Re: Re: [cgal-discuss][Nef_polyhedron] How to convert aNef_polyhedron_3 into a Nef_polyhedron_2 if meaningful
- To:
- Subject: Re: Re: [cgal-discuss][Nef_polyhedron] How to convert aNef_polyhedron_3 into a Nef_polyhedron_2 if meaningful
- Date: Thu, 10 Jan 2008 15:54:09 +0100
I already gave you the answer:
store the points of the Nef_3 and then pass those points to the
constructor of the Nef_2
That should also work with Polygon/Polygon_with_hole in some way.
Peter
On Wed, 2008-01-09 at 10:01 +0800, LoadCom wrote:
> Hello Peter,
> Thanks for your quick response. It's very helpful indeed.
> It's not a surprise to know that the designer of CGAL has never thought
> of such a *strange* conversion. Perhaps it's too wild. :-)
> From your reply, it seems that it's still possible (I mean not so hard)
> to write some code to get such a conversion.
> At the present time, efficiency is probably not a main problem for me. The
> result I desired is somthing that similar in topology to a Nef_2, or
> perferrably,
> in terms of a Polygon_with_hole data structure. With that, I can get to
> calculte some geometric properties of this polygon, including center of
> area,
> moment of inertia, and so on.
> If possible, could you please give me some more detailed instruction with
> which I could accomplish that needs?
> I really appreciat the help you've given me.
> B/Rgds
> Max
> ----- Original Message ----
> From: Peter Hachenberger
> To:
> Sent: 2008-01-08 18:38:41
> Subject: Re: [cgal-discuss][Nef_polyhedron] How to convert
> Hi Max,
> we never really thought about this conversion. So, we don't have it. An
> easy thing to do is just to store the points of the Nef_3 and then pass
> those points to the constructor of the Nef_2. I guess that any
> conversion tool I could write would not be more efficient than that. The
> main disadvantage to a real conversion is, that you loose the marks. The
> constructor does not allow you to choose for every edge whether it is
> selected or not. Does that help you?
> Peter
> On Mon, 2008-01-07 at 15:38 +0800, LoadCom wrote:
> > Hello,
> > Suppose I have a closed Nef_polyhedron_3 N, and I construct a plane with
> > Nef_polyhedron_3 in this manner
> > Nef_polyhedron_3 N; // closed
> > // now constructing a plane Nef
> > Plane_3 pl(1, 1, 1, 0);
> > Nef_polyhedron_3 N_plane(Nef_polyhedron_3(pl) * !Nef_polyhedron_3(pl,
> > Nef_polyhedron::EXCLUDED));
> > // Now I intersect these 2 Nef:
> > Nef_polyhedron_3 N_res = N * N_plane;
> > Now N_res is actually a Nef_polyhedron_2, but is there a way to convert
> > it into a Nef_polyhedron_2
> > and then explore it accordingly?
> > Thanks in advance.
> > Max
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss][Nef_polyhedron] How to convert a Nef_polyhedron_3 into a Nef_polyhedron_2 if meaningful, LoadCom, 01/07/2008
- Re: [cgal-discuss][Nef_polyhedron] How to convert a Nef_polyhedron_3 into a Nef_polyhedron_2 if meaningful, Peter Hachenberger, 01/08/2008
- Re: Re: [cgal-discuss][Nef_polyhedron] How to convert aNef_polyhedron_3 into a Nef_polyhedron_2 if meaningful, LoadCom, 01/09/2008
- Re: Re: [cgal-discuss][Nef_polyhedron] How to convert aNef_polyhedron_3 into a Nef_polyhedron_2 if meaningful, Peter Hachenberger, 01/10/2008
- Re: [cgal-discuss][Nef_polyhedron] How to convertaNef_polyhedron_3 into a Nef_polyhedron_2 if meaningful, Max, 01/11/2008
- [cgal-discuss]Aff_transformation_3 Plane_3::transform_to_2d() const;, Max, 01/12/2008
- Re: [cgal-discuss]Aff_transformation_3 Plane_3::transform_to_2d() const;, Ashwin Nanjappa, 01/16/2008
- Crash on converting Polyhedron_3 to Nef_polyhedron_3 on an OFF input., Stephen Wong, 01/13/2008
- Re: [cgal-discuss] Crash on converting Polyhedron_3 to Nef_polyhedron_3 on an OFFinput., Max, 01/13/2008
- Re: [cgal-discuss] Crash on converting Polyhedron_3 to Nef_polyhedron_3 on an OFF input., Gilbert Bernstein, 01/13/2008
- RE: [cgal-discuss] Crash on converting Polyhedron_3 to Nef_polyhedron_3 on an OFF input., Stephen Wong, 01/13/2008
- Re: [cgal-discuss] Crash on converting Polyhedron_3 to Nef_polyhedron_3 on an OFF input., Gilbert Bernstein, 01/14/2008
- RE: [cgal-discuss] Crash on converting Polyhedron_3 to Nef_polyhedron_3 on an OFF input., Stephen Wong, 01/14/2008
