- To:
- Subject: Re: Re: [cgal-discuss][Polyhedron] Simple program problem
- Date: Fri, 4 Jan 2008 02:49:31 -0800 (PST)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type:Message-ID; b=YKwFLR06pwPSmeoNTT+DrIZmSSbNADDy/Pori6HRP9yc4gCZhE8doaHReaOnqJjYL1DcP4s49rg7v6zKy+Acuvxxp8Y4g2vZDsOw/50KAvHeHm6BbXDnfwCYweaz+9DcV3q5eMhgu7GaX1NcIhegEJe/3GatAhMicjE2vyWH7lQ=;
Hi Max,
First I have to say, I am not expert in Polyhedrons and I do not know the
structure of its code and functions.
I tried to run your code, but I get ther same runtime error as you but in
different location!
But I have to say, there is a sample code in
"examples/Polyhedron/polyhedron_prog_tetra.cpp" and is expplained in CGAL
manual (section 12.3.2 @ page 963). I run it witout any problem. So I
strongly recommend you to try it.
It is the similar as yours, but I think "kernel" is defined in a different
manner from yours ;)
Hope this help,
Mahmood NT
----- Original Message ----
To:
Sent: Friday, January 4, 2008 11:55:45 AM
Subject: Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem
Hello Mahmood NT,
This time the point the program stoped at is different.
The location as well as the call stack is captered as
attached.
Thanks for your help.
Max
>Thank you very much for your reply.
>My environment:
>CGAL 3.3.1
>Windows XP/SP2
>VS 2003
>The program causes a runtime error, see the attached 1.png. (debug mode)
Did you set project properties properly. check your project propeties with a
simple example or demo (if you use QT).
Also it would be helpful to post the call stack.
Mahmood NT
____________________________________________________________________________________
Looking for last minute shopping deals?
Find them fast with Yahoo! Search.
http://tools.search.yahoo.com/newsearch/category.php?category=shopping
- Re: Re: [cgal-discuss][Polyhedron] Simple program problem, (continued)
- Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Mahmood NT, 01/04/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, LoadCom, 01/04/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Peter Hachenberger, 01/07/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, LoadCom, 01/08/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Peter Hachenberger, 01/08/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, LoadCom, 01/09/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Peter Hachenberger, 01/09/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Max, 01/10/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Peter Hachenberger, 01/10/2008
- Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Max, 01/11/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, LoadCom, 01/05/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Max, 01/11/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Max, 01/12/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Max, 01/13/2008
- Re: [cgal-discuss][Polyhedron] Simple program problem - concluded, Max, 01/13/2008
