> > > To:
> > > Sent: 2008-01-07 20:49:42
> > > Hi Max,
> > > Looking at the latest debug picture 1.png, we can try the following
> > > stuff:
> > > The programm stops at an integrity check of the data structure. I want
> > > to check whether the data structure really lacks integrity or whether
> > > its something else. Please add the line
> > > CGAL::SM_io_parser<SM_decorator>::dump(SM, std::cerr);
> > > in front of the fifth line from the end in polyhedron_to_nef_3.h, which
> > > looks as follows:
> > > SM.check_integrity_and_topological_planarity();
> > > So that it looks like
> > > index_adder.resolve_indexes();
> > > at the end of the file. Then compile and execute your program again and
> > > send me the output, please.
> > > Peter
> > > On Fri, 2008-01-04 at 16:25 +0800, LoadCom wrote:
> > > > Hello Mahmood NT,
> > > > This time the point the program stoped at is different.
> > > > The location as well as the call stack is captered as
> > > > attached.
> > > > Max
> > > > >Thank you very much for your reply.
> > > > >My environment:
> > > > >CGAL 3.3.1
> > > > >Windows XP/SP2
> > > > >VS 2003
> > > > >The program causes a runtime error, see the attached 1.png. (debug
> > > > >mode)
> > > > Did you set project properties properly. check your project propeties
> > > > with a simple example or demo (if you use QT).
> > > > Also it would be helpful to post the call stack.
> > > > Mahmood NT
> > > You are currently subscribed to cgal-discuss.
> > > To unsubscribe or access the archives, go to
> > > https://lists-sop.inria.fr/wws/info/cgal-discuss
- Re: Re: [cgal-discuss][Polyhedron] Simple program problem, (continued)
- Re: Re: [cgal-discuss][Polyhedron] Simple program problem, LoadCom, 01/04/2008
- [cgal-discuss][Polyhedron] How to perform coordinate system conversion, LoadCom, 01/04/2008
- Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Mahmood NT, 01/04/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, LoadCom, 01/04/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Peter Hachenberger, 01/07/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, LoadCom, 01/08/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Peter Hachenberger, 01/08/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, LoadCom, 01/09/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Peter Hachenberger, 01/09/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Max, 01/10/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Peter Hachenberger, 01/10/2008
- Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Max, 01/11/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, LoadCom, 01/05/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Max, 01/11/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Max, 01/12/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Max, 01/13/2008
